Which kit is that?
So I used one of these Traxxas Motor Titan 775 when I modded a GR02. Gimson were selling 5mm ID gears that fitted straight on
http://www.fightingrobots.co.uk/thre...ighlight=titan
You would have to mod the pin carriers for sure on the GR02 gearbox
The Magnum 775 looks a nice combo
Pretty sure this is the genuine Mabuchi 18v 775: http://www.adepem.com/PIECES-DETACHEES-119672.html
edit: yeah spec sheet seems a match for the advertised specs on the Banebots website for the RS775-18.
edit2: that French site says it's compatible with this drill: http://www.ebay.co.uk/itm/RYOBI-CHP1...item58984a2d56 - suggesting it might be a source of the right motor and the gearboxes could be put back on sale or butchered for the good bits?Last edited by Ellis; 30 April 2014, 11:31.
look slightly different to the banebots ones... these seem pretty close too;
http://www.aliexpress.com/item/775-h...311023187.html
sorry wrong link;
http://www.pollin.de/shop/dt/MTc0OTg...C785LP_HS.html
Tim did some maths.. apparently will give around 22% higher speed and pull less amps than the rs775.
