Re: 360 - mini hypnodisc
How well do you think the lipo's will cope being so close to the motors as they heat up? The battery's themselves will also generate some heat. I can imagine it getting quite toastie in there when the shell is in place, specially with 6wd, grippy tires and the extra pull from the magnets. Is there any cooling planned for the bot?
The dewalts WILL heat up to very high temperatures ~ 70 - 80 degrees and more
