to put a taped thread into ally i just use a 2nd stage tap not really any different to normal, on the armour i used ally angle to brace the side
scruffy
finally got the lifter fully working would just lift the side of 2.5kg box but had no problem with 1.5kg also planning to make a aluminium/titanium scoop which should be lighter than the steel one
https://www.youtube.com/watch?v=uQuazMhq8IU
ok actually now done enough to beetle scruffy to make it worth posting
im using a sabertooth dual 5a and 2x 500rpm motors which don't seem very impressive, i tryed shoving a 1kg cat food box and it really struggled compared to the 4wd, might change to the same brand as the version in my 4wd as they seem a better quality
i have a 17kg torque servo which will run the lifter, at present im doing some cad to work out the armourLast edited by plargen; 14 December 2013, 15:57.
finally decided on a name for my 4wd BW, which is ..................... glitch, i still have to add the external bec and finish off the replacement scoop but other than that its ready to go
ive also started building another fw might keep it a surprise for gls, mainly im trying out a different motor gearbox setup to the normal drill units
finally got the new Ti prongs made for my bw glitch not the nicest looking but they should stand a chance against all the spinners
will post pics soon
and here it is
and a vid
http://www.youtube.com/watch?v=tjS3_sJaXIwLast edited by plargen; 8 February 2014, 17:06.
scruffy didn't do to well at whitwick, it somehow managed to cook the actuator motor and a relay in my battle switch so battle switch is now fixed and i have gone for a slightly lower rpm motor as i am aiming to get scruffy back to a 4s lipo to regain its speed and pushing power
my bw glitch did nicely but there wasn't much to fight and i now have plans to build a bw with 100mm wheels
on another note i have also started work on scruffy 3 and will probably have some ideas for scruffy 4 after gsl
