XT90s are the next step up, they should do fine.
BOB FW Series
Yes, XT90s. I should note that there is a anti-spark variant available (XT90-S) which I have for Kaizen so hopefully should help allieviate this problem (https://hobbyking.com/en_us/xt90-s-a...pairs-bag.html).
Well it seems to be 1 step forward 5 steps back.
Put on the new XT90 and switched it on and now this.
The fuse now decide to do a bit of sparking, I'll have to change the fuse and a few other things inside just to be sure. Maybe I should change my robot name to Sparkman.
On the plus side I finally got my HDPE panel that will be its armour, just need to measures it and cut it up to its right size.
Well my robot may have not worked so well but I still had a nice time. Just need to work on the next one now.
Before
After
This is the fight where it happened.
https://youtu.be/yx6KrEwdtME
The components should still work, just need to try and fix the problem on this one and start on the next one.
They might have not had the torque to turn the mass of bot with wide wheel base. You can try uping the voltage to 6s which would improve performance by how much not sure but this may be the quickest "fix" but the best idea would be to make a smaller tougher bot, AL's Plastic Fantastic is a good place to look ( it was also at manchester)
Hmm.... re-reading the thread again, did you use the same battery as the one you were having trouble with (https://www.componentshop.co.uk/14-8...o-battery.html)? 14.8v from a 4S1P LiPo should be plenty, The Honey Badger ran on 13.2v batteries(2x 2S1P LiFe batteries in series) for all but the last fight and weighed 12kg.
The videos I have definitely show it spurting into life briefly and then slowing down, even in a straight line. Could be a slippery floor then.Last edited by Ocracoke; 24 April 2018, 16:35.
If it was a traction issue, it would be good to know what wheels were you using and were they new at the start of the event? I definitely noticed grip getting better as the crown wore off my new tires and they got more rubber in contact with the arena. Did you have the same problem all weekend or did it improve/worsen as things went on?
These are the wheels I'm using, they're new when I used them.
http://www.banebots.com/product/T81P-495BA.html
From looking at the fights again it seem to have got worse in each fight. When I had it weighted it was 13.9KG and that's without the linear actuator in it. At the end of the 2nd fight I drilled a lot of holes in it to help its weight and made some lines the wheels to help with the grip.
Those wheels look fine, I certainly wouldn't have thought it was lack of traction.
Were you still running the 30A controllers per 2 motors? I can't quite tell from the pictures. Maybe its some weird combination of those not allowing the motors to get enough juice, grippy tires and the wide/long wheelbase? I would still be surprised though, I would have though 4 drill motors at 4S would have shifted that along just fine.
For reference its about 27cm w * 22cm long on the wheel centresHow large a wheel base is PF Al ?
