  • Re: 360 - mini hypnodisc
    its not a tx thing as such, it would drive the same way on any tx, it just feels better on a pistol grip
      got some parts for the new one
      Picked them up from an Aussie for $150Aus... not bad Also got a sidewinder, some 3.2mm hardox and some 5mm ti sorted for it. Just need some big billets of alumec89 now for the chassis, some ali bar to machine the wheels from and a lipo.
      Think I'm going to just keep 540 as a rammer for a bit to use at normal events- and to play with when 360 breaks down lol
      Not sure yet if i should go for 4WD or 6wd though.
        your bed sheet has flowers on it
          correction...
          My girlfriends bed sheet has dewalts on it
          Win.
            lol well my bed sheets got your 5mm ti and 3.2 hardox on it :P
              Done a little bit today with Ed.
              New disc centre compared with the old ali one which bent;
              fitted;
              and some wheel blanks cut out of some ali round bar.. will be 30mm widex80mm dia when finnished;
                Just as i found out im fighting Beauty in the uk's the postman nocked my door with a package from the states.. got my esc's back from repair... and feeling a bit enthusiastic i soldered on some connectors and got it going..
                The finished Re-wire job;
                Did two spinup tests, heres how they looked on the data logger;
                Somehow its over 500rpm faster then it used to be... More KE = more fun
                  see in your pic, i just brought a aerobee!! takes me back, i remember them from the 80's.
                  good luck dave, dont forget beauty 4 can go through losers melee, so take no prisoners!
                  sorry john but u had a good run :wink:
                    Does the speedo have a case to go over the top ?
                      Yeah its called armor :P lol
                        dave only takes a little bit of your dribble and your speedos wrecked, shud be in a case!
                          my dribble or westons dribble? Mines non conductive so its all good... Ill just leave the armor on in the pits..
                          Did think of putting a cover on it... but a) carnt be bothered b) there's no real point.
                            I think your going to have a tough battle with Beauty 2 and Toonimator.
                              Yeah I was impressed at the damage inflicted on your arena walls by Toonimator last year. I don't know if it was because the arena walls couldn't go anywhere (whereas a 13.6kg opponent will remove some of the sting of the weapon by being thrown away) but it's one I'm keeping my eye on.
                              360 turns quite nicely so could probably avoid taking damage to the more vulnerable parts of the robot, but then its unpredictability when it's gyro-dancing could see it accidentally hit Toonimator's disc with the rear of the robot. Having said that, with the magnet there will be less of the gyro-dancing so we could get a nice disc-on-disc moment. Definitely one to get on video - go Dave
                                toonimater what robots that?
                                the old beauty that the toon guys have? or is that stagefright
                                bin while since my last event im out the loop lol
