Mechanical Noise - Series 2
Ah, all went according to plan! Great fight Martijn!
. The most successful sawbot ever is back with a vengeance and an awesome drivetrain, but some say the hedgehog lost its glory.
. SOR moves in and Star moves away. The fbs€™ top speed moves it out of the range of the flipper, and Martyn now found himself some time to spin up its weapon, and comes in at SOR! Andy turns SOR€™s back to Star again as he really doesn€™t want his flipper to feel the spinner€™s wrath. Not scared for a confrontation, SOR comes in as determined as Star does, and the duo meets with a bang!
. Star bounces off the Hardox armour and dances around uncontrollably for a second, whereas SOR makes a spin around its centre. When Andy turns SOR around, he sees the damage done to SOR€™s rear. The Hardox€™ plate is mostly intact, but that bar is looking pretty damn loose! Andy€™s highest priority does not include that bar at all though, and he wedges Star who is only just regaining control. Andy€™s plan isn€™t performed perfectly as Star€™s weapon slowed down only 50% or so rather than 100, and Andy fires his flipper quickly before receiving more blows! Star flies through the air yet again and initially lands on its side. Andy moves as Star starts to topple back on its wheels, and wedges the spinner again! The duo moves in forward-motion, one of Star€™s teeth dragging along the ground stopping it from spinning up. The wall€™s in sight!
) around each other. Steve guesses his six wheels will make MSSD turn slightly better than Snakebite€™s camshafts and the hedgehog has a go at the snake€™s right corner! The box slides underneath, and sparks fly when its top receives a nudge from the blade! That nudge knocks MSSD aside slightly, and MSSD€™s saw is positioned under the skirt rather than the main body! Sparks fly from under the skirt when MSSD drives Snakebite forwards and slams Snakebite against the wall!
. With a display of sparks and€¦ sparks, the saw eats its way past the skirt underneath the body, where Snakebite€™s underbelly is at the saw€™s mercy! The shafts are trying to get a grip on SD€™s wedge to shuffle away, but aren€™t quite able to do so. For all Richard knows, Spin Dash might be sawing his shaft in halve right now! After several highly tense seconds, Snakebite manages to get a grip on MSSD€™s saw of all places and shuffles away to safety. Doing so, however, Richard shockingly discovers several small slices across his left camshaft! Snakebite still moves, but can€™t quite respond when MSSD comes in on its right side! With the traction on the left shaft decreased as it is, MSSD does a good job pushing Snakebite. The hedgehog turns left a little, where the pit is waiting! The grip left in Snakebite moves it forward a bit, but is it enough€¦?
This is going to be a tough match, but a great one whatever the outcome is. First of all Im going to take my bar to those skirts. I will aim to rip them off if possible or at least mangle them to allow me to get under easier. From there, slide the flipper under and keep throwing it over. Ill try to throw it OOTA, pit it, whatever - just get rid of it. Its saw is going to have a hard time getting under my skirts, and then its going to do minimal damage to the 4mm Hardox. If it comes down to the pushing game we both have the same drive set-up, so this is going to be interesting. Hopefully I can swing this one on the damage factor. Good luck Steve, this should be fun!
! SOR fires its flipper hoping to get off, but it€™s no use!!! Spin Dash has its revenge!
Still, brilliant destruction, Martijn!
Seung Minas previous generation...lets see. Two powerful flippers and a suicidal ring spinner? Would be wise for me and Achilles to gang up on it. *SHOCKHORROR* Shouldnt be hard at all.
