FRA Royal Robot Rumble: 30 enter, 1 leaves
Thats it, Rev II will have to enter, Ive got to show half the newbies how to build a robot with proper parts! Its noob busting time!
Motivation: Wheels
Speed: 8MPH (Translational speed)
Weight: 109.9kg
Height: 170mm
Length: 1000mm
Width: 1000mm
Weapon: The weapon is just the same as Revolutionary, but this time, it has the legendary and nearly outlawed Gas Turbine implemented. To fit the 19kg 65HP 20000rpm Gas Turbine into the weight limit, the design went through a large weight loss design switching from Aluminium Boron Carbide which is light and strong to a heavier Hardox 400 which is stronger, and used less over the whole robot. 3 large portions have been removed and are air gaps to save weight. The total weight of the drive in the last version of Revolutionary was close to 45kg (32kg in motors, plus the rest in gears and wheels) The new version has a 42kg drive set up with over 20kg into the titanium mod 3 gears for the twin stage planetary gearbox which is then into a single stage bevel gear box. This is then transmitted to the drive wheels via magnetic clutches/brake which control the speed of the robots wheels to enable it to translate around the arena like the previous version. The whole robot revolves around at 2000rpm and produces easily over 120 kilojoules. Spin up time is limited to 2 seconds as the magnetic clutches are eased on to save the gearing from over torque as the turbine opens up to full power start up.
Armour/Chassis: 5mm & 10mm Hardox 400 ware-plating
Notes: Will easily attract the Anti-Turbine enthusiasts, invertible, first ever petrol powered translational spinner! Extra 10kg is in the fuel canisters. It should easily run for 20mins since its carring around over 400L of compressed oxy-acetylene fuel
ITs got a bit more armour around the canisters too(not like anything would go through 10mm Hardox)
Lets kick bot!
Motivation: Wheels
Weight: 109.9kg
Height: 170mm
Length: 1000mm
Width: 1000mm
ITs got a bit more armour around the canisters too(not like anything would go through 10mm Hardox) Lets kick bot!
