FRA Royal Robot Rumble: 30 enter, 1 leaves
  • FRA Royal Robot Rumble: 30 enter, 1 leaves
    Cool, ok, added to the list
    who else ?
      ^^The most w00tiest and Epic bump in FRA history^^
      David is interested in writing this again, folks
        :P You absolutely had to resurrect the oldest thread in the whole of fanfic, didnt you?
        Ill enter if I still can...
          Hehe, thanks Kody
          Ok, starting from Scratch, I need 15 builders to enter 2 bots each, shufflers get no additional weight advantage, however all robots get an additional 20% weight allowance for CO2 or higher capacity batteries, one of which must be stated beforehand
          Lets see those bots, fellas
            reserve me a spot
            3 friggin years...
              Righty...give me Phoenix Down (with claw and saw setup) with 22kg extra in batteries, and No Exceptions, with 20kg extra.
              Stats: http://strickenone.proboards99.com/index.cgi?board=chevhwhttp://strickenone.proboards99.com/i...i?board=chevhw
                20 kg extra of what ? CO2 or batteries ?
                  Well, seeing as there are no pneumatics in the robot whatsoever...batteries, plzkthx.
                    Also, FYI, I will allow the 10kg addition for Tracked robots
                    30 robots, down to 1...its gonna be freakin carnage!
                      Ok then, Ill enter Symmetry with 20kg worth of A123s. That will keep me going for an hour at least.
                      For the second one Ill use Sideswipe, also with 20kg extra batteries.
                      For stats:
                      http://www.insaneclown.nl/vapourbots/http://www.insaneclown.nl/vapourbots/
                        save me 2 spots
                          Reserve me 2 spots as well please.
                            Slammer and Baldur
                            Increase on batteries for both
                            http://www.alexjholt.tkwww.alexjholt.tk
                              Bad Temper Jr and Spring-BOK! please.
                              STATS UNDER NORMAL CIRCUMSTANCES...
                              BAD TEMPER JR
                              Weight: 80 kilos
                              Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
                              Speed: 12mph
                              TC: 0
                              GC: 7mm
                              Wheels: 4 inner
                              Armour: 6mm titanium
                              Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
                              Colour: Red underbelly, black sides, grey top, white weapon.
                              Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
                              Srimech: The weapon goes that.
                              Notes: I have a little Lego model if you need pictures.
                              Strengths: Persistant.
                              Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
                              SPRING-BOK!
                              Weight: 100 kilos
                              Body Shape: Firestorm.
                              Speed: 12mph
                              TC: 0.
                              GC: 0 at front, 7mm at sides.
                              Wheels: 2 inner.
                              Armour: 8mm titanium, covered in 2mm orange fur.
                              Power: 3x 12v batteries, powered by a couple of Magmotors (S28-400s).
                              Colour: Orange, thanks to the fur.
                              Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards via hydraulics. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
                              Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
                              Inspiration: Its named after an antelope.
                              Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
                              Strengths: Experience, unique weapon.
                              Weaknesses: Untested, Flammable, back-up plan probably wont work.
                              STATS FOR FRARRR PURPOSES...
                              Bad Temper Jr will have 20 kilo extra in CO2 to power his knife blade, whilst Spring-BOK! will have an extra 22 kilos of weight in batteries. I say 22 because his fur is ALSO being removed (yep, you read that right!).
                                I think Ill give this a miss....
                                PSYCH!!
                                Ill enter Supreme and Noo Monsoon, both with 20kg of extra battery power.
                                Stats can be found here:
                                http://strickenone.proboards99.com/?board=teambv&field=ordertime&order=desc&page=2http://strickenone.proboards99.com/?...rder=desc&page =2
