Mechanical Noise - Series 1
No prizes as to who Ill be rooting for...
HINT: Crash Bandi-bot still hasnt forgiven you Mr Spinny Guy.
). Only slightly though, since Flank Attack€™s concave shape makes sure Tengu keeps on rebounding against the pincersand the plow. Not happy with its current position, Tengu starts driving backwards, only to find out MacWilliams has already pushed his pincer button! Slowly Flank Attack€™s pincers come in and get a solid grip around Tengu€™s anti spinner ring. The ring is even denting under the pressure of Flank Attack€™s weapon, and the spinning body seems to slow down. Flank Attack now turns around and heads for the pit release button, with Tengu in its clutches. The pit starts descending when Flank Attack slams Tengu into the button, and surprisingly enough, the slam makes Tengu slip out of Flank Attack€™s grip! With Tengu out of his pincers, MacWilliam can now see the damage Tengu has done. His plow is buckled beyond recognition, and the pincers look rather ugly as well. The joint of one of the pincers is almost broken, which must be why Tengu slipped loose. Holt laughingly looks at the current status of his opponent, and tries to spin up his body once more. However, this time it€™s MacWilliams turn to laugh, as Tengu€™s spinning body hardly catches any speed at all. It€™s almost like the spinner ring being bend somehow jammed this spinning body (which is exactly what happened, dear readers). With it€™s body spinning at ~100 rpm, Tengu dashes away from Flank Attack, hoping it€™s still able of reaching a high speed, even though it€™s at a piss poor acceleration. MacWilliams doesn€™t want this to happen, and rushes towards Tengu, which skilfully dodges this initial attack. However Flank Attack turns around and has no problem fitting Tengu in its pincers now. Flank Attack accelerates again and finds Tengu stuck on its buckled plow now, giving Flank Attack a nice level of control over its opponent. Holt has a bad feeling about what€™s coming next and keeps all the buttons his controller has, but his attempts remain effortless. Filled with pride, MacWilliams ends his march towards the pit, watching how Tengu falls into it.
