Pussycat Tribute Tournament 5
And here is the last the bots i need to post stats for, Frank, thanks for posting the 360 stats.
Name: Vampire Twin (Cluster 1 (Obviously, i wont be switching them between fights))
Dimensions (mm): 120x60x20
Shape: Box shaped with skirts on each side except the back
Colour: Black with splotches of blood
Ground clearance: 2mm on the three skirted sides, 3.5mm at the back.
Weight: 50 KG
Power: Bosch motor
Top speed: 15mph
Weapons: The bot has two drills powerful enough to pierce all but the toughest armour (stay the hell away from 6mm hardox
). The front skirts also flip up (to help with self-righting) so they could be counted as weapons
Armour: 5mm Titanium
Mobility: Four wheels, the wheels are protected by the skirts which are also there to reduce ground clearance. If a skirt was taken off, the ground clearance would go up to 15mm (same as the back)
Turning circle: 5mm
SRIMECH: The skirts flip up to self right the bot.
Strengths: High powered drills. Low ground clearance. Creature of the night (ok so that€™s stupid but I wanted another
Weaknesses: If a skirt got hit the right way, it could jam a wheel. If the skirts are removed, no SRIMECH. Aversion to sunlight (stupid weakness to go with stupid strength
Weight: 50 KG
Power: Bosch motor
Top speed: 15mph
Turning circle: 5mm
