Drilling out a standard batterydrill pinion ain't an easy job. Pure hardmetal cutters are the least you need, and then the chances of succes are limited. The aussie forum has quite a few threads on that.
I myself prefer to make gearboxes with standard, affordable mod 1 gears.
The pinion I prefer is the steel Z12 Mod 1. You can buy those easy enough over the net.
