How Could I Improve...
  • How Could I Improve...
    Thanks Paul
      quote:
      It did in my Mini-Tournament, as Leo stated in his stats Symmertrys batteries wouldnt go the distance.Most vapourboteers make their robots Battlebots specs So I thought Id do that too. Battlebot fights are 3 minutes, not 5.
      But thats ok, if Symmetry cant get the job done in 3 minutes it wont do it in 5 minutes either.
        Well, in practice its up to the writer wether ANYTHING needs to be specified or not.
        But while things like armour and weapons are commonly accepted as must-haves, batteries are in a grey zone, I myself kinda agree with Frank though.
        Liam, good question. In all cases I have seen, and it happened more than once, a realie would be seeded based on its performance no matter who enters it.
          I personally dont look at battery stats in detail, but I think they should be included, if only for the sake of completeness - besides some designs benefit from heavy SLA batteries rather than lighter ones, but thats just me being pedantic probably.
            Right so you plant a V8 in a car and say it runs on petrol you think that is enough to predict it will last 30 rounds in the race?
              The problem with batteries is I dont have a clue where to start.
                I just say NiCads unless I need SLAs for weight (like in a Mjollnir-style torque reaction pickaxe), and work from 1 pack being 12v, stating more if I think I might need more (e.g. for an electric spinner or tracks). /useless
                  batteries are vital for vapourbots, if you dont list ur batteries then u will never know how far it will run for.
                  eg, 2x Mag s28-400 and 2x LEM-200 would require 8x 24v 3Ah Nicad Packs that would leave u with no weight for anything else
                  As for types of batteries thats simple enough to explain.
                  Nicads and Nimh - there nearly the same, Nicads produce a higher current but you can get high discharge Nimh that can out preform nicads, I have some in the new Tanto. Youll need min of 3 packs for a heavyweight on Mags
                  SLA (sealed lead acid) or Gell Cells - much heavier but potential higher discharge than nicads
                  Li-Ion or Li-Po - lighter than nicads, but early tests on the A123 cells show theyre discharge is half what they claim, theyre good but theyre not there yet
                    2 Mags require 8 batteries?! :S
                    I always thought that LEMs sucked up more batteries than Mags in the same time frame. :S
                    (Message edited by kodster on May 06, 200
                      2 mags and 2 lem200 as in used at the same time, sorry that wasnt very clear
                        Not really the place to ask, but Craig could you give me details of these high discharge Nimh batteries, could be just what I need.
                          you need a curry and a night out with me mate mark if you have my mobile number give me a ring please
                            Mauling Dervish
                            Shape: Barberous 2 and a bit
                            Colour: BLACK
                            Weight: 100kg
                            Dimensions: 96 X 42 X 42
                            Armour: 8mm Titanium
                            Wheels: 2 X Tightly Foam Packed Wheels with Hardox Hubs, based on Stinger
                            Drive: 2 X C40-500 Magmotors Powered by 4 X 24V NiCad BattlePacks
                            Speed: 15mph
                            Ground Clearence: 6.8mm All Around
                            Turning Circle: Zero
                            Weapon: 19kg Full Body Drum with 8 X Grade 5 Titanium Teeth, a bit blunt and curved upwards. Its powered by 2 X LEM-130s and spinning at 3000RPM. This also spins upwards to flip AND damage opponents at the same time.
                            Strengths: Invertible, Flipping it does nothing at all, PSYCHOTIC WEAPON!!!!
                            Weaknesses: Although EXTREMELY sturdy, wheels kind of exposed.
                              Looks fine at a glance, but Id change the name. Theres already a similar robot called Dervish.
                                To have your drum 19kg, your drum would have a wallthickness of 2mm steel,or 3.4mm Ti. Over a distance like almost a meter its not going to be pleasant.
