Well I'm using the AC input power port (AC 100~240v 50/60HZ
BOB FW Series
It's a 14.8V, max charged voltage is 17v
more info about the battery if it helps here
https://www.componentshop.co.uk/14-8...o-battery.html
There's always something. I been doing a bit of weapon testing to make sure I got the right channel. With the new battery in and going to put the safety link in, then it does this.
This why you test things more then once, so you can avoid things like this.
Now I need more plugs.
