How Could I Improve...
  • How Could I Improve...
    There is good reason those weight classes are not popular and never have been. Even in the Heavyweight class some people would rather see the limit go down to 80kg again. I for one think that the 100kg heavyweight class is the highest sensible weight class for back and limbs, provided you have a teammate or 2.
      fine, so how do you suggest i get S.U.C.K.E.R.P.U.N.C.H inside the weight limit with the disks weighing 15kg?
        Well for starters Id lose the second disc on both machines and stick with one on each. Even 100kg heavyweights like 13 black had to accept less armour to accomodate for the second disc.
          ok only 1 disk
            well thats a start. now you need to reduce your armour as well.
            Hardox is heavy. 6mm with the dimensions you give, you are looking at 45kg of armour alone, 50 without the holes in the armour to poke the disc and wheels trough.
              3mm hardox
                ok, so you are now reducing the armour to about half, that makes it 22.5kg. Lets for the sake of argument take 22kg.
                armour 22kg
                disc 15kg
                2x lem 130 6kg
                1x lem 200 11kg
                4x nicad 36V 10.8kg
                add those up, you are on 64.8kg.
                Then you still get gears, guidewheels for the tracks, tracks, electronics, and so on. Even if you do get 5kg extra per robot for tracks, I dont see how that would help you in this case, the tracks are just too heavy for a cluster. I think of you make your robot 2 wheeled instead of tracked, you might just get it down to 75kg per cluster side.
                  ULTO II
                  Shape: a bowler hat with the rim being a 360 wedge
                  Colour: Blue for the body, Green for the 360 wedge and orange for the teeth and flipper
                  Speed: 12MPH
                  Weight: 150KG
                  Armour: 5MM Hardox
                  Drive: 4 C40-500 Magmotors @ 36V
                  Power 10 NiCad Battlepacks @ 36V
                  Locomotion: A Cheeky Boy walking mechanism
                  Ground clearance: 0MM
                  Turning circle: 0M
                  Size: 60x60x25 the wedge is 5CM tall and protrudes 7CM
                  Weaponry: 1) The outer shell spins and is powered by a LEM130, it has 8 2cm teeth on the body and 8 1cm teeth on the 360 wedge
                  2) A lifting arm protrudes 40cm from a small Tazbot style turret the top of the robot and goes down to the floor at right angles, it is powered by a 140X180MM pneumatic ram
                  Powered by dual 3KG Co2 or Nitrogren (Cant Decide, Help!)(It also can be powered by the KE of the spinning shell, like warrior SKF), it has 5 attachments,
                  1) A Hardox forklift arm which is 15x5x3
                  2) A small Hardox wedge which is 10x15x5
                  3) A curved Hardox wedge that covers 90 degrees of the body
                  4) Another curved Hardox wedge that covers 180 degrees
                  5) A Hardox ring which is 13x13x5
                  Srimech: The Flipper
                  Strengths: Powerful Spinner, Powerful flipper, Weapons synergy
                  Weaknesses Heavy, Quite slow
                  Modifications for 200KG weight limit:
                  Another identical flipper on the back of the turret capable of creating 360 flipper when both use attachment #4
                  Two LEMs powering the shell
                  Thicker armour/shell
                  Let the Nit-picking begin
                  (Message edited by neontetra23 on July 16, 200
                    Right then...
                    1) You might have to explain the walking mechanism to me. Walking weight bonuses are a bit weird because of people insisting that certain methods of walking are in fact shufflers (Craig, Aaron and, uh, me :P) and just saying Cheeky boy walking mechanism is not going to help as I have no idea what it is.
                    2) You will not fit all of those mechanisms in 60 x 25, trust me. Gyrobot was probably the smallest heavy with a similar weapon I can think of, and it was 10cm larger, and wheeled. Youll need space for the as yet unknown walking mechanism, the clutch to transfer the energy to the flipper, and these weird attachments, and batteries, so think about at least a metre in diameter.
                    3) With 0 ground clearance, it wont move. You need at least 7mm under the body to be able to properly move, and preferably more.
                    4) The lifter...where do I start? :P I dont want to think about how you can make it run from the KE of the ring when its a 360 degree turreted weapon, that seems to be a mechanical impossibility. Also, with everything else, having it run on pneumatics may take it overweight, so drop that.
                    5) If the lifter protrudes 40cm from the turret and goes down at right angles, and your diameter is 60cm, you will be lifting parts of your own robot up.
                    To be honest, it looks like youve tried to create a robot to beat everything with little regard to complexity, reality, or peoples sanity :P You seem to be out of your depth regarding describing things adequately in this design, so try something a bit simpler.
                      Ben, first perfect the stats of your other bot before you start new ones. specially one with so many faults as Ulto II
                        fine no KE
                        same mechanism as archangel of the abyss
                        less batteries
                        smaller pneumatic rams
                          So...now youre stealing from other vapourbots? Thats just so wrong.
                            cause no one has ever done that one before chris lol
                              Theres a difference between unintentional and deliberate.
                                no it wasnt invented by alex he just used it
                                what you are saying is like saying im stealing by using a pneumatic ram
                                (Message edited by neontetra23 on July 17, 200
