Mechanical Noise - Series 1
  • Mechanical Noise - Series 1
    No prizes as to who Ill be rooting for...
    HINT: Crash Bandi-bot still hasnt forgiven you Mr Spinny Guy.
      quote:
      Dont post the results juuuuuust yet Martijn, Ill be wanting to deal with this post tommorow. =P
      geez, how fast do you think I am
      and your vapours should make a cool addition Matty, thanks
        If Tengu generates approximatly 40 times the energy of a bullet, than if it hits something than it will have approximatly 40 times the energy of a bullet going into the other object, and a force forcing in the insides which could destroy electronics, assuming that all the energy from the spinning shell is taken out at that instant, without wastage due to friction/sound.
        So the moral of my story is...
        ...Go Flank Attack
        I love you with mouth.
          uhhhm... have you dealt with it yet?
            So then why has it worked fine in the last fight, and virtually every other fight Tengu has been in?
              Watch some videos of spinners similar to Tengu, youll understand how well the weapon will work then....
                Aaron, being unable to find any videos of FBSs like Tengu [SInce i dont know many that have Tengus power, or come close to it] Im confused. Are you saying Tengu WILL work, or that it WONT work?
                  Yeah, Im probably never going to get round to it. Go ahead.
                    Heat B
                    Heat Final
                    Flank Attack vs Tengu VII
                    3€¦ 2€¦ 1€¦ Activate!
                    As per usual, Tengu starts spinning up its feared spinning body. However, this time around his spinning body looks slightly different. With two aluminium wedges instead of a pair of spinning blades, Holt wants to wedge AND clobber his opponent today! Enough about Tengu€™s weapon though, MacWilliams seems to think and his impressive horizontal crushing machine box rushes towards the full body spinner. Tengu isn€™t at full speed yet, and attempts to get away from Flank Attack€™s attack. Overwhelmed by Flank Attack€™s high speed though, Holt can€™t avoid his spinner hitting the end of one of Flank Attack€™s pincers. Tengu€™s €œblade-wedge€ rams underneath Flank Attack and the crusher is knocked upwards, before it lands on its back. In the meantime Tengu managed to reach its lethal speed and comes in for an attack. MacWilliams tries to dodge, but Flank Attack is simply too wide to carefully dodge attacks like this, and his pincer takes yet another hit, and the machine is knocked over the top AGAIN! Serious dents can now be seen on this thick titanium pincer, but MacWilliams knows this is only superficial damage, and doesn€™t seem to be scared yet. Tengu seems to be up for another attack, but this time Flank Attack has more time to deal with it. Flank Attack faces its plow towards the full body spinner. Now without hesitation both machines accelerate. With a loud bang Tengu€™s spinning wedge blades hit Flank Attacks titanium plow. The plow is too low for Tengu to get underneath and therefore the impact propels Tengu slightly backwards (and heavily buckles Flank Attack€™s plow, but that goes without saying ). Only slightly though, since Flank Attack€™s concave shape makes sure Tengu keeps on rebounding against the pincersand the plow. Not happy with its current position, Tengu starts driving backwards, only to find out MacWilliams has already pushed his pincer button! Slowly Flank Attack€™s pincers come in and get a solid grip around Tengu€™s anti spinner ring. The ring is even denting under the pressure of Flank Attack€™s weapon, and the spinning body seems to slow down. Flank Attack now turns around and heads for the pit release button, with Tengu in its clutches. The pit starts descending when Flank Attack slams Tengu into the button, and surprisingly enough, the slam makes Tengu slip out of Flank Attack€™s grip! With Tengu out of his pincers, MacWilliam can now see the damage Tengu has done. His plow is buckled beyond recognition, and the pincers look rather ugly as well. The joint of one of the pincers is almost broken, which must be why Tengu slipped loose. Holt laughingly looks at the current status of his opponent, and tries to spin up his body once more. However, this time it€™s MacWilliams turn to laugh, as Tengu€™s spinning body hardly catches any speed at all. It€™s almost like the spinner ring being bend somehow jammed this spinning body (which is exactly what happened, dear readers). With it€™s body spinning at ~100 rpm, Tengu dashes away from Flank Attack, hoping it€™s still able of reaching a high speed, even though it€™s at a piss poor acceleration. MacWilliams doesn€™t want this to happen, and rushes towards Tengu, which skilfully dodges this initial attack. However Flank Attack turns around and has no problem fitting Tengu in its pincers now. Flank Attack accelerates again and finds Tengu stuck on its buckled plow now, giving Flank Attack a nice level of control over its opponent. Holt has a bad feeling about what€™s coming next and keeps all the buttons his controller has, but his attempts remain effortless. Filled with pride, MacWilliams ends his march towards the pit, watching how Tengu falls into it.
                    CEASE
                    Tengu VII meets the bottom of the pit
                    Flank Attack goes through to the semi-finals!
                    Coming next:
                    Heat C
                    Leprosy Infection vs Shovearound 2 vs Whirligig 4.0
                    Disco 5 vs Going Crunch vs Omniforce
                    Gimme your predictions, gimme your tactics
                      For refernce tengu is approximatly like typhoon at its maximum (never actually to my knowledge turned up to this point for safety) but this means it is perfectly plausible in terms of comparable real bots (unlike many other famous FBS)
                      Anyways, good fight, bad result lol, but a heat final is still good and I will avenge myself (mwhahaha and all that, lol)
                        Basically treat Whirligig as a mobile hazard, just keep slamming Leprosy Infection into it again and again and again and again. Whirligigs shell is very durable, so im pretty sure Leprosy Infection will die first, even if I do it with the weapon first, which ill only do if I have to, ill mainly get under it from the sides and the rear or front only if I have to.
                          Drive around, have some fun, push some things.
                            LEPROSYS TACTICS
                            Do NOT touch Whirligig. Spin the drum up to full speed, then keep hitting Shovearound 2 in any weak spot possible. If possible, try to keep in league with W 4.0. Not quite a team-up, more of a Please dont hurt me, I have a great respect for you kinda thing.
                              HEAT C
                              ROUND 1
                              1) Leprosy Infection VS Shovearound 2 VS WHIRLIGIG 4.0
                              ...um...spin up and hit anything that dares to cross my path?
                              2) Disco 5 VS Going Crunch VS OmniForce
                              Chris clusterbot could be in for a tough time against these two, especially with OmniForces manoueverability. Going Crunch to be going home
                              Cracking job, Marti!
                                My first heat final win! With a robot similarly resembling to Tough as Nails. Remind you of anyone? =D. Heh, nice result there Martijn.
                                Wow, first time against Tengu and everything is already falling apart. =P Better steal Steves plastic spanner then, for the repairs. =P
                                As for predictions...
                                Whirligig probably has the best chances here, since the other two are going to be going at it like all hellz. Of the other two, Id have to choose Shovearound, unless LI can get enough good hits that it bends up the lifter and eventually takes it out.
                                Disco 5 should easily go through here, taking out either Going, or Crunch with ease; Omniforce would handle the other one at the same time, and eventually both would go out.
                                (Message edited by Siphai on November 06, 2005)
