Attention Beetleweight builders!
  • Awesome! I did something almost identical with my real robots motors and gearboxes years ago.
    • Thanks! The motors themselves are surprisingly good in all honesty, can't see them being a permanent solution (plastic gears and all), but it's free so why not? Easy to mount as well, quite a handy bit of kit! Might be able to find a use for those LEDs that it had too...
      I've got a ludicrously oversized but light motor (for this application, anyway) for a drum spinner on the front too, just need to make a decent drum first!
      • Sounds cool mate, good luck with it
        • Got some parts for my beetle now, and I must say they are looking rather swish
          • Harry, that looks immense! But at the same time, it also looks massive
            I know that's probably due in part to it being in the same picture as an AW, but still looks waaay bigger than either of my part-built beetles. What are its dimensions?
            • It is massive, yeah. More fun that way :P
              75mm by 180mm and 17mm thick
              • How much does that weigh!?
                • roughly 500g
                  • Looking very nice harry looking forward to seeing these robots finished.
                    • Harry has started an interesting rebuild diary here http://www.bigconkers.com/forum/rpm-rebuild hope its helpful to builders to get an idea on how things are mounted and the workings of a battling 1.5kg machine
                      • A quick video of the drive that I'm planning to use in my beetle. Has 4 Pololu motors on 60mm wheels and a 3s Lipo. Currently uses a Sabretooth but I'm planning to swap it for a pair of botbitz or something similar.
                        Won't be using this design as this was used for my uni project last year but the drive seems perfect for the job.
                        http://www.youtube.com/watch?v=BriSZAfMNNA
                        • Sweet! Looks like it can outdrive mine easily
                          • Liking that drive Will. Nice
                            • Think its about time i got 180 off the shelf, dust it off and sharpen the teeth
                              Swanny are you still upholding the active weapon rule?
                              • Brilliant!
                                Active weapons are heavily encouraged but not mandatory.
