It looks more evil than before, which is awesome. I was wondering, where do you get your spikes and stuff from?
scruffy
i think i got pretty much everything off ebay apart from the tx
the horns are a small cut up crowbar and the spikes i put down the back of the lifter are goth/punk spikes im going to use the same setup as scruffy 1, 4-5 25mm long spikes down the back of the lifter but i also have some small 10mm spike that will be going in various places haven't quite decided where yet
i should probably have called it something like revenge of scruffy, scruffys revenege or scruffys demond
i will have to look for some stick on flame affect for down the sidesLast edited by plargen; 14 June 2013, 13:08.
been a while since ive updated but due to heat and laziness not really done much
scruffy 2 requires a few adjustments to the lifter a bit of wiring and the aesthetics to give it some more character
ive also started to look at building a beetle got the motors and decided to do a night fury like beetle probably with a servo lifter estimated top speed is round 7-8mph so should be nice and quick and i will probably be using a bolt together structure so i can easily change Armour and shift between the 1.36 and 1.5 weight variations
ive also started looking at my robot with chin/drill driven lifter again and have worked out that it will have a maximum lift of 30kg ish before the chain snaps so once i have to working i will do some weight tests and see if i need to upgrade to 8mm chain or if belts would be better but i cant find any info on the forces that the technobots belts can withstand
and lastly i have started to make base of the Dog/Growler style robot
haven't decided on the name yet thought of a good list but cant deside
hellhound
anubis
The Grim
gnasher
not sure if any are take, if so please tell me but if anyone has any other name suggestions please post them up
ok started my beetleweight, its a 4wd,
it has
4x 12v 1000rpm motors with 4 65mm wheels (which seem grippy), im using aluminium for the body and 3mm t6 aluminium for the side,front and rear armour i have a servo that i am aiming to use for some sort of lifting weapon but haven't decided on what yet, i have also got a turnigy nano tech 3s which will peek at 18a so i hope it will be enough to run the 4 25mm motors
it should do about 7.5mph hopefully have it ready for a test drive this weekend will post pics/vids etc later when its a bit further along
