2012 FRA UK Featherweight Championships by RoboChallenge
Re: 2012 FRA UK Featherweight Championships by RoboChallenge
I know there's still tomorrow and Thursday for info being published, but any word from anyone who's been at the NEC today regarding arrival procedure? Last year we had to go up to some car park in the middle of nowhere to get a pass to get through the barrier at the gate nearest the hall to be able to unload. Just wondering if it's a similar story this year and, if so, what car parks are the relevant ones?
On a side note, both our bots are combat ready and just require a final bit of paintwork. I even had time today to clean and prep my spare drill motors and other bits and pieces. I like being this prepared
EDIT: On another side note, got combat robots and the Gadget Show Live mentioned in a shout out on the radio this morning. Although with it being a small local station, it probably won't have served much purpose. But the DJ said she thought it sounded pretty cool :P
I don't know, but the NEC is always like that for exhibitors, you normally go the car park 12 to get a loading pass for hall 9 (where i had to go on Sunday).
Flows going to the champs un tested so hopefully be able to get it in the arena friday just to arm it up and get a test flip on low pressure. I dont know if the system is even air tight yet. Could do with a WB just to know if it can flip the weight of a featherweight on low pressure. Its got about a 99% chance of failure so it could be quite fun.
Ten robots go through from the qualifiers.
They fight in five 1-v-1 battles, leaving five winners.
The five losers go into a big mele with one winner, who rejoins the others, leaving six robots.
The six fight 1-v-1s again, with three winners.
The three losers go into a mele again, with the one winner joining the remaining three contenders.
Then it's just 1-v-1s for the semis, 3rd place play-off and grand final.
Spot on Jamie thanks.
Leonardo yes thats all no problem
If you wish to unload equipment at hall 9 door 9.1 you will first need to get a loading pass from car park 12. Head to Gate 3 on arrival and say you are unloading for the Gadget Show and they will direct you to car park 12. Please arrive early as it can be busy to get passes.
Any other questions just fire them thisa way. I will be at the NEC during the days but will endeavour to answer questions as soon as possible.
Is it possible at all to lathe hardox? We trashed two lathe heads and a milling cutter yesterday trying to lighten the disc!
Yes lighten, Conker is about 600g over weight and the only real place that we can take weight from is the disc, well maybe 300g, and then 300 in holes through out the bodywork
Not done anything to Explosion, apart from the light repairs around September it's exactly the same as last year
We did have a look at the transmitter though, and found that the aerial had been twisted near the end of it's holder, can't believe I've been driving it with such a low signal for two years (since the case snapped off)!
So, that means that it should be flipping perfectly. Over the past few events we increased the flipper's sensitivity due to stray flipping in both the feather and the heavy, but it did mean that sometimes pressing the button wouldn't cause the robot to flip. Not got that problem anymore .
Today we'll stop by David's to get our new batteries and charger (that came to £111!), and to get new plastic/armour. 6mm HDPE will keep NST out, right?
Right!?!?
Also going to pop by the Coopers' workshop to get our forks back into... erm... shape. Or a better shape, at least. The dented buckled broken look isn't quite to our taste.
Tormenta weighs 13.2kg (ish) according to our bathroom scales. Don't know what we'll do if we find it weighs 15kg. Wish us luck, were going to need it to get it battle-ready in time (and to survive said battles).
