Re: The Crash & Burn Tournament 4
A second Heat Final? Who would've thought I'd get this far? Certainly not you folks, though that's partially my fault. :P The 3rd seed's come through with flying colours, only to face the terror that is Ringwraith. The winner? It's coming to you now!
*in the pits*
Melissa: I must say, that's quite the hat you're wearing there.
Paul: Why thank you.
Melissa: Do you fear that drum?
Paul: A little bit, since I can't flip him properly, but I'll do the best I can. I came 3rd for a reason, yes?
Melissa: 4th, actually, but Shane Swan isn't taking part this time.
Paul: Well...yes...er...4th is still high, isn't it?
Melissa: Um, quite. Good luck to you. And...let's go over to...the Velociraptor table! Ah Richard, how's the repairing going?
Richard: We dislodged the killswitch a bit during last battle, so it's getting secured back on.
Melissa: All right, and are you scared about facing the 3rd seed?
Richard: Not especially. He's just another robot, which still is tough, but we'll give it a go and see what happens.
Melissa: Good! To the arena!
Heat B Final
Nitro-Gene 5.0 (3) vs. Ringwraith
Roboteers, stand by...
House robots: Rorschach and Asterix Anarchius
3...
2...
1...
ACTIVATE!
Activate indeed; both competitors have done just that as Nitro-Gene blasts out of his spot towards Ringwraith, who's getting its spinning body up to maximum killing potential. Unfortunately for him, it's not fast enough for Nitro-Gene, who comes straight in on the attack, and manages to avoid the drum by nailing one of the wheels with the flipper! Unfortunately for HIM, that turns the Duralumin drum right into the front of Paul's flipperbot, resulting in...
CRASH!!!
...a massive collision! And it's thrown Nitro-Gene right over onto his back amid them pretty sparks!
The 3rd seed tries to move away to self-right quicker, but he's having a hard time doing that! Obviously the inverted ground clearance isn't agreeing with his wheels! Revelling in this newfound discovery, Ringwraith sits nearby, waiting for Nitro-Gene to right itself, Richard having spun up the drum again and seemingly concocting up a plan. Paul tries to get Nitro-Gene away, but try as he might, he's not going anywhere! So, with no other alternative, Paul has to activate the flipper, which sends Nitro-Gene into the air in a 540...but directly on top of Ringwraith! ...HA! Would you look at that! Nitro-Gene is stuck on Ringwraith's tire! And it can't get off! Ringwraith tries to move, but it can only turn in an arc; the pressure Nitro-Gene is exerting on that tire is a bit too much and Ringwraith can't move it! Ringwraith now tries to move in an arc to swing the drum in and attack the underbelly...but no such luck! The two robots are stuck and any moment now...bump. The Watcher moves in and nudges Nitro-Gene...sadly, that's hardly done anything as he went into the rear of Nitro-Gene, which was still on the ground. It has, however, given Ringwraith the opportunity he needs to bring the drum in closer, and...it's smacking the left side skirt repeatedly! And there it goes! A few successive hits on the skirt and it's 25 feet removed from its owner, near an angle grinder at the other end of the arena...Asterix jumps upon it!
Now, now, even then you shouldn't leave your CPZ.
Meanwhile, The Watcher is still trying to separate the two, as Ringwraith can't bring the drum further into play and the referee decides, finally, to move to the right side of Nitro-Gene and begin pushing...and thanks to the absence of the left skirt, Nitro-Gene's now stuck on BOTH wheels...seems the 'Gene's maximum length is larger than Ringwraith's wheelbase. The Watcher continues pushing...and unwittingly sticks his arm underneath Nitro-Gene and lifts him up overtop of Ringwraith. That's not a wise move, seeing as the drum on Ringwraith hasn't stopped!
CRASH!!!
A second later and the Watcher finds himself with a bent lifting arm! It's your fault, you bloody fool, you stuck it where the sun don't shine!
But now the competitors are separated at last. Nitro-Gene, not turning to get the flipper in play, uses the rear end to push Ringwraith, who's trying to spin up his drum, across the arena. The rear skirt is hit, and is quite bent, but it stops the drum and Nitro-Gene continues pushing the axlebot into an empty CPZ. He then turns to try and flip Ringwraith OOTA but Ringwraith drives straight into him and tries to go all-terrain on his arse!
Note to Ringwraith; you can't ride onto a bot using a flat side.
...well, bugger what I just said, he's just done it. Ringwraith drives right overtop of Nitro-Gene and spins around, spinning the drum towards its lethal RPM value. Nitro-Gene again rams, using its rear end, but Ringwraith backs off this time; a pursuit ensues, abruptly ended when Ringwraith stops and Nitro-Gene smashes into him!
CRASH!
And there goes the rear skirt! More sacrificial than anything, however, as Nitro-Gene takes the hit easily and pushes Ringwraith back towards...Rorschach's CPZ! The Watchman actually backs away in an arc to let Nitro-Gene smack Ringwraith into the wall and drive to the edge of the CPZ, then Rorschach forces Ringwraith against the corner and brings the beak down...well, it's not doing much to the Duralumin, really, but Nitro-Gene's gone off and hit the pit release button; the house robot, however, ignores the opened pit and tries hard to crush the drum but he's not making much headway into the task and soon after is forced to let go and let Ringwraith get away...but Nitro-Gene is right there! And with an almighty SLAM he smacks into Ringwraith, the force itself vaulting Ringwraith into the air...but thankfully the drumbot is still in the arena. Nitro-Gene has him pinned though, and...there's the flip! WHAT?! NO! Ringwraith is rocketed into the air, but OVER Nitro-Gene and landing right behind him, and getting the drum spinning again! Oh dear! What a stroke of black magic that was! And now the wraith backs off, allowing the thunderstuck Nitro-Gene to turn around and simply face him, unaware that Rorschach is trying to eject him from the CPZ. Then he charges. The flipping arm is the first thing to come into contact with Ringwraith's drum.
CRASH!!!
And thankfully it isn't too damaged, but Nitro-Gene's sent up a bit and that's allowed Ringwraith to spin up a bit more! The 3rd seed is in trouble here, but isn't out of the fight by a long shot and rams Ringwraith again...or tries to, but Ringwraith moves to the right and spins, effectively bypassing the charge and giving the flipperbot a hefty whack on the explosed left side!
CRASH!!!
Amazingly, it flips Nitro-Gene right onto his back! The side in question also has a nasty scar down the center, but Nitro-Gene activates the arm, unable to move on its back, and lands...upside-down again! The full 360 isn't quite what Paul wanted here and that leaves his poor robot exposed to another shot from Ringwraith, which Richard takes with obvious glee.
CRASH!!!
The rear takes a shot this time, Richard taking careful aim so as not to re-right Nitro-Gene, and the angled rear, deprives of its skirted protection, finds itself mangled directly on the edge! Paul doesn't want to self-right directly next to Ringwraith but he has no choice, and so flips himself off the ground again...once again landing himself into a 360, more graceful than before but still in a rotten position, and Ringwraith keeps bringing the punishment! He moves around Nitro-Gene and attacks the flipper, just as Nitro-Gene decides to flip itself again!
CRASH!
Oh...my. The self-right + hit sends Nitro-Gene, again, into a 360, from which it lands again onto its back. Ringwraith's drum hasn't stopped much during the hit and he brings it in again before the 3rd seed can even think of self-righting again!
CRASH!!!
That was a very powerful blow...so powerful, unfortunately, that it righted Nitro-Gene! And the said Nitro-Gene uses its mangled rear to back into Ringwraith and shove towards one of the Discs of Death! Oh my! Oh...no. Ringwraith's huge tires are proving very helpful here, as it is able to break the push and send Nitro-Gene flying almost into the Disc of Death itself. Paul, realizing his mistake, tries to make up for it by aggressively shooting across the arena to where Ringwraith is spinning, and just manages to catch Ringwraith before it can turn in another direction. The problem? It hit Ringwraith's tire again, which turns Ringwraith into Nitro-Gene's right side!
CRASH!!
The right side skirt, the remaining one, gets bent up, and doesn't fold back down like it should, but once again it's stalled Ringwraith's greatly feared spinning drum and Nitro-Gene is able to face and push into him before the axlebot can react. And this time, Ringwraith can't break the charge! They're heading for the wall! It's a...flop. A very disappointing performance here as Nitro-Gene flicks Ringwraith not over the fence, but straight into the wall; the latter bounces off and starts spinning again. Nitro-Gene desperately turns and moves in to ram Ringwraith, but Ringwraith's able to turn a bit to smack Nitro-Gene's right corner on an angle.
CRASH!!!
The resulting hit, once again, upends Nitro-Gene, who self-rights immediately, the 360 long forgotten as the flipper has lost enough power to right its host properly. Not that Nitro-Gene is complaning, as he rams into Ringwraith once more, and this time he stops the drum without taking any damage; quickly, he tries to turn to push Ringwraith towards the pit, but Richard isn't having any of it and as Nitro-Gene turns, Ringwraith whirls the opposite direction, leaving him at the side of Nitro-Gene. Of course, that doesn't help much since the drum isn't spinning, but it's saved him from the pit...and Paul's frustration is mounting as he tries to get some kind of attack going here. He again manages to stop the drum before it gets up to a high speed and pushes Ringwraith, but the slippery axlebot again pulls out of the charge and begins spinning again. Richard is smirking now, playing a very clever game, while Paul seems to be on the verge of erupting, as the box attempts to assault the drumbot, but can't as the drumbot pulls away. It seems monotonous, as Nitro-Gene charges, but Ringwraith, despite having his weaponry stopped, parries the thrust (en garde!
) and moves away to try and spin up again. However, this is earning Nitro-Gene big aggression points, but will it be enough? The clock is ticking down and Ringwraith sees the time for a bit more action...
10...9...8...7...
The drum fully spun, now, Ringwraith moves in, but Nitro-Gene is right there and throws himself into it...
CRASH!!!
Both robots are thrown skyward as Nitro-Gene activates the flipper on contact; Ringwraith soars into an empty CPZ but exits it quickly' Nitro-Gene lands on its back.
6...5...4...
Ringwraith drives straight towards Nitro-Gene, who tries to self-right, and just manages to do so, revealing a very bent-up flipping arm!
3...2...1...
Nitro-Gene throws caution to the wind and slams into the oncoming Ringwraith, who's unable to get out of the way this time, and takes it to the wall for one hefty slam and flip...
CEASE!
AND OH NO! Ringwraith's out of the arena, too little too late though! Or maybe not! Let's see the decision, judges!
Nitro-Gene 5.0 - Ringwraith
Strategy = 1/5 - 4/5
Style = 6/10 - 4/10
Control = 4/15 - 11/15
Aggression = 12/20 - 8/20
Damage = 1/25 - 24/25
TOTAL = 24/75 - 51/75
The bronze medal is taken back right quick, as Nitro-Gene is just full of hot air!
Ringwraith advances to the Series Semi-Finals!
Next time on C&B4
Killotine: EVO defends his 5th seeding against STAT!
Mobile Failure locks its axe with Y5's spinning blades!
And the first Lightweight Melee greets us: Sergeant Slaughter vs. Backlash vs. Ziggo vs. Gamma Raptor!
*in the pits*
Heat B Final
3...
2...
1...
ACTIVATE!
CRASH!!!
Meanwhile, The Watcher is still trying to separate the two, as Ringwraith can't bring the drum further into play and the referee decides, finally, to move to the right side of Nitro-Gene and begin pushing...and thanks to the absence of the left skirt, Nitro-Gene's now stuck on BOTH wheels...seems the 'Gene's maximum length is larger than Ringwraith's wheelbase. The Watcher continues pushing...and unwittingly sticks his arm underneath Nitro-Gene and lifts him up overtop of Ringwraith. That's not a wise move, seeing as the drum on Ringwraith hasn't stopped!CRASH!!!
Note to Ringwraith; you can't ride onto a bot using a flat side. CRASH!
CRASH!!!
CRASH!!!
CRASH!!!
CRASH!
CRASH!!!
CRASH!!
CRASH!!!
) and moves away to try and spin up again. However, this is earning Nitro-Gene big aggression points, but will it be enough? The clock is ticking down and Ringwraith sees the time for a bit more action...10...9...8...7...
CRASH!!!
6...5...4...
3...2...1...
CEASE!
Style = 6/10 - 4/10
Next time on C&B4
