Mechanical Noise - Series 2
Heat D
Heat Final
Achilles (7) vs Killotine: EVO
3€¦
2€¦
1€¦
ACTIVATE!
What€™s interesting to say is that back in Mechanical Noise - Series 1, many predicted this fight to be the Heat F final. Back then, Chris Mason proved the criticisers wrong by flipping Killotine OOTA in the 2nd round, only to fall against Achilles in the Heat Final. Steve got his €œrevenge€ then by beating Achilles with Wedge Devolution on a JD in the semies, but Alex had the last word when Black Panther Queen beat Wedge Devo in the finals
. Back in the present day, Achilles€™ Eteks push it forward and towards Steve€™s axing menace. Killotine may have a disadvantage when it comes to speed and drive, the axebot is slightly more controlled and heck, those skirts offer some nice protection against Achilles€™ weaponry, as is showed off right now when Achilles tries to get under Killotine€™s side. Achilles initial attempt fails here and Steve makes sure he won€™t get a second chance. Killotine skid-steers around Achilles€™ chassis and reaches Achilles€™ side, only to come by the same problems Achilles encountered earlier, those blasted skirts
. Luckily Killotine€™s weapon doesn€™t rely on getting underneath stuff, and Steve brings down his mighty axe
CLANG!
CLANG!
Achilles is left vibrating after 2 axe-blows in quick succession, but other than the judges noting this display of aggression, Alex is happy to see the attack had little effect. Achilles€™ top is by far the best-protected area of the machine with 10 mm rubber over 5 mm of titanium. Achilles accelerates away from the pressure Killotine is putting him under, and makes a 360, giving Steve a nice view of that feared flipper. Achilles steams in, fully aware of how Killotine€™s weapon only hits that what€™s right in front of it, and rams the front-corner of Killotine! Killotine lowers the axe but narrowly misses Achilles! Achilles is underneath the front now, and activates the flipper.
FLIP!
Now it€™s Killotine€™s turn to make a 360, a 360 through the air that is
. Alex is displeased to see himself failing to through Killotine on its back, but given the position in which Killotine lands in front of him, receives one helluva second chance. Achilles attacks Killotine€™s front, again. Killotine uses its axe, again€¦
CLANG!
Only this time the axe does hit its target! The damage is minimal however, and Achilles continues to get underneath Killotine and flip it€¦
FLIP!
On it€™s back this time! Achilles nudges Killotine as it starts to self-right, out of danger. Achilles is quick to turn however and can now be found at Killotine€™s side, pushing it, towards the wall!
CLANG!
Killotine finds itself closed in by Achilles and the wall on either side, and because of this Achilles quite easily pierces Killotine€™s skirt now! Lets see what a flick of the flipper can do, shall we Alex?
CEASE
Killotine: EVO has hit the camera tracks
Achilles (7) goes through to the semi-finals!
Coming next:
Heat E
Cyberdemon (9) vs BIACS-LE vs Wedginator 5.0
Turbulence vs Starstorm 2 vs MORD2
Gimme your predictions, gimme your tactics, gimme your thoughts
Heat D
Heat Final
3€¦
2€¦
1€¦
ACTIVATE!
! CLANG!
CLANG!
FLIP!
. Alex is displeased to see himself failing to through Killotine on its back, but given the position in which Killotine lands in front of him, receives one helluva second chance. Achilles attacks Killotine€™s front, again. Killotine uses its axe, again€¦ CLANG!
FLIP!
CLANG!
CEASE
Coming next:
Heat E
) and flip it onto its back. Whilst self-righting, make sure it bounces onto my flipper, push it to the edge and flip it out! If Rich wishes to gang-up on Frank, then thatll be fine.
