Challenge Belt
  • Challenge Belt
    Do U want the challenge belt?Then ull hav 2 enter a real or vapourbot that meets RW rules and can kick ass 2 get it!I need 6 entries, so get going!
    After this tournament any1 can challenge the holder on this thread.
    Challenge Belt
    ...so you just started an identical thread because the last ones title was too boring?
      Challenge Belt
      Ill enter, with No Objections. The stats are in the coliseum thread, I think.
        Challenge Belt
        Liam, do you really need a new thread for every event? Cant you just make one thread for all of them like the various extreme threads?
          Challenge Belt
          I didn think any1 had read da last 1, but people HAV read this 1.C how dat wrks?And in future I wil stik 2 1 thread I admit its getin outa control already
            Challenge Belt
            Duz No Objections hav ANY opponents?
              Challenge Belt
              Well it IS called No Objections...
                Challenge Belt
                Tornado wil also compete, seen as it woz the last holder of the belt in RW.4 mor robots, any1?
                  Challenge Belt
                  Its all part of my plan, to gain peoples FEAR and AWE and RESPECT by winning tournaments nobody else bothered to enter muahahaha...
                    Challenge Belt
                    KK, Joey do u want to challenge Tornado for the belt?
                      Challenge Belt
                      Doesnt look as if I have much of a choice, does it?
                        Challenge Belt
                        And so the first challenge for the belt...
                        Tornado, the current holder goes up against No Objections, the dome from Kuwait!
                        Filling two of our 4 CPZs this evening will be the beautiful Matilda and the unstoppable shunt!
                        Tornado is a simple invertable box design, underestimated by many.It was a semi-finalist in robot wars 4, had an embarassing loss to Diotoir in series 5, but returned in series 6 with interchangeable weaponry to take Razers crown once and for all. It later became the european champion, and came a respectable 3rd in the final series of Robot Wars. For this battle the team has opted to use their pushing scoop.
                        No Objections is a slightly more complex design, a striking yellow dome with a lifter easily powerful enough to flip Tornado.The edges of the dome are very sharp so that when the robot goes into a spin its nothing short of a whirling dervish from hell!Unfortunately for Joey at the controls its a 2-wheel drive so Tornado should hav no problems shoving it around the arena.
                        Booth 1:Andrew Marchant, David Gamble and Bryan Moss
                        Booth 2:Joey McConnell
                        3, 2, 1, ACTIVATE!
                        Tornado gets off to a very quick start, driving around No Objections and sliding underneath to push it onto the flame pit. No Objections escapes and gpoes into a spin, but before gets up to a good speed Tornado comes in for another attack!
                        CRASH!
                        No Objections is left reeling while Tornado lines up for another go. This time, however No Objections is ready and manages to get its lifter under Tornados side. It quickly lifts Tornado into the air, but it falls off and plunges to the ground with a slam! Tornado attempts to ram No Objections from the side with his rear end, but No Objections is too fast and gets his lifter in again, this time getting one of the forks stuck in Tornados wheel rut when it lifts the pushbot up! Tornados in a very vunerable position as No Objections gets a very sweet (and hot) revenge and dumps Tornado on the flame pit. No Objections then reverses into the pit release tyre and waits for Tornado to give chase. It does, but it seems No Objections pierced that tyre and now Tornado has weakened maneouvrability! Taking advantage of this, No Objections runs in on the attack and gets under the side of Tornado, flipping him over so that the scoop has no effect! Tornado attempts to get away, but No Objections drives in underneath and rams them into the wall before using the lifting arm to prop Tornado up against the angle grinder! No Objections tries to flip Tornado out, but refbot gets in the way and rights Tornado, which manages to get its scoop back under No Objections and pushes it towards the pit! However, something is wrong with Tornado as it stops pushing No Objections and the dome slides off its opponents wedge. It appears that one of Tornados unreliable drivetrains came loose at the same time the tyre was punctured, and now it has fallen off completely! No Objections finishes the fight off by pushing Tornado into Matildas CPZ, where the rambot meets the very deadly flywheel and sails through the air, coming to rest in the pit of oblivion!
                        CEASE!
                        No Objections is the new holder of the challenge belt!
                        This is only my first fight, so plz go easy with ur comments although I welcum constructive criticism.
                          Challenge Belt
                          I hereby challenge No Objections to a fight for the belt. I will fight with Cyrilium. The latest stats are on the How Can I Improve... thread.
                            Challenge Belt
                            K, Joey you hav a new challenger!The fight wil b posted soon, any predictions any1?
                              Challenge Belt
                              Tonights battle will be No Objections first defence of his challenge belt, and the first challenger attempting to take that belt frm him wil be Cyrilium, a new machine frm Mark Elam. Correct me if Im wrong Mark, but I believe this wil b Cyriliums first ever battle!
                              Patrolling the CPZs tonight are Mr.Pyscho and as always hes accompanied by his ever-faithful mutt Growler, the canine born in the fires of Robot-Hell...
                              No Objections recently defeated Tornado (a previous european champion) to retrieve the belt. Joey isnt about 2 let go of it without a fight, and Mark Elam is the guy 2 giv him 1.
                              Cyrilium is a capital T-shaped robot with wedges at the front and rear. Its got the potential to give No Objections a good thwacking, but it cant run inverted and Joey will certainly try to get under that 1mm ground clearance.
                              Booth 1:Mark Elam
                              3,2,1, ACTIVATE!
                              Cyrilium is the first bot off the mark as it hurtles at No Objections full speed, slamming the holder into the arena wall!
                              CRASH!
                              No Objections is flipped by the force of the hit, but quickly self-rights and spins up. In an attempt to stop it spinning Cyrilium attacks again, and despite succeeding is sent spinning away across the arena floor. Taking adavntage of Marks momentary confusion No Objections attacks Cyrilium, slipping its forks underneath and lifting it up into the air!
                              CRASH!
                              Cyrilium falls off the forks and is lucky enough to fall down the right way up, and wastes no time in attacking No Objections again, getting underneath and ramming them into Pyschos CPZ! Pyscho brings his hammer down, but only just catches the edge of No Objections spinner rim, hardly causing any damage at all. No Objections was knocked free by the slight impact, and escapes from Pyschos grasp. Cyrilium, however is now trapped between Pyschos backside and the arena wall, and its unsual shape prevents it from getin free! Mr.Pyscho reverses onto the top of Cyriliums front wedge, and Mark takes his chance the reverse away. However No Objections is ready and gets in behind, lifting Marks machine for the second time!With amazing good fortune Cyrilium lands right side up again, but this time it isnt as quick to react and No Objections lifts it again, this time propping it up on the side wall! Before refbot can free Cyrilium No Objections lifts it off the side wall. Cyrilium falls right on top of No Objections with a slam, and Mark looks happy as he senses the impact may have damaged No Objections lifter.But hes never been more wrong, as Joey lifts again and Cyrilium ends up on his back! Refbot comes in and begins the count:
                              1,2,3,4,5,6,7,8,9,10
                              Cyrilium is immobilised!Growler comes in and grabs hold of Cyriliums corpse, dragging it onto the floor flipper like a good dog. As Cyrilium flies across the arena, No Objections does a victory spin and Joey celebrates his first successful defence of the belt.
                              CEASE!
                              No Objections keeps hold of the belt while Cyrilium goes back 2 the drawing board!
