How Could I Improve...
Fine All Info Here:
ULTO II
Shape: a bowler hat with the rim being a 360 wedge
Colour: Blue for the body, Green for the 360 wedge and orange for the teeth and flipper
Speed: ?MPH
Weight: 200KG
Armour: 5MM Hardox
Drive
Power 10 NiCad Battlepacks @ 36V
Locomotion: A Small Mechadon Like walking mechanism
Ground clearance: 3MM
Turning circle: 0M
Size: 100x100x35 the wedge is 5CM tall and protrudes 7CM
Weaponry: 1) The outer shell spins and is powered by a Perm132, it has 8 2cm teeth on the body and 16 1cm teeth on the 360 wedge
2) 2 Identical lifting arm protrude 120cm from a small Tazbot style turret the top of the robot and go down to the floor at right angles, they are powered by a 140X180MM pneumatic ram
Each is powered by dual 5KG Co2 bottles, it has 14 attachments:
1) A Hardox Forklift Arm which is 15X5X3
2) A Small Hardox Wedge which is 20X15X5
3) A Curved Hardox Wedge which covers 45 degrees and is 10X25X3
4) A Curved Hardox Wedge which covers 90 degrees and is 10X50X3
5) A Curved Hardox Wedge which covers 180 degrees and is 10X100X3
6) A Circular Hardox Wedge which is 13X15X5
7) A Hardox Scoop which is 20X20X30
The Other 7 attatchments dont use the original arm they are connected to the turret and all arms are 120 cm long (without attatchments)
 A Tazbot Style Lifting Arm
9) A Tazbot Style Lifting Arm with Panic Attack Style Forks at the bottm which are 35X20X1
10) A Mortis Style Lifting Arm
11) An Atomic Style Lifting Arm that narrows at the top and the wedge is 5X25X5
12) A T-minus Style Lifting Arm
13) A Techno Destructo Lifting Arm
14) A Toro/Ceros Style Lifting Arm
Srimech: The Flippers
Strengths: Powerful Spinner, Powerful flippers, Weapons synergy
Weaknesses Heavy, Quite slow
There, Phew!
					Fine All Info Here:
ULTO II
Speed: ?MPH
Weight: 200KG
Armour: 5MM Hardox
Drive
Turning circle: 0M
 A Tazbot Style Lifting Arm  9) A Tazbot Style Lifting Arm with Panic Attack Style Forks at the bottm which are 35X20X1
There, Phew!
