Is the Lipo pack just smaller, or smaller capacity as well? Seems to me that you need as many AH as possible to feed than monster weapon motor.
Which motor is it you use on 720? It's rather impressive to use only 2.5ah after the 3 minutes...
As for the new one too, it's looking pretty awesome. Bet those Colsons will help loads with the traction too! Is 720 sticking with it's current setup and everything, just going back to the old drum?
Both bots use castle creations neu 1515-2200kv motors... but there both customised with the front face plates removed, 10mm alumec fronts that key into the motor can with twice the amount of mounting bolts in the can than standard, with helicoiled threads, larger 10mm high speed bearings (up from the standard 5mm), custom shafts and a support bearing for the other end of the shaft thats pressed into the bulkhead... basically took them of the shelf and "combat hardened" them.
There great motors off the shelf... NST bent the shaft on mine slightly in 2013 so i went all out for 2014 and it worked great.
As a rule of thumb, In-runners are lower voltage and Higher KV and Out-runners are lower KV and Higher Voltage.
In-runners go up to about 8S max voltage where as a Out-runner will take 12S. However, In-runners can go as high as 5000Kv+ where as most Out-runners do 500-1000kv, only 10-20% of the In-runners.
This all of course depends upon their size. Scorpion have a HK-25 that does 3500kv, and a Turnigy 1015 can do 11'500KV. On the other end I have seen a liquid cooled in-runner as low as 620Kv and a Our-runner at a mere 168kv!
This has been Roseanne, your guide to the world of facts.
That's really interesting! I always assumed 720's motor had a much higher power rating as I need a Neu 2210 motor with almost twice the power to get Shiny's eggbeater spinning at the same or lower RPM. That's suggesting that eggbeaters are very inefficient and I might have to change to a drum in the future.
Wouldnt be suprised... wind resistance has a massive effect on continuous current draw.. all the air inside the beater will be wofting around causing a massive amount of drag.
The spinning OD has a large effect on spinup current aswell.. my drum is only 95mm tip to tip and the gear ratio is 3:1... quite high considering the OD of the weapon.
I spent more time deciding on weapon motor/ratio/drum weight when designing 720 than anything else and its worked out really well... the castle motor only gets what id consider luke warm after 3min of abuse, and now its combat hardened i wont be changing them.
not done much in ages…Life got in the way… going to start doing a bit more soon hopefully…
Thanks for Grant for helping me put my ideas into a CAD file that i can send to the laser cutters next week… ive lasered some cardboard templates to see what the hardox version will look like… 722's armour is a bit different to 720's…never really liked the spikes on the side, its not very refined… so spent some time coming up with the new shape which should also help in a few ways…. Card mockup;
Im happy with it, hardox is going to the laser cutters in the next few fays
