Pussycat Tribute Tournament 5
and here is my final heavyweight, Lightweight and Super Heavyweight wil be entered by Dave (W)
Name - Axe to Fall
Weight - 100 Kilogram
Speed - 24 km/h (15 mph)
Dimensions - 115x80x40 cm
Ground Clearance - 0 at the front, 2 mm anywhere else
Power - 2x LEM130s at 48v
Movement - Four wheels, 10cm diameter
Weaponry - The main weapon is a 5 kg double-headed axe on top of the machine, it€™s a steel 80 cm shaft with two diamond edged blades made of hardox on the end of it. The blade which aims to the front of the machine is shaped like Steel Avengers axe, to make fine and deep slices in opposing armor, the other one is shaped more like Terrorhurtz€™ in order to make more nasty broad slices in opposing armor.
The whole axe is powered by 2 nitrogen bottles at 1000 psi, a 1 kg buffer bottle and a 30 mm bore ram, for fast and furious hits, with a downforce of 1.5 ton brought onto a fine blade, and an energy unleash which seems significantly higher than for example Beta€™s if my calculations are right.
-At the front of Axe to Fall is a small wedge/ram made out of 8 mm Titanium, to lift my opponent€™s wheels into air while clobbering them with my Steel Avenger-style blade, or perhaps even to grab him. This ram is also my plan B if my axe fails in battle, just ram them hard
Armour - 10 mm Aluminium chassis, 8 mm Titanium front and 15 mm polycarb for the rest of the bot.
There are also two small blocks of vulcanized rubber on the mid-front and the mid-back of my machine, to absorb the downforce where the axe hits the chassis.
Shape - Basically it€™s a 80x80x20 box, with a curve on top of it (making it look like an old pirates-style treasure chest actually). There are two small polycarb domes on both sides so my bot won€™t end up on it€™s side. On front is a small wedge.
Srimech- The axe acts as a srimech, thanks to the curved shape of the top my bot can self right in no time, even if it has to self right over the wedged front (the wedge is very small mind you).
Power: Very destructive axe that will both hit at the front and the back, fast srimech and an nearly indestructible front
Weakness: A powerful spinner might eat my polycarb, not the fastest bot on the block.
btw, if anyone wants to see renders of my bots, feel free to ask, I have them stored on my pc atm and Im pretty sure theyll make my descriptions alot more understandable
Name - Axe to Fall
