  • Coolspeedbot
    replied
    Damn it.
    Leave a comment:
  • Coolspeedbot
    replied
    started some wiring, hope it holds.
    Leave a comment:
  • Coolspeedbot
    replied
    Thanks, I'll thin the base and do a test run with it.
    Leave a comment:
  • Albear
    replied
    looking good!
    Leave a comment:
  • Coolspeedbot
    replied
    Added the wheels to Wolf-E, by melting a nut into the bore of the wheels, then threaded it onto the shaft of the drill motors.
    Not bad for a first go.
    Leave a comment:
  • Coolspeedbot
    replied
    Demo of the 4 cell lipo battery + 12 volt drive motor set up.
    Leave a comment:
  • Coolspeedbot
    replied
    I see
    Leave a comment:
  • daveimi
    replied
    Yeah my robots are made from biscuit tins and chopping boards so I'm not really an expert. But after building naff robots since 2012 you do start to pick bits up here and there. I spose what I mean is you don't need angled wedges, just a robot that's sort of all one shape so it's hard to get a bite on lol.
    Leave a comment:
  • Coolspeedbot
    replied
    I see what you mean David, if you can do a sketch that might help a lot more although bare in mind that Wolf-E was designed to me made with HPDE with the top and bottom plates/ wedges made out of hopefully a metal material (depending on weight and cost).
    Leave a comment:
  • daveimi
    replied
    Yeah or even more so. I just realised you may not even want to fight spinners so it doesn't matter. But if you look here on Beta can you see how it's just one smooth continuous angles and shapes? And how anything nasty trying to get at it would sort of deflect rather than chew? If it helps I can sketch something to show you with regards to your robot when I get home.
    http://vignette2.wikia.nocookie.net/...20160517203923
    Leave a comment:
  • Coolspeedbot
    replied
    Originally posted by daveimi View Post
    Smoothing the wheel guards in will help with spinners if you have weight etc. The right angle will be easy for them to bite.
    something like this?
    Leave a comment:
  • Coolspeedbot
    replied
    Although I'm not sure Wolf-E would be used at events with spinners anyway.
    Leave a comment:
  • Coolspeedbot
    replied
    I'll see what I can do
    Leave a comment:
  • daveimi
    replied
    Leave a comment:
  • Coolspeedbot
    replied
    Edited design so the frame to interlock with the top and bottom plates and made wheels with bike tyre treads.
    Leave a comment:
