Challenge Belt
  • Challenge Belt
    Nidhogg v Worck
    Yet another Joey v Paul match!So far Joeys Nidhogg is undefeated, but Pauls Worck is thus far unseen in this competition!
    Looking on from the corners of the vast arena are Sir Killalot and Matilda!
    Worck is a low edge with a front-hinged flipper capable of putting Nidhogg OOTA!Also Joey is going to have his work cut out trying to get under Worck to use his crusher as it has wedges all the way around!
    Booth 1:Paul Cuomo
    Booth 2:Joey McConnell
    3,2,1,ACTIVATE!
    Worck comes straight in on the attack, but doesnt dare face Nidhogg straight on, instead choosing to steer and try a side attack!
    Nidhogg turns to meet it though and the two robots meet face to face!Neither can get under the other, but Joey manages to wedge those forks into the front of Worck and lifts it off the ground!Worck still has its rear wheels on the floor, however, and wont be pushed around.Eventually refbot comes in to separate the two combatants, therefore resuming the fight.
    Worck reverses away and tries to get around the side again, this time Nidhogg turns too slowly and Worck slides underneath the rear end, flipping it over!Before Nidhogg can self-right Worck pushes it into the angle grinder and flips it again, this time rolling it onto its side!Nidhogg self-rights but finds itself back on top of Worcks flipper!The next thing Joey knows Nidhogg has been flipped again, and falls head-over-heels over the side wall!
    CEASE!
    As Worck does a victory spin Joey commiserates by gallantly applauding his opponent.
    Nidhogg finally falls (literally!) !
    Worck is the new holder of the challenge belt!
    • Challenge Belt
      WOOT! First and win for WORCK, and first loss for Nidhogg. Unlucky Joey, but well done for getting the first belt.
      • Challenge Belt
        Two more battles and the 2nd belt will belong to Worck.But first it needs challengers!
        Come on people-if you want that belt, come and have a try!
        • Challenge Belt
          Ill challenge WORCK.
          Name: Supreme Glory Omega
          Weight: 100kg
          Armour: 20mm Lexan and LexiGuard compound and 4mm Grade 5 Titanium skirts.
          Speed: 18mph, running of 2 x S28-400 MagMotors running at 24v.
          Shape: Box shaped with Ti skirts on each side.
          Weapon 1: An 11kg Aluminium alloy axe powered by liquid Nitrogen running at 1000psi. The axe mechanism is a rack and pinion system, using a 100mm stroke, 80mm bore pneumatic cylinder.
          Strengths: Strong armour and very manoeuvrable.
          Weaknesses: Axe only works if something is in front or behind the robot.
          Ground Clearance: 0mm all around due to skirts.
          Srimech: The axe self rights the robot.
          Notes: The 2 wheels are made from Ti/V alloy and coated in Vulcalore to aid in traction. The robot is covered in 20mm Lexan and LexiGuard compound. The axe weighs a total of 11kg and is shaped like Excaliburs axe from series 3 of Robot Wars. This shape is designed to focus all the force on a single point, meaning it can pierce through armour easily. To stop the robot hopping around when the axe is fired, the robot incorporates a vacuum system. This system basically sucks SG0 to the ground and is mainly used when fighting pushers or robots with superior pushing power. This mechanism can be knocked on and off during the match. The robot carries 4kg of liquid Nitrogen on board and has roughly 35 hits per fight. The axe can come down with roughly 2 tonnes of force at the tip, meaning that the axe could knock certain opponents out in one hit.
          • Challenge Belt
            Worck v Supreme Glory Omega
            Worcks first challenger steps out into the open...Iiiiiiiitttts Supreme Glory Omega!
            Its got one hell of an axe, so watch out Paul!
            The house robots that oversee this battle will be made of hot stuff- in the case of the first one, literally!Its Sergeant Bash!And following him into the arena will be the one and only shunt!
            Paul recently defeated the previously unbeaten Nidhogg to take the belt, so hes not going to let go without a fight to the death!Worck is a low wedge with a front hinged flipper, it got Nidhogg OOTA so watch out Super Glory Omega!
            Speaking of which, Danny isnt at all defenceless! Super Glory Omega packs an extremely powerful punch with that nitrogen powered axe, plus its got skirts all around so getting underneath isnt going to be at all easy for Worck.Could this be a telling factor?
            Booth 1:Paul Cuomo
            Booth 2anny
            3,2,1,ACTIVATE!
            Super Glory immediately shows its thirst for blood as it races towards Worck, which goes full on to meet it!
            CRASH!
            Super Glory brings its axe down at precisely the right moment and puts a nice round hole in the middle of Worcks flipper!This is good stuff early on and Super Glory doesnt stop there, dragging Worck onto the flame pit!
            After letting Paul feel the heat Super Glory digs its axe out and Worck, relishing its new found freedom runs away and presses the pit rlease button.Super Glory isnt bothered and strolls up to meet Worck, sticking its axe into the bodywork this time!Super Glory pushes Worck up against the arena wall and withdraws its axe before striking again without a second thought!
            This hit goes through the flipper arm and suddenly Worck is letting off gas!The axe of Super Glory has punctured one of the Co2 canisters and Paul isnt looking too happy about that!
            Nevertheless Worck drives away and turns around before swerving around to meet the approaching Super Glory Omega!
            CRASH!
            They slam into each other, and this time Super Glory misses with its axe!This gives Worck an opportunity and Paul takes it, taking the chance of one of the skirts being pushed up by a Co2 jet to slip in underneath Super Glory and turn it over!Danny quickly self-rights and attacks with its axe again, giving Worck another hole to think about- in the other Co2 canister!Worck is now weaponless and Super Glory pushes it into the CPZ just to prove a point.
            SLAM!
            Shunts diamond edged axe pierces Worcks armour again.
            CEASE!
            After that intense battle both robots are still mobile, so a judges decision is called for!
            Worck: Super Glory Omega:
            Damage- 1/5 4/5
            Aggression- 2/5 5/5
            Style- 3/5 3/5
            Control- 5/5 4/5
            Overall- 11/20 16/20
            Worck loses the belt, while Danny puts it on and walks away cackling!
            Super Glory Omega is now the one to beat!
            • Challenge Belt
              Does anyone dare challenge Super Glory Omega?
              Come and have a go if you think your hard enough!
              • Challenge Belt
                Hang on - my oponnent is made of Polycarbonate - and that is known for being vulnerable to a weapon - spinners.
                MeCannibal wants a go, and hell just tear Supreme Glory Omega into Supreme Glory ??? (What comes after Omega) I know he will not stop me spinning up, as hes way too slow, and my acceleration and traction should allow me to dodge his axe, and rip him up.
                Good luck Danny :wink:
                One question though, pardon me for being crocuhy, but how did Shunt pierce my armour so easily - hed struggle with 5mm Titanium, but 5mm Hardox, hell pierce it no trouble. Just curious :wink:
                (Message edited by paulc on March 21, 200
                • Challenge Belt
                  A destroyed MeCannibal. Thats what comes after Omega.
                  Tactics: Stay near the arena walls and hope that he accidently drives into them, slowing the spinner down and allowing me to bring the axe into play.
                  • Challenge Belt
                    Dont worry - Im coming after you alright
                    • Challenge Belt
                      ok Liam, Im convinced you are a serious writer and an improving one on that, Ill step in line behind MeCannibal and enter...
                      FLICK OF THE WRIST!
                      http://strickenone.proboards99.com/index.cgi?board=thvapours&action=display&thread=61http://strickenone.proboards99.com/i...n=display&thre ad=61
                      • Challenge Belt
                        Rightey ho!
                        MeCannibal returns to challenge Supreme Glory Omega, the winner to take on Flick of the Wrist!
                        Supreme Glory Omega v MeCannibal 2.0
                        Lets take a look back at MeCannibals previous battles in the challenge belt...
                        1)It completely destroyed Crimson Thunder to take the belt
                        2)But lost to Nidhogg in an intensely close match as one of its shuffle pads took severe damage and stopped working
                        Looking down upon this match made in hell will be the dreadful grabbing arms of Dead Metal and the hammer of havoc, Mr.Pycho...
                        This will be the first time in the challenge belt competition that a spinner (in this case, MeCannibal) has come up against an axe (Supreme Glory Omega), so lets get ready for this exciting line-up to get underway!
                        Booth 1:Paul Cuomo
                        Booth 2aniel
                        3,2,1,ACTIVATE!
                        MeCannibal immediately gets that deadly weapon up to speed and shuffles towards Supreme Glory to try and bring it into play.Closer...closer...
                        Supreme Glory stays by the arena wall as still as a statue until MeCannibal is just millimeters away, reversing out of trouble!But Paul was expecting the move and doesnt hit the wall as Daniel planned, instead continuing its pursuit of Supreme Glory Omega.Supreme Glory tries again, this time trying to get MeCannibal into the CPZ.But this time he isnt fast enough in making his escape!
                        CRASH!
                        The front panel is torn off as MeCannibal goes in and Supreme Glory spins away!But part of Daniels plan has worked- although managing to hit Supreme Glory, MeCannibal has driven into Dead Metals CPZ! The house robot grabs hold with his claws and moves in with its circular saw, while Supreme Glory creeps up and uses its axe!
                        SLAM!
                        Daniel hits MeCannibal right where it hurts- in the shufflepad of course! Dead Metal lets go, but MeCannibal cant escape as its now moving on one pad only!It spins up, but the length of Supreme Glorys axe allows it to hit MeCannibals bodywork without having to make contact with the spinner ring.
                        SLAM!
                        Daniel brings the axe down again, this time catching the edge of the spinner.Supreme Glory pulls MeCannibal across the arena and onto the pit.Then all Daniel does is stroll to the pit release tyre and watch MeCAnnibal sink slowly out of sight!
                        CEASE!
                        MeCannibal is swallowed up by the pit and Supreme Glory Omega gets the glory of holding onto the belt!
                        • Challenge Belt
                          Liam can i give you a small bit of advice, if you leave a one line gap between after saying who is fighitng and between the intros for each robot and the start of the fight, it will look better and be easier to read. Other than that your fights are pretty ok.
                          • Challenge Belt
                            Yay!!
                            • Challenge Belt
                              Supreme Glory Omega v Flick of the Wrist
                              Martijn makes his debut in the challenge belt competition with Flick of the Wrist, a powerful rambot with lifting spikes that can run both ways up!
                              Looking on from the CPZs we have Growler, the helldog thats come out of its hell-kennel to partner Matilda, whos ready to let robot fly with that devastating spinner!
                              Supreme Glory Omega came out of nowhere to take the belt from Worck, and has already made a successful defence of the belt by incapacitating MeCannibal 2.0.
                              Flick of the Wrist has six wheels, 7mm thick titanium armour and some pretty good lifting spikes, so Supreme Glory Omega is going to have a tough battle ahead of it if Daniel wants that belt for good- as it his third battle, a victory from Supreme Glory Omega today would mean it is the permanent holder of the second belt!No pressure then, Daniel!
                              Booth 1aniel
                              Booth 2:Martijn M Benschop
                              3,2,1,ACTIVATE!
                              Flick of the Wrist is faster off the mark, heading across the arena at a decent speed, unlike its opponent which just edges forward cautiously. Just as Flick of the Wrist gets within axe range Martijn pulls it around and pushes Supreme Glory from the side, lifting it just as the axe crashes down uselessly, a second too late...
                              But Martijn couldnt be in a better position and rams Supreme Glory into the arena wall, propelling it sideways through the air to land in Matildas CPZ!She isnt best pleased, and wallops him with the flywheel, ripping off the side skirts and the axe head!When Supreme Glory Omega lands Flick of the Wrist is ready and rams it again, letting it slam into the angle grinder before lifting it once more, before dragging it Panic Attack style onto the flame pit!Supreme Glory fires the remnants of the axe helplessly, but to no avail as Flick of the Wrist pushes it back into the CPZ again!
                              CRASH!
                              Matildas bum collides with Supreme Glory again, ripping off a side panel and sending it cartwheeling off across the arena floor!It tries to escape from the advancing Flick of the Wrist, but is far too sluggish and Martijn easily shoves the spikes into Dannys innards, so that when it lifts it gives Supreme Glory more damage to think about!
                              CRASH!
                              Once again Flick of the Wrist has rammed Supreme Glory into the arena wall, and something fell off then!Flick of the Wrist backs away to watch as refbot comes in to check on Supreme Glory.
                              1,2,3,4,5,6,7,8,9,10!
                              It seems that the component that fell off was the removable link, and so Daniel is powerless as Matilda thumps Supreme Glory again, this time sending it right OOTA in a graceful arc.
                              CEASE!
                              Supreme Glory loses the belt and Flick of the Wrist is the new holder!
                              • Challenge Belt
                                Martyn- Ill be sure to do that from now on
