Challenge Belt
  • Challenge Belt
    Nitro-Gene is going to have another go. See you in the ring Martijn. My plan is to get under him and flip him all day long. If hes dominating the battle, go for an OOTA.
    He might have trouble getting under my skirts, so I feel fine - hes got no skirts which gives me a big advantage over him.
    And I think I have the power, as hes trying to get 35hp (???) onto the floor, but is spreading it out onto 6 wheels, which means only half of it is getting down, so he has 17.5hp. I have 36hp coming from 4 motors onto 4 wheels, one motor per wheel, so thats good. Just get under and push/flip him all day long. Try and stick him in a CPZ and hope the house robots do some damage.
    Good luck Martijn :wink:
    • Challenge Belt
      Ill take on the winner with:
      Name: Lethal Injection
      Shape: Stinger, but with static prongs between the wheels.
      Colour: Unpainted.
      Weight: 100kgs
      Dimensions: L:55cm W:60cm H:45cm
      Speed: 18mph
      Turning Circle: 0cm
      Armour: 9mm titanium on the wheels, 5mm Hardox for the prongs and disc.
      Ground Clearance: Ermm.. Being a stinger style axlebot, it doesnt really have one. The prongs are 0mm however.
      Movement: 2 stinger style wheels with Vulkanon rubber tyres, with 2 LEM130s and 4 NiCad battlepacks at 24volts.
      Weapons: Spinning disc positioned in between the prongs. The idea is that the opponent will be wedged on the prongs then caught by the disc. The disc is powered by a LEM130 at 2000rpm and deals about 60kj.
      Scrimech: Invertible
      • Challenge Belt
        Flick of the Wrist v Nitro-Gene 4.0
        Another of Pauls creations returns to the arena in an attempt to reclaim the belt!Nitro-Gene is very experienced in this competition, lets take a look at how its done in the past...
        1)Flipped No Objections OOTA to take the belt
        2)Beat Cyrilium on a JD to retain the belt
        3)Lost the belt to Crimson Thunder when it was pitted.
        4)Returned to challenge Nidhogg, but lost...
        Watching from the CPZs we have the boxer, Cassius Chrome, and the forever deadly Sir Killalot!
        Flick of the Wrist is defending the belt today, and Matrijns robot has a few tricks up its sleeve- Its a six wheel drive and has some pretty deadly diamond-tipped lifting spikes!
        Nitro-Gene has the more power, and a 1000 psi nitrogen flipper to boot!There are 2x3kg bottles inside Nitro-Gene, so it can get a decent 25 flips per battle!
        Booth 1:Martijn M Benschop
        Booth 2:Paul Cuomo
        3,2,1,ACTIVATE!
        Nitro-Gene gets off to a fast start, running in on the attack to try and get Flick of the Wrist OOTA!But Martijn isnt a fool and dodges away, before turning around and ramming Nitro-Gene from the side, using its spikes in the middle position as ramming spikes!It hits Paul hard into the angle grinder, and the sparks fly off Nitro-Gene!Flick of the Wrist then lifts Nitro-Gene, as it was stuck against the wall the spikes could lift by getting stuck on the side and now Martijn pins Nitro-Gene onto the wall! Flick of the Wrist just reverses slightly to let Nitro-Gene fall onto its spikes and then lifts again before carrying Paul over to the pit release tyre! Carefully Martijn manouvers towards the chasm, dropping Nitro-Gene 4.0 into the darkness Panic Attack-Style!
        CEASE!
        Nitro-Gene never got a chance, Flick of the Wrist retains the challenge belt!
        • Challenge Belt
          Flick of the Wrist v Lethal Injection
          Flick of the Wrists third battle...If Martijn wins this he keps the second belt forever.
          Representing the house robot team-Mr. Pyscho and Sgt.Bash!
          Flick of the Wrist has already defeated Supreme Glory Omega and Nitro-Gene 4.0, both of which were pretty one-sided fights, it must be said!
          So here is its third and possibly final battle in the 2nd challenge belt!
          Lethal Injections looks good to me- its a stinger-shaped robot, but with static prongs and a spinning disc instead of a bludgeon.Lets see how effective this original weapon setup will be, and if Lethal Injections bark is louder or much quieter than its bite...
          Booth 2anny Bailey
          3,2,1,ACTIVATE!
          Lethal Injection heads across the arena, speeding up that disc, ready to cause some damage!But Flick of the Wrist is having none of it and speeds straight into them, stopping the disc in its tracks!Flick of the Wrist continues its attack, managing to get its forks around the middle axle of Lethal Injection and lifting it up!It toasts Danny on the flame pit before depositing Lethal Injection into the CPZ!Sgt Bash gets his clal around one of the prongs and squeezes it!
          SNAP!
          The prong falls away, detaching Lethal Injection from Sgt Bash!Quickly as he can Danny scurries away, only to meet Flick of the Wrist, which pushes him straight into an angle grinder!
          CRASH!
          Lethal Injection bounces off the angle grinder and finally gets that disc up to speed, swinging it round in a large circle onto Flick of the Wrists rear end!However, the disc does little but chip the titanium and Flick of the Wrist gets under Lethal Injection again, this time ramming it into the pit release tyre!But Martijn cant get the forks around the middle axle again and so cant get a hold on Lethal Injection to put it in the pit.But he manages to lift one of the wheels and tip Lethal Injection onto its side!The wheel spins and Lethal Injection wobbles madly, finall y coming down to earth with a crunch!In the dying seconds of the fight Flick of the Wrist manages to get in underneath Lethal Injectoin and tries to pit it, which it does, but Martijn pits himself at exactly the same time!
          CEASE!
          Both robots went into the pit at the same time, meaning the fight will go to a judges decision!
          Flick of the Wrist: Lethal Injection:
          Damage- 2/5 1/5
          Aggression- 4/5 2/5
          Style- 3/5 4/5
          Control- 2/5 3/5
          Overall- 11/20 10/20
          A single point separates the robots, but all the same Flick of the Wrist becomes the permanent holder of the second challenge belt!
          • Challenge Belt
            I paln to do something a bit different for the third and final belt of this years challenge belt, so dont post any challenges yet.Watch this space...
            • Challenge Belt
              So-this is whats going to happen in the third belt:
              Obviously Flick of the Wrist will start with the belt, but before you can challenge it youll have to go through a mini competition first!
              I need 3 people to enter 2 vapourbots each, therell be 2 three-way melees with 2 robots advancing, then 2 one-on-one semi-finals and one one-on-one final to find out wholl challenge Flick of the Wrist...
              • Challenge Belt
                Im honoured
                I take it I cant enter?
                • Challenge Belt
                  MeCannibal and WORCK want retries to grab a chance to fight for the belt.
                  • Challenge Belt
                    Sithis and Crimson Thunder will also have a go.
                    • Challenge Belt
                      Yes Martijn, dont enter the mini tournament as the winner will get to challenge Flick of the Wrist.
                      Also,Paul and Danny I accept your entries and look forward to your fights!
                      • Challenge Belt
                        ONE MORE PERSON????
                        Ill calm down now
                        • Challenge Belt
                          SGO will have another go.
                          • Challenge Belt
                            Daniel, either enter two robots or get somebody else to enter another one
                            • Challenge Belt
                              Oh, I will enter my new cluster as well then. =)
                              Name: Weapon Synergy (5-WAY CLUSTERBOT!!! )
                              Weight: 100kg (Each part weighs 20kg)
                              Armour: 3mm Titanium with 4mm Polycarbonate panelling.
                              Power: Each part is powered by 2 x S28-150 MagMotors running at 24v, giving each part 6HP of pushability.
                              Speed: Each part travels at 12mph.
                              Strengths: Ability to work as a group. Variable weaponry, albeit at a low level.
                              Weaknesses: Weak armoury and lightweight.
                              Part 1: Axe
                              Shape: Tornado Box
                              Weapon 1: Axe powered by lightweight pneumatics running at 1000psi. The axe is double-headed and has a spike at one end and a blunt mass at the other end.
                              Ground Clearance: 1cm all around.
                              Srimech: Axe self rights.
                              Part 2 : Flip
                              Shape: Wedge with sloped sides.
                              Weapon 1: Flipper powered by lightweight pneumatics running at 1000psi. Contains 2kg of liquid CO2.
                              Ground Clearance: 0mm at front. 1cm at sides and rear.
                              Srimech: Flipper.
                              Part 3: Disc
                              Weapon 1: Vertical spinning disc weighing 5kg on the back of the robot, powered by a S28-150 MagMotor running at 24v and geared down 4:1.
                              Ground Clearance: 0mm at front, 1cm sides and rear.
                              Srimech: Invertible.
                              Part 4 : Ram
                              Shape: Tornado Box
                              Weapon 1: Assorted ramming spikes at the front of the robot.
                              Part 5: Claw
                              Shape: TAN shaped
                              Weapon 1: Pneumatic claws which grab the opponents. Running at 1000psi.
                              Ground Clearance: 4mm at front, 1cm at sides and rear.
                              • Challenge Belt
                                Challenge Belts 1&2- summary:
                                Tornado lost to No Objections
                                No Objections beat Cyrilum
                                No Objections was flipped OOTA by Nitro-Gene 4.0
                                Nitro-Gene 4.0 beat Cyrilium
                                Nitro-Gene 4.0 was pitted by Crimson Thunder
                                Crimson Thunder was ripped up by MeCannibal 2.0
                                MeCannibal 2.0 was crushed by Nidhogg
                                Nidhogg crushed Tri-Tainium
                                Nidhogg crushed Sithis
                                Nidhogg won the first belt!
                                Nidhogg beat Nitro-Gene 4.0
                                Nidhogg was flipped OOTA by Worck
                                Worck was beaten by Supreme Glory Omega
                                Supreme Glory Omega defeated MeCannibal 2.0
                                Supreme Glory Omega lost to Flick of the Wrist
                                Flick of the Wrist beat Nitro-Gene 4.0
                                Flick of the Wrist beat Lethal Injection
                                Flick of the Wrist keeps the second belt forever!
                                What will happen in the battles for the third belt?}
