FRA Royal Robot Rumble: 30 enter, 1 leaves
  • FRA Royal Robot Rumble: 30 enter, 1 leaves
    Can I enter the Royal Rumble? Ill enter Pink Panther and X-Terminator.
      Note: Instead of Ankle Biter, Ill enter Snakebite Evolution. The stats can be found in Virtual Ebay.
        If I can Enter Another robot in the annihilator I will enter Hole in the Armour 2, stats in a minute
          Name-Hole in The Armour 2
          Weight in kilos (Max 100) 92kg
          Body Shape Circuler
          Speed in MPH 8mph
          Ground Clearance in mm -15mm
          Armour type and thickness Solid Steel Lorry Wheel Hub
          Locomotion type (wheels or tracks, say how many wheels) 2 wheels inside and over the robot robot
          Weaponary (maximum of 2) Fluffy Style Blade at Bottom of the robot
          Srimech - Invertible, Tyres go over top of robot
          Strengths-Destructive Weaponary
          Weaknessess-Exposed Tyres
            ok then, HITA is in the Royal Rumble, as is Pink Panther, and its also in the Battle royal
              Ill enter the Battle Royal with Terrorhurtz and Agro III.
              AGRO III
              Weight: 100kg
              Shape: Low invertable wedge with a low square hinged plate at the front
              Dimensions: 85 x 65 x 40 (cm; l x w x h)
              Speed: 17mph
              Ground Clearance: 0 at front due to hinged plate, 1cm at sides and rear
              Armour: 4mm titanium
              Wheels: 2, inside robot
              Power: 24V battery and motors
              Weapon: The hinged plate at the front allows 0 ground clearance - it can surpass skirts with a good push. Inside the wedge, half sticking out of it about 10cm back from the front, is a 8kg 3000RPM Tetanus Booster-like spinning drum - when opponents are on the wedge, it can damage them and often flip them over. At the rear is a 8kg 2000RPM X Terminator-like vertical spinning disc.
              Srimech: Invertable, but drum cannot be used upside down. It stops when the robot is inverted and doesnt hinder movement, but holds the wedge up a little bit, increasing the ground clearance. The hinged plate at the front flops down and touches the ground so the wedge still works.
              Tactics: Try to get under opponents and use the drum on them. If I cant, use the rear disc on them.
              Strengths: Fast, manouverable, dangerous weaponry
              Weaknesses: A little tricky to control, high ground clearance
                Ok guys, the FRA Royal Ruble is being written, but I need stats for Pink Panther
                  NAME- Pink Panther (Formely Big bad and pink 4.6)
                  SHAPE- Low wedge
                  COLOUR- Pink (of course)
                  WEIGHT- 100kg
                  DIMENSIONS- H: 37 X L: 100 X W: 97
                  SPEED- 12mph
                  TURNING CIRCLE- 0mm
                  GROUND CLEARANCE- 0mm at front 0mm at sides and rear due to quad sprung skirts so shouldnt come up it has12 torsion points to keep the skirts down. 15mm with out the skirts
                  ARMOUR- 5 mm polycarbonate over 3mm grade 5 titanium
                  WHEELS- has 2 inner tracks
                  POWER- 2 x S28 Magmotors on 24v.
                  WEAPONS- it has interchangeable weapons which consist of:
                  2 X dominator 2 like axes. 1 on the left side one on the right the axe head can be changed for a little wedge so it acts like 2 flippers, and the other interchangeable axe is like terrorhurtzs but is only one way, and finally the other weapon is a 10kg vertical disc.
                  SRIMECH- the axes or flippers can right the robot helped by a curved back if they are all ready fired or in flipper mode and with the disc it has a rear roll bar type thing but is supported underneath it so shouldnt bend.
                  NOTES- Bought off Virtual Ebay for £465
                  STRENGTHS- Interchangeable weapons
                  WEAKNESSES- easy to push from sides
                    Thanks for that. I need to know what set up youll be using for the Battle Royal.
                    I remember Big, Bad and Pink, I do beleive one of the Hell Bots mullered it
                    BTW, 1 more person wanted for the Battle Royal, 1 vapour, one real
                      Ill enter the Battle Royal, I just need to get some enteries ready...
                        Ill enter Interrorgator Evo and Toro.
                          Ill be using the disc with rollbars for the Battle Royal.
                            I require stats for Interrorgator, Ill have to do research for Toro
                              Toro is a superheavyweight American robot with a powerful flipper, Dave. Theres info about it at http://www.longnow.org/rhino/toro.htmhttp://www.longnow.org/rhino/toro.htm
                                A SHW ? hmmm, not sure if I should allow it
