This isn't a CAD software it's actually a animation and modelling software called Autodesk Maya. I'm only using it cause my Mac can't run Fusion 360 which has been recommended to me before. I know it isn't really ideal for the job but it works for concepts.Originally posted by mackemforever View PostJust out of interest, what software are you using for your CAD?
Forgot to post these, I’ve started making a cardboard mock up of the designed panels to get a sense scale with the electronics.
Also I've been wondering in regards to the 6 wheel robot design and it's weapon linkage, how does one attach a lifter arm to a shaft? and how do you connect that same shaft to spur gear?
Finally made a new version of CSB's 2 wheeled design on the computer. In other news I got a sheet of 10mm thick HDPE for Xmas so when I get some new bolts and threaded inserts I'll hopefully have the HDPE parts of the body work finished sometime in the new year and then I'll worry about getting a Hardox panel for the wedge down the line.
Not sure how you see it as looking like Firestorm.Originally posted by Albear View PostThe shape reminds me a little bit of Firestorm but obviously shorter. Like it though!
I see, well we'll see, it should run inverted but I'll have to test it once I finished making the bodywork.Originally posted by Ocracoke View PostComes down to traction really. You can have all the power in the world but if you can't put it down, it is of no use. Your design certainly looks fine, especially it it can run inverted.
haha! Looks good none the less!
