FRA Royal Robot Rumble: 30 enter, 1 leaves
  • FRA Royal Robot Rumble: 30 enter, 1 leaves
    THIS SHOULD BE GOOD!!
      I am so pleased with the response thus far
      Alex: Which weapon set up do you want?
        Id like to enter my first two vapours
        Twister and Drumblebee, stats and pictures up soon
          Here are the stats on Twister Evo my first vapour
          Shape: Circular, with optional skirts
          Colour: Yellow for the body, grey for the wedge, blue for the main section of the arms, red for the small angled sections of the arms and black for the 2.5 KG hammers
          Speed: 10MPH
          Weight: 100KG
          Armour 5MM Hardox, skirts are 6MM Hardox
          Chassis: 4MM steel box section
          Drive: 2 NPC 1200s @ 36V
          Power: 4 36V NiCad battlepacks
          Locomotion: 2 aluminium wheels with vulkalon treads, 5MM in diameter and 3MM in width, with 2 front casters, all wheels are partially inside the body
          Ground Clearance: 2MM without skirts, 0MM without skirts, 0mm at front and sides of wedge
          Turning Circle: Zero thanks to 2 front casters
          Size: Bodys diameter is 45CM, main part of wedge is 20CM wide and 40Cm long, side parts of wedge are 10CM wide at widest point
          Weaponry: 4 arms leading to a 2.5KG hammer on each arm, plus a complicated gray fur-covered wedge to scoop up PREY!, sorry victims, I mean opponents, the fur is to hopefully either trap the opponent or provide a spectacular fire show
          Srimech: May self-right when it spins upside down
          Strengths: Will obliterate anything it touches, strong armour, everything should hopefully stay far away
          Weaknesses: May not self-right, battery life may be short
          BIO, OBLITERATION!!!!!!!!!!, nothing else, worse than a nuclear bomb
            not bad for a first try huh
              Yes, when it explodes under its own sheer crappiness.
              Youve a LONG way to go, young one.
                i know and it wiil not explode, but your robot will when Twister Evo catches you
                  hey kody, can you do a render of it for me
                    quote:
                    it wiil not explodeIm afraid the stats say otherwise. And besides, you dont even state how the arms work.
                    quote:
                    but your robot will when Twister Evo catches youGood for use as a slogan for the vapourbot, but it wont happen in a battle, I can assure you.
                    quote:
                    hey kody, can you do a render of it for meI am currently rendering my own projects, so no. Turn to someone else at the moment, please. Or learn Rhino or ProDesktop, if you REALLY want a render.
                      Please add my robots david i will have the stats for drumblebee up soon
                        they spin they are powered by a s28-400 magmotor
                          quote:
                          they spin they are powered by a s28-400 magmotorOkay. Then it wont explode, but it wont do relatively much either.
                            gonna post drumblebee now, nice name huh
                              quote:
                              gonna post drumblebee now, nice name huhYes, considering you stole it from one of the Series 5 qualifiers. :P
                                why?
