2012 FRA UK Featherweight Championships by RoboChallenge
Re: 2012 FRA UK Featherweight Championships by RoboChallenge
Originally posted by Danjr1
Custom made 5mm steel wedge and two machined HDPE wheels
Okay, not many of us will have them lying around in our spares box :P
But looking at the last picture of Doorstop that you posted, could you not just put some tyre tread round your wheels and some more HDPE at the front (on the vertical bulkhead, rather than in the shape of a wedge) to absorb the majority of impacts?
Yes its a 26KW solenoid, in theory it wont be as good as the co2 system but havent tested it yet
with the flipper arm on and dont know how long it will last.
A while back I was looking into Solenoid alternatives to CO2 but ran into problems with stroke length being too short and the fact that the solenoid loses power as the arm extends further.
What sort of Nm rating has it got? I found I needed something like 2000Nm to contend with a FP flipper system.
I know this is short notice, but the new 12v NiMH charger I bought will only charge up to 2.8v.
I was wondering if anyone (probably best if competing on saturday) could lend me a 12v NiMH charger with a tamiya connector for the day? It would be really helpful, much appreciated.
Just tested the flipper, it self rights ok, might flip another robot out if its right at the edge of the arena
The stroke is only 38mm and the force should start at 180kg rising to 300kg at the end of the stroke with this design assuming that the lipos can supply it with 500a, may need to test different lipos at some point and increase the wire size and bigger connectors(they were warm after 15 flips).
Very nice Will, can't get much closer than that!
Car's packed, we'll be leaving shortly (once I've had some lunch). Good luck to anyone who is still building, and of course good luck to everyone competing. See you all there!
Having some RC issues, hoping someone can advise.
Our £2 V-Tail mixer (the ones that just say v-tail mixer on them) ruins our fail safing. The ESC that has the BEC just refuses to failsafe with the mixer in line. Using Electronize 15a.
Any ideas?
Alternatively we tried the Mixing built into our DX5E, which aside from the half throws is set up so that up and down on the stick is left and right, and left and right is forward and back.
Swap the channels or swap 1 motors polarity. If up and down on the stick goes side to side in the robot, one motor is going forward on command, the other is not. Swap that motors wires over.
As for the failsafe, can't offer any insight on that one .
