This one will probably end up a role reversal lol. You'll be working and I'll fail
Massacre - Build Diary
 Looking very good! :-) On 5S it should be even scarier!
 And for hiding, I recommend wheely bins. Easy to move, fairly strong and big enough to crouch behind. :-)Last edited by Eventorizon; 1 April 2014, 17:32.
 lmao alex would know… during a gadgetshow filming he once proved he really can drop to the floor and scream like a girl like a total professionalOriginally posted by Eventorizon View PostLooking very good! :-) On 5S it should be even scarier!
 Looking good, with a nice short spin-up time! You might want to be careful though; I once did a spin-up test with just the motor and weapon mounted on the base plate and at near to full speed the whole thing took off! It jumped almost a metre  straight up and punched a hole clean thru the 1" side of my work bench. if its not already held down, I would really recommend screwing the base to something heavy! It jumped almost a metre  straight up and punched a hole clean thru the 1" side of my work bench. if its not already held down, I would really recommend screwing the base to something heavy!
