FRA Royal Robot Rumble: 30 enter, 1 leaves
Ok people, heres the next part of the Rumble:
With the arena as it was and the tracks clear, the fight resumes€¦
3€¦
2€¦
1€¦
ACTIVATE!
Gravity is first on the draw, bobbling towards the deadlocked Razer and M2. Gravity is starting to show the effects of repeated attacks on it. Gravity flips over M2 and Razer, causing the claw to slide out, and allowing M2 to self right, but Razer doesn€™t move! Razer has landed on the broken srimech side! M2 and Gravity back away, allowing Refbot to count it out€¦8€¦9€¦10: OUT! But Refbot€™s counter changes back to the time, and once again hits 0, signalling for robot No. 12 to enter. The door opens and out comes Adam Emmett€™s Mute, the robot with the self righter that€™s all wrong! Gravity goes for Mute, but lurched forward and stopped€¦the wheels has come off and jammed! Mute uses this, wedging fully under the immobile Gravity, and catapulting it 6 feet through the air! Gravity lands next to the immobile Razer, and Refbot comes and counts down the Dutch launch pad. M2, who has been observing all this time, takes a shot at Mute, barely getting under Mute€™s tiny GC, but enough to send the New Blood runner-up onto its back. We all know what follows! Mute throws itself into a 360° somersault, sending it back onto its head! This continues for 4 flips, until M2 gets in its way on the way down, sending it back onto its wheels! Mute gets under M2 and flings it away as Refbot€™s clock hits 0, and in comes the yellow launch-pad, Atomic! Atomic makes a dash for Mute, wedging under it and throwing it into the wall! Mute is on its side, flipper facing the wall, which it fires, sending it spinning on its side and eventually onto its wheels. M2 and Atomic, meanwhile, are having a grudge match from S7, but this time. M2 is on top, flipping and flipping Atomic into an unoccupied CPZ (thank God for that!)! M2 throws Atomic into the corner and against the wall. M2 takes a running shot at him, only to be interrupted by a furious Mute, throwing M2 into the wall as Atomic did to him, whilst the yellow Atomic flips itself off the wall, just as Refbot€™s clock hits 0, summoning robot No. 14 in, the simply swingin€™ Stinger! Wheeling at full tilt, Stinger slams the tail into Mute, only making a tiny mark in the tough armour. With M2 and Atomic both back on track, both of them scoop up Mute and throw it skywards, and coming down, only to be clouted by a spinning Stinger! Mute bolts away to avoid another mob attack, but is quickly followed by all three robots, hungry for robot blood! Mute turns to avoid the pile of wood and dead robots, only to get a face full of Atomic! Mute is launched up and onto the remains of the piano! Mute rolls off, but is once again met by a spinning Stinger, clouting the rear flipper and leaving a large chop mark! Mute is continuously thrown about by all three flippers, as if they were playing ping pong! Mute manages to wheel away from them, just as Refbot€™s clock hits 0, and No. 15 in the rumble shoots out; its Dantomkia, the bi-wedge flipper, named after the kids, nothing kiddie about it! Dantomkia goes straight for Stinger, wedging up one of the wheels and flipping it over, sending the robots spinning like a top! Atomic speeds up behind Dantomkia and fires the flipper, sending Dantomkia crashing into Stinger, shortly followed by Atomic, who is flipped by the silent M2! Dantomkia come to rest on one side of the pit, but Atomic has one wheel over the edge! Stinger spins anti-clockwise and smacks Atomic off the pit side, which he really shouldn€™t have done! Mute, meanwhile, is keeping out of harms way, but Dantomkia, now recovered, brings harm to Mute€™s doorstep, wedging under the front and flinging it over onto its roof. Before its even hit the floor, Mutes flipper opens up and fires the robot to the wall, right side up (phew), and speeds towards Dantomkia, wedging under it and firing it towards the pit, landing the robot upside down, and Mute makes a final charge at the Lambert€™s machine, but Dantomkia fires the self righter, throwing itself over Mute, and Mute, missing Dantomkia, takes a nosedive into the pit! Mute is eliminated! Stinger, meanwhile, is slamming the bludgeoning spike down onto M2€™s flipper, making a large crack down the polycarbonate window on the flipper, but M2 is fighting back, trying desperately to flip Stinger away, but in reality wasting precious CO2. Atomic, safely away from the pit€™s edge, is busying itself with Dantomkia, flipping it over and over, only to have Dantomkia turn around and fling him over himself! Refbot€™s counter hits 0, and the next robot to come through the gates is the mad axe-bot, Terrorhurtz! THz immediately swings into action, slamming the axe into the underbelly of the overturned Atomic, leaving a large slot in the thin armour. Dantomkia takes this chance to take out THz early, wedging under the thick skirts and throwing THz over, but he quickly self rights with a snap of his axe, and proceeds to chase Dantomkia all over the place, swing the axe wildly. Atomic flips itself over, and swivels to face the CPZ, occupied by M2 and Stinger, with M2 still trying to get Stinger out, but still having no effect. Atomic charges in, avoiding the pit as it does so, and slams into M2, launching it over the fence and out of the Rumble! Stinger, still not quite with it, gets scooped up by Atomic and pushed towards the opposite arena wall, firing the axle-bot into the wall, but Stinger simply bounces away, and takes a side swipe at Atomic, making a neat slice in its side panel. THz, meanwhile, has Dantomkia up against the wall, and is pummelling the hell out of it, hoping to knock out the receiver or aerial, But Dantomkia is pushing back with all the motor power it has, sending smoke out from the underside of the robot. Stinger and Atomic, meanwhile, are taking it to each other, Atomic throwing Stinger around and Stinger taking big swipes with the mace, leaving several large dents and gashes in the side plating Atomic forces Stinger in front of the gate, pinning him down with all its got, and, like Dantomkia is, sends dust and smoke from the arena floor, trying to get Stinger far enough up the flipper to fire him over. Refbot€™s counter hits 0, the gate drops, Stinger drops, Atomic jolts forward, and both are met by the monster of the deep, Hydra! Hydra runs right past Atomic, flipping it side wards into the wall, revealing the gash in its underbelly, which Stinger adds to with a swinging attack. Atomic self rights off the wall, and speeds into the arena before the gates shut, and Stinger, realising he may be shut out, does the same, and only just beats the rising gate! Hydra, meanwhile, is slamming down the axe onto THz€™s raised side, making minor dents but nothing more. Dantomkia uses this and gets away from the pummelling THz, who turns and clubs Hydra with the executioners axe, making a big dent in the bodywork! Dantomkia, now free, takes a shot at Atomic, flipping it over with great force. Stinger, who was spinning to fend off Atomic, makes a small dent in the side panel of Dantomkia, but nothing more. Realising that it won€™t do much damage to Dantomkia, it makes a hasty exit, rolling away from Dantomkia, leaving Dantomkia to deal with the now self righted Atomic. Stinger decides to join in with THz in pummelling the living daylights out of Hydra, who is firing its axe and arm everywhere to get free. Stinger slams down the mace again and again, leaving a few impact marks in the titanium armour, but then it starts spinning, knocking THz away and letting Hydra get away! Hydra quickly turns to face the back of Stinger, and it fires the axe right between the axel, and fires the flipper, locking Stinger€™s axle between the two weapons! Hydra backs away with Stinger in its grasp, with THz swinging its axe away in a mad rage. Hydra turns to the pit, and releases both weapon, sending Stinger tumbling on top of Mute, eliminating the Axle-bot! THz, meanwhile, has been letting fly with the axe and finally it slams down on Hydra€™s rear end, making a large chasm in the top. Hydra throws itself into full reverse, pushing itself and THz€™s away from the pit€™s edge, away from danger! The Refbot€™s clock hits 0 again, and the gates drops for robot number 18; it€™s the robo-lobster, Thermidor 2! Thermy instantly gets stuck in with Dantomkia and Atomic, who are both almost out of CO2! Thermidor gets under the yellow Dantomkia and fires it over onto its back leaving Thermy open for an attack by Atomic! Atomic goes under Thermy€™s flipper and...Erm€¦flaps it away? The gas is running out on Atomic, but it already has run out on Dantomkia! Dantomkia isn€™t moving, and the Refbot comes to count it out, only for Hydra to come in and turn him back over! The count stops, and Dantomkia motors away, a lucky escape! Hydra, despite just helping it out, goes after Dantomkia and thwacks Dantomkia with the axe, making nothing more than a tiny hole in the polycarbonate cover. Dantomkia turns and wedges under Hydra, pushing it towards a wall, and firing the flipper€¦which does nothing more than give a little flick on Hydra; he€™s not going out of the arena that easy! Atomic, meanwhile, has attracted the attention of THz, who it now pummelling away on the bulldozer shaped €˜bot, attacking the flipper arms with his axe. But all the roboteers note, the THz hits are getting more and more feeble. The continuous axing of Dantomkia and Hydra has weakened it. Thermy, meanwhile, is seeking out a target, who to choose€¦he chooses Dantomkia, speeding towards it, wedging it up and firing it over the fence, sending Hydra flat into the wall as it goes! Thermy goes for the double, but Hydra quickly flips itself off the wall and speeds away to avoid the incoming lobster. Refbot€™s clock hits 0, and the gate drops down, revealing the new UK champion, Typhoon 2! The S7 champ is already up to full rev and everyone knows that it means you must keep away! However, THz doesn€™t know about this, and gets its rear end armour torn away by the FBS. This sends THz recoiling and Atomic becomes free again. Atomic turns to face the spinning Typhoon, and chases it towards the arena wall. Atomic gets just under, flipping Typhoon into the wall, getting its flipper blade ripped off in the process, and the flip, despite not having much power, throws Typhoon into the wall, which shatters upon impact!
CEASE!
Typhoon is told to turn off their body spinner and to back away, as the tech crew once again come in to make repairs. The robots are told to stay put until the next ACTIVATE is called. To Be Continued€¦
3€¦
2€¦
1€¦
ACTIVATE!
CEASE!
