Good
Attention Beetleweight builders!
The max weight you can build to is 1.5kg....for my competitions that i will be doing in the future...weigh limit will be 1.5kg. I will be getting sponsored too so i want a 1st prize of £500 for the first uk champs. need the class to be a bit more popular first tho. may take time or not happen at all will see.
Probably the 5a sabertooth and a small lipo, forgot what the other bits are called that I bought when the class got popular before..for armour HDPE and titanium will probably work well in this class.
think some people were using the MFA motors and gearboxes from technoboxes before but might be wrong.
I'm actually really considering building a beetleweight with some of the leftover parts I've got laying about... Got many questions about it though, like what sizes are they usually, what sort of motors/speed controllers would be best and so on, but definitely will be something I'll get involved with somewhere down the line!
Very much like the look of that arena too, didn't realise it was as big as that either!
I think 200mm by 200mm is about average for size, mine is 230mm by 200mm at the moment.
The motors and speed controllers I told Matt about should be sufficient as far as I'm aware.
It is great that a lot of people seem to be interested in the weight class, personally think it has a lot of potential.
Ah, thanks for the help! Got an idea for a machine coming along now, need to get working on that after this feather's done!
It does have a lot of potential, very much like the look of this weight class!
Does the arena have a pit or arena well (for out-of-the-arena's) as well, sounds like a bit of an odd question I know, but I'm thinking ahead design wise!
