Pussycat Tribute Tournament 5
  • #76
    Changing hte drive on Shovearound to 4 LEM130s, 48v and geared 22:1.
    ALso, its a monoque now, so no frame.
    • #77
      HWs:
      Flaming Hell
      Weight: 100kg
      Dimensions: 90x90x60 cm
      Weapon: a triangular spinning cage with 3 sharpened bot openers on each end, weighing 5kg each, spinning at 3000 RPM, powered by a Lemco on 36v
      Power: 2x Bosch 750 motors at 24v (its been made so that the cage motor gets 36v but the drive only gets 24, as the drive is ok as it is on 24V)
      Shape: circular base with triangular cage atop
      Speed: 15mph
      Drive power: 4bph
      Notes: small electric actuators in the rotor arms in order to self right. They have been shock proofed so that the weapon impact will not bust them, and the cage spins 2mm from the ground. Small bearings for the cage and the far set apart wheels give it increased stability for a FBS
      Turning Circle: 0cm
      Armour: 3mm titanium
      Wheel Type - 4 small wheelbarrow type wheels (no need for great traction)
      Strengths: Power of cage
      Weakness: Unpredictable bounce off from an opponent
      Hell Machine
      Weight: 100kg
      Dimensions: 140x100x60 cm
      Weapons: Lemco motor powered axe (run through gear box) that can deliver an axe blow of 3 tons (according to my calculations) and rear linier actuator operated lifting arm that can flip 600kg
      Srimech: Side arms and rear arm
      Speed: 15mph
      Transmission: a 4 wheeled Tornado set up(36v and same gearing), but with a pair of Mag C40€™s in place of the Bosch motors, and a set of NiMh in place of the heavy Lead Acids the real thing uses.
      Turning Circle: 0m
      Ground clearance: 0 at the scoop and wedge edge, 2mm the rest of the way around
      Wheel Type: Go-kart
      Body Shape: scoop fronted, wedged back
      Armour: 8mm Grade 5 Titanium and 2mm stainless steel
      Colour: Black with flame face on scoop and name in blood writing on side, devil head on rear wedge
      Strengths: Enormous pushing power (About 12hp), EXTREMELY powerful axe, relentless in attacking (until a robot is immobile)
      Weakness: Dislikes spinners, doesnt like weapons that use carbon
      Weight: 100kg
      Dimensions: 150cm x 80cm x 120cm
      Shape: low angled box with disc on the front like 13 black and rear 259 disc, style
      Weapons: A front mounted Horizontal spinning disc and a rear mounted vertical spinning disc, both running at 4500rpm and delivering a blow of 75kj
      Top Speed: 13 mph
      Transmission: 4 Rubbertex coated aluminium wheels (Rubbertex is a grippy rubber substance used on the K*bot tables) run on a Smidsy type wheel system, and run by a pair of Bosch 750€™s and a bank of Ni-cads to give me more weight for armour
      Armour: 8mm Titanium
      GC: 3mm either side and back, 7mm under the disc at the front, variable at the sides of the disc
      Srimech: powerful electric arms mounted on the top
      Turning Circle: 0cm
      Strengths: devastating weapons
      Weakness: carbon based weapons
      Notes: will NEVER turn the vertical flywheel into an opponent as it will throw SH over. Also, counter-acting discs (vertical and horizontal) will keep it stable, and if it is flipped, it does a funny jig in the air before coming down, most of the time, right way up
      Dimensions: 120cm x 80cm x 40cm
      Weight: 100kg
      Shape: steep wedge front, elongated wedged tail (not used as a weapon)
      Weapon: 1000psi 2 pivot pneumatic flipper that can generate enough momentum and force to throw a 100kg robot 25ft up and 20ft across
      Top speed: 18mph
      Transmission: just like Razer€™s
      GC: 0 at the front, 2mm down the side, 4mm at the back end
      Turning Circle: 0cm
      Armour: 6mm aluminium and steel alloy
      Strengths: Can win with one weapon shot
      Weakness: None
      Notes: 4 wheels, the rear two of which are Razer type, so the flipper is always facing its opponent
      Name: Jaws of Hell
      Weight: 100kg
      Dimensions (LWH): 130 x 100 x 25 cm
      Body shape: Tornado shaped, but with 6 wheels
      Weapons: a hydraulic tearer. The idea is that the large blade that is edged on both sides punctures the armour of an opponent, and a 3000psi hydraulic ram separates them, causing a huge tear in the armour. The edge is carbon tipped, so Titanium is not even there as far as Im concerned.
      Power: a pair of LEM 130s on 36v running through a Storm 2 transmission (with 6 vulcalon wheels, with small screws in them for that little extra)
      Armour: 4mm Hardox and 2mm stainless steel
      Srimech: invertible
      Speed: 27mph
      Strengths: vicious weapon
      Weakness: Unique weapon, may be mis-understood
      Weight:100kg
      Dimensions: 100 x 100 x 35 cm
      Shape: Low wedge, rounded back
      Weapons: A 750 PSI pneumatic arm that is mainly for self righting but can be used as a weapon, and a set of 3 Kill Saws at the back. The Kill Saws four, 20 inch, carbide tipped, SystiMatic saw blades. The blades are powered by a 48 volt, 3.5 horse power motor and can shred titanium and many other things too.
      GC: 0mm at the front, 1mm the rest of the way
      Wheels: go-karts
      Power: a pair of Bosch 750s on 36v, whereas the weapon is on 48v
      Speed: 18mph
      Armour: 2mm stainless steel and 4mm aluminium
      Strengths: rip-roaring weapon
      Weakness: iffy armour
      Weight: 100kg
      Dimensions: 100 x 100 x 50cm
      Shape: Vortex, but without the motor sticking out the back
      Weapons: A 27kg outer-rim weighted steel vertical flywheel, Powered by a B&S motor at 48v and run through a 40:1 ratio chain and sprocket transmission. The disc runs at 3500RPM but packs a 79Kj wallop (I worked it out; it€™s not that dissimilar from Matildas tail disc).
      GC: 3mm all the way around
      Wheels: 2 x Vulcanised Aluminium hubs
      Power: a pair of Bosch 750 watts motors running on 36v (Like Flaming hell, wired so the drive gets less and the weapon gets more) running through a 10:1 ratio gearbox
      Speed: 12MPH
      Armour: 6mm Stainless Steel
      Colour: Black, with pentagrams and demon faces painted in random places
      Strengths: Devastating Weapon
      Weakness: No srimech as such, but can run on the disc, which is then thrown into reverse which causes the robot to flip over, Stinger Style. Tipped right way up
      MW:
      Hell Fire
      Weight: 50kg
      Dimensions: 120x110x40cm
      Shape: low slung wedge
      Weapons: Powerful pneumatic flipping arm that has a plate that runs the width of the front, that can throw 75kg 3 feet or so no problem, and can, flip 100kg, but not too high, and a rear Pussycat style Saw, that spins at 4000rpm, and has carbon tipped teeth to cope with titanium.
      Top Speed: 25mph
      Transmission: a pair of Mag C40€™s on 24v NiMH€™s running through a really simple transmission, but a reliable one due to features to keep the chain on.
      Amour: 4mm Ali and steel alloy and 2 mm of stainless steel on top
      Strengths: Very manoeuvrable and fast, generally very easy to control
      Weakness: Exposed outer wheels
      Ground Clearance: 0 at the front, 5cm at the back, varying from 0 to 4.5 at the sides (wedge goes up)
      Turning Circle: 0cm (its turning is very nimble)
      Notes: Hell Fire is extremely manoeuvrable because it has 2 sets of wheels on the same axle, meaning that it€™s incredibly stable, and can turn on a penny, and can still run even with outer wheels ripped off
      LW:
      Weight: 25kg
      Dimensions (LxWxH): 50x40x30cm
      Shape: scooped front, rectangular body, rounded back
      Weapons: 2 conjoined Pincer type crushing jaws with a small hydraulic ram powering each, producing a 1 and 1/2 tonne crushing force
      Colour: mainly black, but with Rotweiler features all over the body
      Speed: 15MPH
      Transmission: a pair of Bosch 400€™s on 24v running through a simple 6:1 ratio gearbox
      Armour:1mm stainless steel and 1mm Ali/steel alloy (tough enough for LWs)
      Srimech: cable pulled legs from out the side (like a dog cocking his leg to do his business)
      GC: 0 at the scoop, 2mm the rest of the way
      Turning circle: 0cm
      Strengths: Power of weapon
      Weakness: slow self righter (still effective mind)
      FW:
      Weight: 12kg
      Dimensions: 59 x 45 x 15 cm
      Shape: Scoop front, rectangle body, wedged rear end
      Weapons: a FW gold motor powered axe, drilled for lightness, but with still a heavy axe head, with a wallop power of about 500kg
      Transmission: Ali protected Windscreen wiper motors attached directly to the compound rubber wheels, which are studded with screws pointing out (like those on Chaos 2)
      Speed: 12 MPH
      GC: 2mm all around, 0 at the scoop end
      Srimech: The axe, the weight of which pulls it over so it cannot rest on its side. Make SURE you remember that.
      Armour: 2.5mm mild steel on the sides, 1.5 mm steel elsewhere
      Strengths: The axe
      Weakness: the armour may not stand up to strong FW spinners, but should prove good enough
      • #78
        OK, two people wanting to fill the last spot. :S After much deliberation and conference with some other competitors, weve come up with an idea.
        - Dave W and Martijn enter as one team. Each enters 4 Heavyweights each (at least one of these four must be a vapour)
        - Dave enters a FW and MW
        - Martijn enters a LW and SHW
        If you both think this sounds OK, please post your response here and get your stats together soon. Thank you
        If that fails, we can go to the other, other plan and have you two battle it out in a little qualifier
        • #79
          Or seeing I only entered to make up numbers, I could always withdraw and let Dave take my place :P
          • #80
            I would like to go with Steves suggestion, as I would not want to deny Frank his place.
            BTW frank, any pics of CB ? and why have you put a lifter in ? Its had a drill since the day you designed it
            • #81
              Now these stats have been done at different times and for different formats, dont like that? Tough
              Robot Name: Love Bite V 2.0
              Length/Width/Height: 120/30/20
              Weight: 100KG
              Motivation: €œWheels/Legs/Shuffles€™ 4 inner wheels
              Speed: 30 MPH
              Weapon: €œWeapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. At the front is a Firestorm type flipping arm, CO2 powered, really just a SRIMECH but it will get other bots over, not really meant to be an OOTA flipper seeing as it€™s speed and the pincers do most of the damage.
              Drive: €œMotors used and voltage, style of reduction€ Bosch motors at 36 volts, gear reduction
              Power: €œBattery type and Voltage & Amps€ 2 x 36 volts at 3 amp NiCD packs
              Armour: €œMaterials and thickness, method held on€ 4 mm hardox, welded.
              Ground Clearance: 3MM
              Turning Circle: 0M
              Notes: It is a double wedge with skirts around the two sides. The paint job is black with Love the Bite in red down the skirts. Muchos credit to Aaron for the help.
              Accomplishments: Spawn of Love Bite (NSBFL 7 16th seed), the NSBFLX New Blood runner up
              Name: Natural Selection
              Paint scheme: Green
              Wheels: Four, inside
              Shape: Boxlike. Scoop on the front, skirts around the sides, the back is rounded to help with self righting.
              Dimensions (cm): 80/40/20 (L/W/H)
              Weight: 100
              Armour: 4mm ti
              Weapon: A hydraulic lifting arm with vertical pincers. These are made of titanium and powered by a linear actuator, giving 400 KGs of grip. The arm is 70 CMs long.
              Motors: Two Bosch motors.
              Batteries: Natural Selection is powered with Hawker Genises batteries, which are placed in the rear to act as a counter-weight
              Top speed: 15 mph
              Turning circle: Zero
              Ground clearance: 7mm
              SRIMECH: The arm.
              Strengths: Crushing power
              Weaknesses: Slow to self right.
              Accomplishments: Runner up of Daves four bot tournie.
              Name: Going Crunch (Cluster bot)
              Weight: 100kg (55 KG spinner 45 KG flipper)
              Dimensions (LxWxH):120 x 30 x 12 joined.
              Shape: The flipper is triangular and designed not to flip itself ala Gemini. There is also a lump of metal at the back guarding against that as well. The flipping device is at the point of the triangle and there is a slight scoop. The spinner is same shape only the triangle is cut off with the spinner.
              Weapons: A flipper that has the ability to toss opponents far rather than high and a spinner that delivers about 20 KJ energy.
              Srimech: The flipper is its own srimech and the spinner has a lifting arm type srimech.
              Armour: 4mm Titanium
              Top Speed: 14 MPH when joined. Flipper 18 MPH separate. Spinner 14 MPH separate
              Main Tactics: At first the robots can be joined with a spinner at one end and a flipper at the other. Then they separate and use a pincer type attack.
              Colour: Red with black writing.
              Strengths: Ability to use a pincer attack.
              Weaknesses: The flipper is quite light and can be pushed around from the back. That€™s where the spinner would need to help.
              Accomplishments: Seeded 14th in NSBFL 7 Last surviving seed in NSBFL 7, current semi finalist. Runner up (with 360) of NSBFLX tag terror, has always escaped the first battle since being converted from Going Going Crunch
              360: Frank, you have the stats somewhere, could you find and post them for me?
              Accomplishments: NSBFLX tag terror runner up (with Going Crunch)
              • #82
                so, me and Dave W entering as one team?
                fine with me, I already was kinda worried about the amount of bots I needed to come up with :P
                (Im kinda inexperienced yknow)
                • #83
                  Steve, can you pick some random bots for the other weights for me, if Son of Wyachi hasnt gone, ill use that for my super heavy, otherwise, i dont have a clue. I can probably use one of the Vampire Twins clusters for one of the weights, 50KG
                  • #84
                    Dan Says: w00t!
                    STEVE SEZ:
                    Good to see Mr B and Mr W agree with this little idea. I appreciate your gesture, Frank, but this way, nobody has to pull out. Plus, it makes the seedings easier for me
                    Also, Chris, Son of Whyachi and a Vampire Twin will do just fine for your SHW and MW. Ive also chosen Mammoth and 259 as your FW and LW respectively, if thats OK with you.
                    PTT5 ENTRIES THUS FAR:
                    HEAVYWEIGHTS
                    1. Supreme Glory Gamma (Daniel S)
                    2. Squishiest
                    3. Manic Monsoon
                    4. Dervish //
                    5. Sonic Boom
                    6. Artemis
                    7. Pure Evil: Revenge of the Disc
                    8. Firestorm 5 (RW7)
                    9. A Large Red Bus Drove My Love Away (Dave S)
                    10. Chalkie 3G
                    11. Push-ish Fundimental
                    12. Son of Wedgie
                    13. P.C.C.
                    14. The Circle Revisited
                    15. W.A.F.T.
                    16. Tornado (RW7)
                    17. Disco 5 (Martyn F)
                    18. T.I.R.T.A.S.M.
                    19. Keep On Panicking
                    20. Star 69
                    21. The Deer
                    22. Take Me Out
                    23. Razer (RW6)
                    24. Panic Attack (RW Ex 2)
                    25. Hacked-Off Ha-ka (possible editing?) (Matty F)
                    26. Roo Cubed
                    27. Powerpoint the Thrasher 5
                    28. Bull in a China Shop L.E.
                    29. Windiest Killer
                    30. Riptile 2
                    31. Back 2 Basics
                    32. Voltronic (BB5)
                    33. Son of Ripper 5.0 (Andy J)
                    34. F.P. 4.0
                    35. Wedga REVO V2
                    36. GigaByte V1.5
                    37. The Nose 3.0
                    38. GeForce 3.0
                    39. Psyclonic
                    40. Typhoon 2 (RW7)
                    41. Mass Disctruction Ultimate 3 (Aaron K)
                    42. M.O.A.B.I.E.
                    43. Gyrate
                    44. The Ultimate Wedge
                    45. Intensity
                    46. Rogue
                    47. Fragmentor
                    48. Slam Job (BB5)
                    49. Tengu VII (Alex H)
                    50. King Black Panther
                    51. Achilles
                    52. Slammer 5
                    53. Kali
                    54. ArchAngel of the Abyss
                    55. Dante
                    56. Storm 2 (RW7)
                    57. unknown (Scott A)
                    58. unknown
                    59. unknown
                    60. unknown
                    61. unknown
                    62. unknown
                    63. unknown
                    64. X-Terminator (RW7)
                    65. SpinVerter 4 (Tom R)
                    66. UltraVerter
                    67. SpunOut 3.0
                    68. Ze Newie
                    69. Automatic Schmuck
                    70. Surround Sound
                    71. a.k.a. I-D-I-O-T
                    72. Napalm (RW2)
                    73. Agro 3.5 (Richard S)
                    74. Battle Raptor 4
                    75. Death Adder 3
                    76. M.O.R.D. 2
                    77. Slice n Dice on Steroids
                    78. Snakebite IV
                    79. Tenderizers Revenge 2
                    80. Warhead (BB5)
                    81. Natural Selection (Chris C)
                    82. Love Bite V2.0
                    83. Going Crunch
                    84. 3-6-0
                    85. Pussycat (RW7)
                    86. Hypno Disc (RW Ex 2)
                    87. Wild Thing (RW4)
                    88. 13 Black (RW7)
                    89. Die-Ceratops ReInvertus (Chris M)
                    90. Orka Mk 4
                    91. Cyclone Force 2.5
                    92. Crash Bandibot 2
                    93. Leprosy Infection
                    94. Axe-O-Lotl
                    95. Mega Masher 2
                    96. Iron Awe 2.1 (RW7)
                    97. 4 Swords (Tony P)
                    98. Beavis and Bothead
                    99. The Robotnik Twins
                    100. Little Man on the Boat
                    101. Aquarius
                    102. Dr Evil
                    103. Shovearound 2
                    104. Spawn Again (RW7)
                    105. Flippa Frenzay Mk 7 (Matty McD)
                    106. No Close Shave 3
                    107. Not Another Pushover 3
                    108. Wind Chiller
                    109. Rippoff Yet Again!
                    110. The Axe Attaxe
                    111. Atomic (RW7)
                    112. Bulldog Breed (RW7)
                    113. Tempest Evil-er-oution (Frank G)
                    114. The Disc 5
                    115. Enter The May Tracks
                    116. I.D.S.F.A. (and what does it mean? :wink
                    117. Starstorm 2
                    118. N.S.B.F.R. X
                    119. Another Twist of Fate
                    120. The Crashing Bore (realie. Evidence? )
                    121. unknown (Martijn B/Dave W)
                    122. unknown
                    123. unknown
                    124. realie
                    125. unknown
                    126. unknown
                    127. unknown
                    128. realie
                    FEATHERWEIGHTS
                    1. Critical Damage (Daniel S)
                    2. Pillow Torque (realie) (Dave S)
                    3. D.T.K. (Martyn F)
                    4. unknown (Matty F)
                    5. OverDrive (Andy J)
                    6. Particle Accelerator (Aaron K)
                    7. Sith (Alex H)
                    8. Maximum Velocity (Scott A)
                    9. unknown (Tom R)
                    10. Snakebite Hatchling (Richard S)
                    11. Mammoth (Chris C)
                    12. Ram Raider (Chris M)
                    13. Novastorm (Tony P)
                    14. Aaargh! (RW Ex 2) (Matty McD)
                    15. Susan (Frank G)
                    16. Hells Angel (Martijn B/Dave W)
                    LIGHTWEIGHTS
                    1. Triskaidekaphobia (Daniel S)
                    2. Ziggo (BB5) (Dave S)
                    3. Spikey 2 (Martyn F)
                    5. MicroForce (Andy J)
                    6. The Quick and the Dead (Aaron K)
                    7. Tiny Tengu (Alex H)
                    8. Lithium and Destroy (Scott A)
                    9. unknown (Tom R)
                    10. Crash (Richard S)
                    11. 259 (Chris C)
                    12. Little Big Bot (Chris M)
                    13. Marasame (Tony P)
                    14. Wedge of Doom (BB5) (Matty McD)
                    15. I.S.A.W. Some More (Frank G)
                    16. unknown (Martijn B/Dave W)
                    MIDDLEWEIGHTS
                    1. Purer (Daniel S)
                    2. T-Minus (BB5) (Dave S)
                    3. Daphne (Martyn F)
                    5. Typhoon (RW7) (Andy J)
                    6. Insomniac (Aaron K)
                    7. Blizzard (Alex H)
                    8. unknown (Scott A)
                    9. unknown (Tom R)
                    10. Collision Force (Richard S)
                    11. Vampire Twin (Chris C)
                    12. Tom (Chris M)
                    13. Bothead (Tony P)
                    14. Red Square (BB5) (Matty McD)
                    15. Goldbug (Frank G)
                    16. Hell Fire (Martijn B/Dave W)
                    SUPERHEAVYWEIGHTS
                    1. Out Of Bounds (Daniel S)
                    2. Diesector (BB5) (Dave S)
                    3. Someones Watching Over Me (Martyn F)
                    5. œberForce (Andy J)
                    6. Gyrate Extreme (Aaron K)
                    7. The Red Knight (Alex H)
                    9. unknown (Tom R)
                    10. Toro (BB5) (Richard S)
                    11. Son of Whyachi (BB5) (Chris C)
                    12. Octopush 2 (Chris M)
                    13. Psycho Cyan (Tony P)
                    14. Hornet (Matty McD)
                    15. unknown (Frank G)
                    16 places taken, 0 place remaining. Hooray!
                    Stats needed from...well...most people :wink:
                    • #85
                      let me just check, stats owed are:
                      sith, tiny tengu, king black panther, blizzard?
                      • #86
                        Ill get the rest of my stats up ASAP.
                        • #87
                          Looks like Chris wants me to post 360s stats. I hope these are current. If not, it sucks to be him
                          Weight: 100kg
                          Dimensions (LxWxH):120x80x30
                          Shape: Full body invertable spinner.
                          Weapons: It IS a weapon all over. 28 KJ power
                          Top Speed: 20MPH
                          Main Tactics: Circle until spinner is going full speed then attack. Careful to avoid hazards though.
                          Strengths: High powered weapon.
                          Weaknesses: The ping effect and when its upside down the controls change (up becomes down and left becomes right) so that has to be kept track of. Also, being invertable, its wheels are vulnerable to axes.
                          Dave, CB has a lifter because it evolved a bit during discussions. Neil wanted to make it a grapler-lifter, and I liked the sound of that. The downside was, the drill isnt compatible with that idea.
                          • #88
                            Right, well, the HWs I wanna Enter are Flipping Hell, Flaming Hell, Hell Machine and All Hell.
                            As for a SHW, I have a design, but its up to martin, he may have one of his own
                            • #89
                              Slight changes to stats:
                              LW:
                              Weight: 25kg
                              Dimensions (LxWxH): 60x50x30cm
                              Speed: 15MPH
                              Srimech: cable pulled legs from out the side (like a dog cocking his leg to do his business), and a cable pulled tail that pops out of the top near the back if it rests on its head
                              Turning circle: 0cm
                              FW:
                              Weight: 12kg
                              Weapons: a pegueot radiator fan motor powered axe, drilled for lightness, but with still a heavy axe head, with a wallop power of about 500kg
                              Transmission: 24v 3Ah Ni-cads power 2 Ali protected Windscreen wiper motors attached directly to the compound rubber wheels, which are studded with screws pointing out (like those on Chaos 2)
                              Speed: 12 MPH
                              Armour: 2.5mm mild steel on the sides, 1.5 mm aluminium checker plate elsewhere
                              Strengths: The axe
                              • #90
                                well Dave, could you show me the stats of yer SHW then? ^^
                                either Ill completely hate it and enter one of my own (which is unlikely :P)
                                or its ok and well go with yours
                                (cause I dont have a SHW design of my own)
                                and for the HWs, I wanna enter TAN and Gravity
                                which leaves me with 2 HWs and 1 lightweight still to come...
