NSBFLX-2
  • #76
    NSBFLX-2
    You bloody well know it.
    The bad comparisons only serve to elucidate your lack of skill, obviously.
    • #77
      NSBFLX-2
      *shakes fist*
      Ah well, at least Im not thought of by association with the Mauler Dance (Mauler...Aaron...seperated at birth? ) or getting DQed from tournaments :P
      • #78
        NSBFLX-2
        True, and you almost win things, which is better than I can muster.
        • #79
          NSBFLX-2
          Nick, you came 2nd in VFT4, and won the last VFT all stars!
          • #80
            NSBFLX-2
            Also you won the first war of the writers.
            • #81
              NSBFLX-2
              Thats ancient history.
              • #82
                NSBFLX-2
                and you won the Wars of Fury
                • #83
                  NSBFLX-2
                  Silence! It was a joke. Toms won things too.
                  We have a bit of an inner-joke going that only one of my robots has actually won anything.
                  • #84
                    NSBFLX-2
                    If theres space, I would like to Get Psycho Cyan.
                    My robot of choice will be:
                    Dont Worry Dear, Its Only a Robot
                    • #85
                      NSBFLX-2
                      Calm Down Dear (Its just a Robot)
                      Shape - A Logitech cordless mouse shape with Judge Shread style flipper
                      Weapon - Judge Shread style co2 flipper, acts as srimech with added bars to make sure it will self-right. Bars form part of chassis.
                      Drive - 6 wheel drive, on two axles. The front axle has two wheels, the rear axle has double wheels. Powered by a couple of lovely Lems at 36 volts. Tornado style Speed controllers and electrical stuff to provide current of 200 amps
                      Batteries - Nicads.
                      Speed - Built for acceleration this machine, with a 24 mph top speed, with acceleration to match Storm 2.
                      Armour - 4mm Hardox shell, held tight by a titanium framework chassis, with added steel ladder supports. Around the wheels are more support to prevent armour hitting wheels.
                      Skirts - Simple low angled skirts to prevent other robots getting underneath. Angled at 12 degree to the x-axis.
                      Ride Height - At front, with the front plough scoop, we can assume its low, say 0. The sides without skirts is 2 cm to prevent grounding out. The front wedge can be lifted up using a linear actuator for some reason, I aint though about yet.
                      Summary - Its a mouse shaped robot, with flipper, designed to be like storm 2, if it was mouse shaped and had a flipper.
                      Strengths - Go Faster shape, speed, flipper.
                      Weaknesses - Likes Cheese, armour isnt up with the best.
                      • #86
                        NSBFLX-2
                        Wait.., my apologies for the bump, I assume new blood is new blood for NSBFL in paticular or in ANY tourtament on FRA?
                        If any on FRA, replace whoever i entered in new blood [Vampire Killer, I think] with the brand new I knew Jack Kennedy and you sir are no Jack Kennedy...
                        http://farr.proboards21.com/index.cgi?action=display&board=Hitmen&thread=11232 69046http://farr.proboards21.com/index.cg...thread=1123269 046
                        • #87
                          NSBFLX-2
                          New blood is for NSBFL only.
                          ...I really need to sort out the brackets on this again to see how many places are left in what
                          • #88
                            NSBFLX-2
                            if theres any places then ill enter the incredible bulk stats r weapons 2 axes front flipper back spikes and spinning disks
                            speed 15 mph
                            shape square
                            drive motor
                            armour titanium bullet proof and disc proof
                            summary ur average 88kilobot with axes spikes flipper and the killing disc which can shred a whole town in 5 seconds(ok 5 mins)square great manuevrability
                            strengths weapons maneuvrability shape speed armour
                            weaknesses weight easily flipped
                            • #89
                              NSBFLX-2
                              Hehehe, you have a lot to learn. For a start, stop entering tournaments that are already full and started. XD
                              • #90
                                NSBFLX-2
                                OK, assuming Tim isnt an old member having a little joke with us, that robot is so BIIBI I dont even know where to start.
