EnigmaTek Series 1.01
    Looks like a good opportunity to test out the new Novastorm 2, and Bloody Tears 2.
    Team Name: Team Hitmen
    Representing: Oswego NY
    Dimensions: 80cm length, 80cm width, 30cm height
    Speed: 20mph
    Armor: 10mm titanium.
    Power: a 48v Perm powered by 2 Panasonics. FOr the weapon, that is. THe drivetrain is 4 S28 Magmotors at 48v.
    Motovation: 4 wheels.
    Weapon: The horizontil spinning bar has been ditched for a diagonal spinning bar at the front. This also required ditching of the hinged wedges. No big deal, as now it can self right via the rear lifter [Built inside the wedge, like Voltronic] It can also be used to lift oppoments into the bar if they try to approch from the rear. It wont help if the bar breaks and Novastorm 2 winds up on its side unhinged wedge, But that will rarley happen. The bar is also long enough to chip the side of a oppoment, sometimes. The lifter can lift 200kg.
    The bar spins at a high 4000 RPM, which can toss a thing or two around! It also weighs 10kg, and produces 80kjs.
    GC: around 3mm all around, 0 at the rear lifter.
    Turning Circle: Guess. What does almost every vapour have for this? Fine fine, 0.
    Strengths: Can now self right, powerful, speedy, well armored, can lift and push, good pusher.
    Weaknesses: Control might suffer a tad.
    Unsure if its legal or not...
    Name: Bloody Tears 2
    Weight: 100kg
    Dimensions: 100cm length, 60cm width, 20cm height.
    Speed: 25mph, with Omni-Directional drive.
    Power: 4 cobalt astroflights on 24v. Fueled by 2 Panasonics.
    Armor: 1cm hardox 600.
    Weapons: 4 weapons, all by penutumatics, and all run at 250psi. 4 2kg tanks are in here, by the way.
    The first is the punching rack inside the plow. its mainly made to scoop up oppoments, then see if I can toss them away any. Also might send anybody who charges head onto it right back.
    The first new weapon, proving this thing is made for defense, is the side stoppers, which is kind of two parts. The first part is two static hinged skirts with spikes on the top of it. The second is a metal sheet with spikes on the bottom that comes down quick, and can make a spike sandwich, not doing much damage but can fire quickly, and MAY be able to hold a enemy if they kep firing down, although more likley not than so. Rarley used for attacks, these are used to slow down rammer charges at the side or to clip a overpowered spinner from the side driveby. Only the front ones clamp down, so they cant work when inverted. There are two of them, one on each side.
    The final one, is that the rear hinged wedge has been converted into a rear CO2 flipper. It doesnt have too mcuh force, but is mainly used to stop any sneaky rammer attacks from the back and give them a flight plan instead. Also used to send overpowered spinners off course, and maybe go all over the arena and do massive damage to themselves. OOTAs are unlikley, but can happen aginst multibots or with a lucky fire.
    Also: All parts have a 5mm allunimum casing with severeal shock absorbers outside the casing to prevent rattiling on the inside, and if that wont help, then a steel wire binding all the compoments together will.
    GC: 0 at the plow, 0 at the side skirts, 0 at the rear flipper.
    TC: 0.
    Invertible: Yes.
    Strengths: Strong armor, hard to attack or do anything to, hard to push despite low torque, great anti-rammer and anti-overpowered spinner.
    Weaknesses: Not much for offense, leads to alot of boring fights.
    Unsure if thats underweight too, although I wouldnt be surprised if it wasnt.
      Got one right now, seeing as i designed it for Enigmatech, Love Bite V2.0. Stats when i find em
        Found them quick
        Robot Name: Love Bite V 2.0
        Length/Width/Height: 120/30/20
        Weight: 100KG
        Motivation: €œWheels/Legs/Shuffles€™ 4 inner wheels
        Speed: 30 MPH
        Weapon: €œWeapon type and specs€ Hydraulic pincers at 2000 psi, can damage light-moderate armour. At the front is a Firestorm type flipping arm, CO2 powered, really just a SRIMECH but it will get other bots over, not really meant to be an OOTA flipper seeing as it€™s speed and the pincers do most of the damage.
        Drive: €œMotors used and voltage, style of reduction€ Bosch motors at 36 volts, gear reduction
        Power: €œBattery type and Voltage & Amps€ 2 x 36 volts at 3 amp NiCD packs
        Armour: €œMaterials and thickness, method held on€ 4 mm hardox, welded.
        Ground Clearance: 3MM
        Turning Circle: 0M
        Notes: It is a double wedge with skirts around the two sides. The paint job is black with Love the Bite in red down the skirts. Muchos credit to Aaron for the help.
          save a space 4 me please
            Save me... 4 places as well. Damn FAR forums isnt working for me.
              save me a spot
                Alright, now that the crappy iPod software is off of the computer my internet seems to be up now.
                Team Name: Team Targeted
                Town Representing: Leiderdorp, Netherlands
                Robot Name: The Windmill
                Robot Concept - A circular robot with a spinning blade.
                Mass - 100 kg
                Weapons - A potent blade running at 1000 rpm, powered by 4 Magmotor for some power.
                Can it self-right - No, but it is invertible.
                Velocity - 18 mph
                Turning Circle - 0
                Ground clearance - 1cm underneath the front, 0mm GC for the skirts, 0.5mm at the back, without the skirts the ground clearence is 7mm.
                Skirts - Skirts around each wheel pod.
                Wheel Type - 5 inch wheels
                Motors - Four 4 Dustins, geared for speed.
                Body Shape - Like Nothing Youve Seen Before
                Armour - 6 mm Titanium skirts, 7mm Titanium armour all around, with 4mm aluminum frame.
                Colour - Orange, the color of the best country in the world! =)
                Summary - Thisll be cutting through more than wind...
                Strengths - Its pretty damn fast with an awesome blade, along with invertibility. Plus it has some good wedge protection.
                Weaknesses - If you can stop that spinner, and am faster than me, I might have a loss there.
                Picture -
                http://img289.imageshack.us/img289/7430/thewindmill8hk.jpghttp://img289.imageshack.us/img289/7...indmill8hk.jpg
                City Representing: Baltimore, Maryland, USA
                Robot Name: Malaria
                Robot Concept: Biohazard with dual hammers.
                Weight - 100kg
                Weapons - 2 Diamond tipped hammers; both of them powered by 2 Nitrogen bottles at 1000psi. Also a front small scoop, that is able to lift, although extremely weak.
                Self-Righting - Not invertible but can self-right using the axes.
                Velocity - 22mph
                Turning Circle - 0mm
                Ground Clearence - 0mm all around due to weighted wedges put at an approximated 30 degree angle. A small scoop at the front is also 0mm. Underneath the weighted wedges is a 7mm GC.
                Skirts - All around, except for a small slot at the front where a small lifting scoop is placed.
                Wheel Type - Six - 3 Hardox wheels with tracked, rubber coating.
                Motors - 4 - 4 Magmotors with a 3:1 gear ratio
                Body Shape - Rectangular.
                Armor - 7mm thick titanium wedges, 5 mm thick titanium body.
                Color - Yellow and Black; the colors of danger!
                Summary - Youd better have a cure for this disease, otherwise you wont escape.
                Strengths - Fast, manuverable, nice armoring, low to the ground, dangerous weapon and self-rightable.
                Weaness - If you get under it, its screwed.
                Picture -
                http://img8.imageshack.us/img8/3270/malaria1ni.jpghttp://img8.imageshack.us/img8/3270/malaria1ni.jpg
                (Message edited by Siphai on September 17, 2005)
                • #23
                  Beware I have changed Fireflys name to Enterprise.
                  • #24
                    here goes Ill just enter flippy 2 exactly the same as flippy except for spikes along the side and because of that it goes at 4mph
                    • #25
                      ..Tim, just give up. If you keep giving stats like that, youll NEVER be allowed in any tournys.
                      • #26
                        Entrants:
                        Wedge Devo
                        Seggy 4.2
                        Back 2 Rock 2
                        Malaria
                        The Windmill
                        Love Bite
                        Novastorm 2
                        Bloody Tears 2
                        Wolf
                        FireFly
                        Flipping Hell
                        HellMachine
                        Axe To Fall
                        Space for 3 more machine.
                        Ill start the draw as soon as they are all in.
                        • #27
                          Team Name: Team BriteSpark
                          Representing: Merthyr Tydfil, South Wales
                          Robot Name: Dennis The Menace
                          Length/Width/Height: 100 x 40 x 25 - 35cm (The height of the robot increases as you move from the front to the back).
                          Weight: 100KG
                          Motivation: 2 foam filled go kart wheels made of uber-tough rubber.
                          Speed: About 18mph
                          Weapon: The main weapon is a 20kg spinning drum, powered by 2 Huqsvarna 3120XP chainsaw motors. The weapon is capable of changing gears during a match. Originally, the drum spins at 2400RPM when geared down 10:1, but this can be increased to 2:1 at systematic intervals of 2 gearings (10:1, 8:1, 6:1, 4:1 2:1). The 4mm Titanium drum is fitted with 2 horizontal Hardox bars, welded, screwed and riveted on to avoid them coming off. These are designed not only to flip, but to rip off skirts and armouring. The drum can hit with over 10kJ of force when spinning at 2400RPM, and increases to an astonishing 243kJ when spinning at 2:1 gearing (12000RPM).
                          Drive: 24v Sinclair C5 motors.
                          Power: 4 x 24v NiCad batteries.
                          Armour: 5mm Titanium and Vanadium alloy.
                          Ground Clearance: 4mm all around.
                          Turning Circle: 0M
                          Notes: The robot is invertible, and is completely symmetrical when flipped, meaning the performance isn€™t altered at all. The robot€™s shape is basically a box, but with the height increasing as you move from front to the back. The robot has 2 thick Hardox spikes on each side, which means it can pass the passive weaponry rule, and these also stop the robot resting on its side. To stop it resting on its back, the rear of the robot is slightly curved.
                          • #28
                            what about my robot
                            • #29
                              Tim, just... go away.
                              • #30
                                Get it through your head, Tim: Your stats are more unrealistic than a armored bathtub driving through a wall, running over the Wicked Black Beast of- AAGH!, being flung at King Arthur and his men by crazed frenchmen, and then getting destroyed by the Spanish Inqusition. THATS why youre never allowed in any tournys. Hell, yours make Kustom look UNDERWEIGHT!
                                (Message edited by Swiss_tony on September 19, 2005)
