Mechanical Noise - Series 2
  • Mechanical Noise - Series 2
    Heat E
    Round 2
    Fight 1
    Wedginator 5.0 vs M.O.R.D2
    3€¦
    2€¦
    1€¦
    ACTIVATE!
    There we go, MORD€™s drum starts spinning viciously and clearly visible for the audience, and Wedginator starts spinning up its wheels, slightly less viciously but still with great acceleration. MORD shuffles around, lining up for the first confrontation with its opponent, but Wedginator does not show such care! The wedge comes raging in like a mad rhinoceros for a reckless full-out attack on MORD! Richard did not anticipate such an attack at all, such aggression, such recklessly!
    CLANG!
    CRASH!
    Wedginator shoots under the scoop of MORD, receives a knock by the drum on its polycarb top, but isn€™t thrown back by it due to the momentum Wedginator had! Other than pushing MORD, the drumbot shoots over and lands right behind Wedginator! An aggressive display by Kody who now sees he has to pay the price with some serious scratches on his flipper, courtesy of that drum (you know which one). MORD turns around to bring in its weapon on Wedginator, and Kody follows Richard€™s example (guess which one can turn faster :wink. Wedginator attacks MORD€™s side skirts with its own skirt. Wedginator does not manage to get under straight away, but he DOESN manage to do so after pushing MORD a centimeter or 2 . Kody€™s glad he made his skirt of Hardox, as it seriously helps him in getting under the titanium skirted MORD. Richard now tries to get his machine back on the ground by LOWERING the invertible scoop, pushing himself off Kody€™s wedge. Kody decides to help Richard a little and activates his flipper .
    FLIP!
    Not as devastating as most rear-hinged flippers, Wedginator€™s front-hinged flipper still does what it€™s supposed to do and throws MORD away. Richard couldn€™t care less it seems, his machine runs on its back just as well as it does on its belly. The past NSBFL winner turns around, and heads towards the current EOTR runner-up. Kody prepares, but Richard changes his course ever so slightly, and sticks his scoop under one of the points of Wedginator€™s triangular base! The duo travels towards the arena wall were MORD puts Wedginator in an upright position!
    CRASH!
    The drum hits Wedginator€™s belly! Luckily for Kody, he made his wheels stick out. Balancing on 1 wheel with its top against the wall, Wedginator drives away from MORD and fires its flipper, against the wall, to end up back on its wheels, but not before Kody becomes aware of that huge crack in Wedginator€™s base! MORD gives chase€¦
    CRASH!
    The drum attacks Wedginator€™s side just as the robot was turning around to face MORD. Wedginator however continues its current maneuver and penetrates MORD, from the side, and takes Richard€™s pride for a ride! Richard tries the same trick he used before, but Kody is determined this time€¦ mainly because€¦ he€™s driving to the pit! MORD nearly escapes, but Wedginator is fast€¦
    FLIP!
    CEASE
    M.O.R.D2 meets the bottom of the pit
    Wedginator 5.0 goes through to the heat final!
    Heat E
    Round 2
    Fight 2
    Starstorm 2 vs BIACS-LE
    3€¦
    2€¦
    1€¦
    ACTIVATE!
    It€™s full body vertical low to the ground flipper vs axlebot invertible overhead vertical disc, two original vapours if ever there were 2 . Matty realizes that Starstorm has 180 degrees of protection and therefor it doesn€™t matter from what side he attacks. His machine comes in like a€¦ bull in a China shop () on Starstorm. Starstorm itself in the meantime also set foot in BIACS-LE€™s direction€¦
    CRASH!
    BIACS-LE€™s weapon comes down on Starstorm€™s Hardox dome, and sparks fly! The damage done to Starstorm is€¦ minimal, and BIACS-LE retreats its weapon. Starstorm accelerates and gets under. Matty obviously wants to use his weapon again, but Frank is faster€¦
    FLIP!
    The axlebot flies up, high into the air, and twacks down€¦ on it€™s disc! Matty can€™t control his creation this way. The machine travels quite some distance across the arena on its disc before it settles€¦ with Starstorm damn close to it!
    FLIP!
    Frank does it again . Matty€™s hardly recovered from that previous attack when Frank comes in for a second one. The throw is still a high one, but this time BIACS-LE comes down a bit more€¦ comfortable. Starstorm however has turned on the aggression now and has wedged BIACS-LE! He takes it to the wall for an OOTA, but BIACS-LE has other plans. Matty€™s in twacking mode again .
    CRASH!
    OMG . One of BIACS-LE€™s teeth caught one of Starstorm€™s weight reducing holes, and Starstorm is swept away from BIACS-LE! No matter how thick the Hardox, there€™s clearly a bit of bend metal around that hole now! Could this be a turning of the tide for BIACS-LE? In he goes again!
    CRASH!
    BIACS-LE does it again! He€™s less lucky with his hit this time however, even though Starstorm€™s paint suffers quite a lot .
    10€¦ 9€¦ 8€¦ 7€¦
    The judges think it€™s about time€¦
    6€¦ 5€¦ 4€¦
    Starstorm manages another flip!
    3€¦ 2€¦ 1€¦
    CEASE
    None of the machines could finish the other off€¦ time for the judges to come into action.
    Damage: Starstorm 2 ((4 out of 10)*2=
    BIACS-LE ((5 out of 10)*2=10)
    Aggression: Starstorm 2 ((7 out of 10)*1.5=10.5)
    BIACS-LE ((8 out of 10)*1.5=12)
    Control: Starstorm 2 ((7 out of 10)*1=7)
    BIACS-LE ((5 out of 10)*1=5)
    Style: Starstorm 2 ((6 out of 10)*0.5=3)
    BIACS-LE ((6 out of 10)*0.5=3)
    Starstorm 2: 8+10.5+7+3=28.5
    BIACS-LE: 10+12+5+3=30
    Starstorm 2 couldn€™t impress the judges
    BIACS-LE goes through to the heat final!
    Coming next:
    Wedginator 5.0 vs BIACS-LE
    Gimme your predictions, gimme your tactics, gimme your thoughts
      Flippers really dont bother me, so crash, crash, crash, crash, crash, try and use the disc to knock into hazards, pits, whatever, just keep hitting it and get rid of it.
        Oh well. Twas close at least. I shall only sulk a little bit.
          Awesome! More w00tiness from Mr. Benschop
          Mechanical Noise Series 2 - Heat E Final
          Poot. Well, I can see why flippers dont bother Matty, as BIACS-LE is invertible and, really, awkward to flip. Thats why Im mainly going to be relying on aggression, and pure power. Drive straight into the disc and stop it, no matter what. Then shove it around, and get it into the pit. OOTAs arent Wedginators style, so go for that pit! Pit pit pit!
          Good luck, Matty.
            Wootiness of the fight variety, Marti.
            Wedginator 5.0 vs. BIACS-LE
            Axlebots are really awkward to flip, and BIACS-LE could probably seriously rough up Wedginator a bit. BIACS-LE to win, unless Kody can execute his pit strategy.
              Well, now that I know BIACS-LEs disc is at the BACK...Im changing my starting tactics. :P
              Ram it, and smush the disc into the wall to stop it before it can swing over. Other than that, ram it to hell. :P
                Heat E
                Heat Final
                3€¦
                2€¦
                1€¦
                ACTIVATE!
                Wedginator still is the LEM-powered 25 mph monster he was earlier this heat and the crocodile blasts out of the starting square towards BIACS-LE. Matty as well takes an aggressive approach. BIACS-LE drives into Wedginator, but when it comes to purely driving, Wedginator seems to win this fight .
                CLANG!
                With great power Wedginator comes in underneath BIACS-LE€™s front. The wedgebot carries the axlebot to the wall€¦
                CLANG!
                CRASH!
                JUST before Matty€™s disc would have hit the wall, mr. Fowler brings it down with a thump! It looks to me like the weapon is not fully spun up yet, and also like BIACS-LE suffers more than Wedginator does, since the axlebot itself is thrown away on impact. Wedginator steers around to face BIACS-LE again, who JUST couldn€™t recover fast enough to do anything against this attack. Wedginator underneath now€¦
                FLIP!
                Kody shows some aggression with this great powerflip, but BIACS-LE, being the annoying axlebot it is, isn€™t all that impressed. BIACS-LE lines up, Wedginator comes in€¦
                CRASH!
                FLIP!
                BIACS-LE attacks the moment Wedginator comes in, but Kody is quick with the controls . When the disc came down, the flipper went up. This pretty much saved Kody€™s main body, but he DOES have a slice across his flipper now! BIACS-LE shows off how agile he is and he gets around Wedginator€™s side!
                CRASH!
                THERE! Wedginator€™s front wedge has the shape and thickness to take blows from bots like BIACS-LE, but its sides don€™t have such luxury . Wedginator is attacked by the disc, and flipped! Matty smirks and hopes to attack Wedginator€™s belly now€¦
                Lining up€¦
                SELFRIGHT!
                CRASH!
                If someone knows a cool sound effect to use with a super tense €œin the nick of time€ selfrighting action like this, please e-mail your suggestion to MartyB512@hotmail.com . For now, all I can say is Wedginator successfully dodged BIACS-LE€™s ordeal with some great selfrighting skills., and the disc comes down on the floor. Wedginator moves around the axlebot, but Matty€™s weapon can be brought in fast, very fast€¦
                CRASH!
                Ooooooooooh, that€™s gotta hurt! The weapon again comes down on Wedginator. Wedginator wants to back off a bit€¦ but€¦ but can€™t?! At least, not as fast as it wants to! Wedginator is moving badly after that last attack of BIACS-LE, who comes in again for the kill!
                CRASH!
                Wedginator€™s done for! BIACS-LE€™s gone straight through the polycorb and has bend Wedginator€™s left wheel€™s axle with that attack! Kody€™s pride drives in circles it seems€¦ The judges start moaning.
                1€¦ 2€¦ 3€¦ 4€¦ 5€¦ 6€¦ 7€¦ 8€¦ 9€¦ 10€¦
                CEASE
                Wedginator 5.0 has been beaten into submission
                BIACS-LE goes through to the semi-finals!
                Coming Next:
                Heat F
                Novastorm (11) vs Y4 vs Salamander III
                Aneurysm vs Enter the May Tracks vs Riptile 3
                K, here€™s the deal. I will concentrate on UTATYA (Use the Arena to your Advantage ) now, a 16 vapour tourney that€™ll keep me off the street for a while. This happens to have the side effect that it buys Matty some time to get his stats for Riptile 3 together, which would be cooler than giving byes . I might come up with a deadline after UTATYA is done, if I can be bothered.
                  Agh. Beat my ass. Oh well, you win some, you lose some. Good stuff Martijn.
                  I dont see the seed going very far here. Novastorm to either finish the match destroyed, or on the camera tracks.
                  Honestly, I dont know.
                    My tactics will wait until Matty posts stats.
                      Well, now that Mattys back, maybe well see a glimpse of Riptile 3 and possibly the revival of this tournament?
                        May I ask, as none of us have heard from Matty in weeks, what happens if it turns out hes retired? Im not bumping this, its just that the competitions been great so far, and many of us dont wish to see it go the same way as my last 2 competitions - which reminds me...*Restarts work on E.O.T.R.5 with a very large pen *
                        (Message edited by paulc on May 24, 200
                          I must say I wanna finish UTATYA first no matter what Matty does, when UTATYAs over and Mattys still missing, Im gonna use the stats of Riptile 2 and go on with this
                            Helloooooooooooooooo!
                            Newsflash!
                            Ill be knocking together the last few fights of UTATYA 1 this week and I wish to continue MN 2 after that. I dont know when exactly Ill finish UTATYA and continue this, but when I do, and Riptile 3s stats still arent in, I shall use the stats of Riptile 2 for this tournament, mkay everyone?
                            So basically, Matty, you have about 1 week left to get Riptile 3s stats in
                              uhhh... silly question... where can I find Riptile 2? :blush:
                                ok, new deal, if by next week I dont have EITHER Riptile 2 OR Riptile 3 in, Ill be using Riptile 1!!!!
                                (something tells me I should check where to find Riptile 1 before making this post...)
