NSBFLX-2
  • NSBFLX-2
    But what are you entering that in?
    • NSBFLX-2
      New Blood
      • NSBFLX-2
        lol, I didnt notice this tournament till now
        guess Ill create something for the new blood myself
        • NSBFLX-2
          Whats the GC under the skirts?
          • NSBFLX-2
            Heres a little piece of machinery Id like to enter in the New Blood competition
            Name - Sheer Heart Attack
            Shape - Invertible tracked box, only the main-body between the tracks is shorter then the tracks (as can be seen on the picture), build in such a way that the tracks are in contact with the ground no matter what (like 101), only with two titanium bars at the end of both tracks to protect them from destructive spinners
            Weight - 110 Kilogram
            Speed - 24 km/h (15 mph)
            Dimensions - 90*100*25 cm
            Ground Clearance - Zero underneath the tracks, but with an overhang
            Power -2x LEM130s at 48v
            Movement - Two sturdy titanium tracks, with rubber strips attached to them for traction
            Turning Circle - Zero
            Weaponry - A 22 kilogram titanium spinning drum at the front of my machine equipped with 10 hardox teeth, powered by a LEM 130 and spinning around at 5000 RPM, which produces nearly 40 kJ.
            Armour - 6 mm titanium all around (including the tracks themselves)
            Srimech - It€™s invertible
            Strenghts - Devestating against most wedges, nice traction
            Weakness - Exposed (but quite sturdy) tracks might be a weakness
            Notes- I designed this robot to be a robot which gains it€™s advantage by driving OVER an opponent, a bit like Barberous. The exposed tracks are the ultimate way to keep in contact with the floor no matter what kind of ramp I drive up, so that if a good rambot or whatever gets underneath me in a threatening way, I can simply go in full reverse and escape. The drum, ofcourse, is a perfect way to hurt an opponent while he€™s underneath you.
            Here€™s a picture: http://jupiter.walagata.com/w/madbull/Tracks2.gifhttp://jupiter.walagata.com/w/madbull/Tracks2.gif
            • NSBFLX-2
              OK Enterprise and SHA are in the New Blood. A note for Kevin though, Im assuming a reasonably high GC under the skirts seeing you didnt specify.
              • NSBFLX-2
                Its still pretty low under the skirts.
                • NSBFLX-2
                  Having just received word that not everyone is happy with the downtime this tournament is undergoing, I feel I have to restate my position.
                  I do not have writers block. Writing such a lot of fanfic recently has caused other projects of mine, namely a book I wish to get published, to be put on the back burner. Although I enjoy writing the NSBFL, my book is far more important to me, and its that Im concentrating on.
                  NSBFL X-2 will be kicked off when I feel Ive done enough work on the book for the time being.
                  • NSBFLX-2
                    Well said.
                    Same with any of my tournaments generally for gettign enough lyrics to give Glen to put the music to.
                    • NSBFLX-2
                      Im in no position to tell people to get moving with tournaments as we all know... :P
                      I think we all have other stuff to be getting on with at this moment in time which prioritises over fanfic.
                      • NSBFLX-2
                        Dropping Aquarius VS Ringwraith since A: I dont think RIch will ever respond to the challenge, and B: Myself, andy, and Steve are requesting a Melee between:
                        MSSD
                        Tails
                        Knuckles
                        Robotnik Twins
                        Im sure you know where my stats are [on this page] And Andy will post a link to knuckless stats in a bit.
                        • NSBFLX-2
                          If theres gonna be a Sonic melee, then stats for Knuckles are http://teamcode14.proboards24.com/in...133379047here.
                          • NSBFLX-2
                            Ill file the melee under grudge matches.
                            • NSBFLX-2
                              New Blood: http://teamcode14.proboards24.com/in...=1133099289The
                              • NSBFLX-2
                                The Translator eh? sweet stuff Andy
                                Ive decided to enter Back to Rock 2 in the TYOM
                                Name - Back to Rock II
                                Shape - A box with a slightly sloped front
                                Weight - 100 Kilogram
                                Speed - 29 km/h (18mph)
                                Dimensions - 90x75x30 cm
                                Ground Clearance - 0 underneath skirts and at the front, 8 mm anywhere else
                                Power - 2x Etek motors at 48 volt
                                Movement - Four wheels, 20cm diameter
                                Turning Circel - Zero
                                Weaponry - It has a broad hydraulic lifting arm which can easily lift 200 kg. To easily get underneath an opponent, it has two lifting plates at the bottom of the arm, one on the left end and one on the right end, instead of one large lifting plate like Behemoth.
                                Between the two plates, in the centre of the scoop, I mounted a vertical diamond edged Pussycat-style blade, powered by a S28-150 Magmotor, spinning upwards at approximately 3000 RPM, which will hopefully rip off some armour, or more likely, a tire, while lifting an opponent. Jamming a blade into an opponent while lifting it hopefully provides as much control over an opponent than a Behemoth-style grabbing claw/axe can, and it€™ll surely do more damage. (To avoid confusion, the blade is actually part of the lifter, so when the lifter moves up, the blade moves along).
                                On both sides of the bots is a pair of 5 mm titanium skirts, to make sure I won€™t get flipped very often, as hydraulic srimechs just aren€™t as fast as pnuematic ones.
                                Srimech - The lifter self-rights the robot when needed
                                Strenghts - Nice weapon synergy, high traction
                                Weakness - Hydraulic srimech might prove to be slow
                                A picture can be found here: http://jupiter.walagata.com/w/madbull/BacktoRockII.gifhttp://jupiter.walagata.com/w/madbull/BacktoRockII.gif
                                Notes - Proud winner of The Spanish Inquisition QT
