FRA Royal Robot Rumble: 30 enter, 1 leaves
  • FRA Royal Robot Rumble: 30 enter, 1 leaves
    The Rumble, Natural Selection and 360
    The Battle Royale, Love Bite V2.0 and Storm 2
      Okie Dokey
      Stats ASAP please
        If possible, Id like to enter the following :
        THE RUMBLE:
        1) Wedge Devolution
        2) Killotine: EVO
        THE BATTLE ROYALE:
        1) Whirligig 4.0
        2) Behemoth (RW7)
        Stats & pic can be found here: http://thdcrobotics.proboards33.com/index.cgi?board=Bravehearthttp://thdcrobotics.proboards33.com/...ard=Braveheart
        Should be another smasher, Davey
          ooh good
          Rumble
          baldur and kali
          battle royal
          tengu and razer
            I think...
            RUMBLE
            Leprosy Infection
            Mega Masher 2
            BATTLE ROYAL
            Die Ceratops Invertus
            Dantomkia (RW7)
              Weight: 100kg
              Dimensions (LxWxH):120x80x30
              Shape: Full body invertable spinner.
              Weapons: It IS a weapon all over. 28 KJ power
              Armour: 4mm Titanium
              Top Speed: 20MPH
              Main Tactics: Circle until spinner is going full speed then attack. Careful to avoid hazards though.
              Colour: Red with black writing
              Strengths: High powered weapon.
              Weaknesses: The ping effect and when its upside down the controls change (up becomes down) so that has to be kept track of. Also, being invertable, its wheels are vulnerable to axes.
              Name: Natural Selection
              Paint scheme: Green
              Wheels: Four, inside
              Shape: Boxlike. Scoop on the front, skirts around the sides, the back is rounded to help with self righting.
              Dimensions (cm): 80/40/20 (L/W/H)
              Weight: 100
              Armour: 4mm ti
              Weapon: A hydraulic lifting arm with vertical pincers. These are made of titanium and powered by a linear actuator, giving 400 KGs of grip. The arm is 70 CMs long.
              Motors: Two Bosch motors.
              Batteries: Natural Selection is powered with Hawker Genises batteries, which are placed in the rear to act as a counter-weight
              Top speed: 15 mph
              Turning circle: Zero
              Ground clearance: 10mm (There will never be a completely flat arena floor, 0 would be unrealistic imo)
              SRIMECH: The arm.
              Strengths: Crushing power
              Weaknesses: Slow to self right.
              Robot Name: Love Bite V 2.0
              Length/Width/Height: 120/30/20
              Weight: 100KG
              Motivation: 4 inner wheels
              Speed: 30MPH
              Weapon: €œWeapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. At the front is a Firestorm type flipping arm, CO2 powered, really just a SRIMECH but it will get other bots over, not really meant to be an OOTA flipper seeing as it€™s speed and the pincers do most of the damage.
              Drive: €œMotors used and voltage, style of reduction€ Bosch motors at 36 volts, gear reduction
              Power: €œBattery type and Voltage & Amps€ 2 x 36 volts at 3 amp NiCD packs
              Armour: €œMaterials and thickness, method held on€ 4 mm hardox, welded.
              Ground Clearance: 3MM
              Turning Circle: 0M
              Notes: It is a double wedge with skirts around the two sides. The paint job is black with Love the Bite in red down the skirts.
                After rereading the rules (no shufflers? DAMN!), Ive decided to replace Whirligig with Toby. Stats in the same place. Also, increased battery power and CO2 permitted by da rools.
                Curse your fussiness, Davey
                  rumble
                  disco 5 boosted
                  and someone else
                  royal
                  disc-o-inferno
                  panicking
                  stats when there found/made/finished
                    Sorry, but thats the way its gotta be to avoid confusion.
                    BTW, Extra CO2and batteries have to be declared, or you may fail mid battle.
                    UNDERSTAND ?!
                      ok, Love Bite V2.0 will have 10 KG worth of extra CO2 and extra batteries, the others will have as many extra batteries as i can fit in 20 KG
                        Come on, I resurrected this thread for me to write a big-ass fight. I need more robots !
                          for the rumble both machines have around twice the weigght in batteries, in both machiesn this weight is achieved by takign weight off the wheels which make up a large proportion of thwe weight
                          Tengu gaisn an extra 5 kilos by dropping 2.5 kilos from each 7.5 kilo blade
                          kali should have ample co2 to last the fight, because the gas is stored at high pressure but released much lower it means i should get in excess of 150 flips before havign to refill
                            Ok Alex, Ill bear that in mind
                              Me and my entries
                              Pie of Doom HWBE - stats later
                              Anti-Spin
                              Royal
                              Quocunque Jeceris Stabit
                              Ewe 2
                                Anti-Spin and QJS can be found here -
                                http://farr.proboards21.com/index.cgi?board=TeamSolarizedStatshttp://farr.proboards21.com/index.cg...SolarizedStats
                                Replacing Pie, cos its a LW and looks like a pie, here is Brucie
                                Robots name - Brucie Bonus
                                Mass - 120 kg
                                Weapons - Long-lasting low pressure nitrogen flipper
                                Can it self-right - Using flipper and it can run upside down all day
                                Velocity - 10 mph
                                Turning Circle - Skid Steer
                                Ground clearance - Front is 1mm, rear is a massive 2 cm
                                Skirts - Nah
                                Wheel Type - Solid, 4 on same axle.
                                Motors - A common of Bosch 750s at 36 volts
                                Body Shape - Wedge front, box rear
                                Armour - Titanium,
                                Colour - Grey
                                Batteries - Enough to last ~ 30 minutes
                                Summary - Old school
                                Strengths - Designed to last for long fights
                                Weaknesses - Bit Boring
