2012 FRA UK Featherweight Championships by RoboChallenge
Re: 2012 FRA UK Featherweight Championships by RoboChallenge
Bruiser 2 was worse than that with the spinning bar, so we didnt make it in the end and just made a wedge, but it's still to heavy amongst other things, like no speed controller or batterys, so it probably won't be running at the champ we will try and finish it, but probably won't he able to.
Drumroll and Carcinus are both ready to go. Pictures in the build thread: viewtopic.php?f=240&t=3285&p=131947#p131947
Carcinus will also have an additional weapon fitted when fighting Chuck. Not saying anything more than that, but it's all legal. The main question is: I wonder what will happen when an unstoppable force meets an immovable object? :wink:
Fitted Lf3 with a new flipper system but it is 1.5kg heavier than the old system so have lightened the
chassis today and wired it up. Shall put it together tomorrow and see how much armour i cant put
back on and then test the flipper if theres enough time.
Thats pretty neat, how are you expecting it to act compared to the CO2 system?
