NSBFLX-2
  • NSBFLX-2
    Thats be cool, Shovearound 2 with anyone of my robots.
    • NSBFLX-2
      Can I update PCC with Seggy 4.2?
      • NSBFLX-2
        In answer to Anthony, Alex M & W and Dave:
        Yes.
        • NSBFLX-2
          Okay. Me and Alex have agreed on SUNCUST [stats up] and Flank Attack [Stats for it should be up soon]
          SUNCUST and Judo Chop! Will be replacing Dr. Evil and Terror Gear in football. SUNCUSTs jaws have been modified to do next to nothing except clamp the ball [but not damage it as the spikes have been removed] And Judo Chop!s axes have had the blades removed and now do pretty mcuh nothing except just grab the enemy if they charge for the goal and hopefully prevent the ball from going in.
          Also, you have two of my robots in new blood [Jack Kennedy and Vampire Killer] when you said we were limited to one, so drop Jack Kennedy.
          • NSBFLX-2
            Change of plans: I have Shovearound 2 and Alex has FBSDS [new bot which should be stated soon].
            • NSBFLX-2
              http://farr.proboards21.com/index.cgi?action=display&board=targeted&thread=112 7057591http://farr.proboards21.com/index.cg...d&thread=11270 57591
              FBSDS stats
              • NSBFLX-2
                FBSDS ground clearence is way too low. This is especially bad for spinners as it can quite likely be beached by debris from its opponant.
                • NSBFLX-2
                  Please disregard, I thought I put 8mm or 0.8cm. Either way, its fixed now.
                  • NSBFLX-2
                    While were on that subject you might want to change it for all your other machines as well as they all have the xact same mistake.
                    • NSBFLX-2
                      Oh by the way, Cosmic Thunder has hinged wedges all around making it at 0mm all around. Underneath those wedges the clearence is something like 8mm. So that should be that over.
                      I cant find that mistake for any of my other robots though...
                      • NSBFLX-2
                        I like keeping helpful quotes in case I ever need to refer for information. Heres one that I think Nick once said:
                        People keep going around bragging about 1 mm clearence as if it were a good thing. But its better to be tossed around by high wedges than to get stuck on the smallest pieces of shrapnel. 1 cm or higher is preferred, perhaps less in some areas far from the wheels. ESPECIALLY FOR FULL-BODY SPINNERS.
                        On a different note Im working on some new robots at the moment to put in here, sorry about the delay.
                        • NSBFLX-2
                          Too late to join?
                          • NSBFLX-2
                            Not for the new blood I think
                            • NSBFLX-2
                              You can enter new blood, or something for Get Him.
                              • NSBFLX-2
                                Enterprise
                                Dimensions-95cm length, 80cm width, 40cm height.
                                Weight-100kg
                                Shape-low wedge/sloped rear with Biohazard like side and rear skirts
                                Wheels-4 inner wheels
                                Speed: 22 mph
                                Weapon:A rear-hinged flipper. There is a strip on the bottom of the flipper, allowing the flipper to get under bots with skirts. The flipper is 750psi. There is the option of removing the strip and putting a small titanium plate that extends the flipper out 15cm. It could be used against dangerous spinners. Has two spikes at the back to stop the robot flipping itself over.
                                Motors-2 LEM-COs running at 36v
                                Power-4 x 36v 3600mAh NiCD packs
                                Armour-6mm titanium all around
                                Ground Clearance-0mm front, 0mm around the sides/back with skirts.
                                Turning Circle-0m
                                Strenghts-Powerful flipper, nippy around the arena.
                                Weakness-Flirts with Matilda.
