EnigmaTek 1.01
EnigmaTek is one of the leading manufacturers in combat robot parts, producing top quality ESC€™s, Motors and even custom CNC bot parts. The company makes an annual profit of $100 Million. As a Tax evasion technique, EnigmaTek has decided to spend some money into a Robotic Combat Competition. Reducing there Tax while increasing their sales (From all the damaged robots in the battles!)
An email arrives in your inbox, it reads:
€˜You have been officially invited to represent your local region (City/Town/Suburb) in the first EnigmaTek Qualifiers, where you have the chance to prove yourself to earn a place in the top 8 robots that will enter the EnigmaTek 1.01! Winning the EnigmaTek 1.01 competition pays a $1million cash prize! Take your chances against the best and enter TODAY!€™
You quickly race to the shed after reading the email, pulling the covers off your pride and joy sitting on the work bench; you lift the covers off and give it a last minute check over before loading all your tools and parts into your car. Your destination, EnigmaTek!
You arrive to find many other roboteers racing around a crowded pit bay. An official walks up to you and says:
€˜Competitor are we? You better fill out this form and look over these rules€™ He gives you a form to fill out and hands you a thick rule book.
You then open up the rule book to make sure your robot complies with the rules for the 100th time since building it.
EnigmaTek 1.01 *Battle of the Champions!*
EnigmaTek 1.01 RULES AND REGULATIONS
Weight:
Wheeled = 100kg (No Speed Limit)
Shuffler = 150kg (15KM/H Limit)
Walker = 200kg (10KM/H Limit)
Clusterbots = weight + 5% (Speed and Weight Limits Apply)
Pressures:
Hydraulic = 3000psi
Pneumatic = 1000psi (Nitrogen & CO2 only)
Spinners:
No more then 50% weight can be used in the rotating mass
No more then 8000rpm on any spinning weapon larger then 300mm diameter.
Weapons:
Each robot must have at least a passive weapon to compete ie: static spike (Wedges and scoops not included)
Clusterbots:
Maximum of 3 parts, All parts must be knocked out to be defeated.
EnigmaTek 1.0 JUDGING
No time limit, No Judges. A total fight to the death, you have to either KO an opponent or pit/OOTA to win a match. If your robot chews power, kill the opponent before you run out of power!
EnigmaTek 1.0 ENTRY FORM
Team Name:
City/Town/Suburb Representing:
Robot Name:
Length/Width/Height:
Weight: KG
Motivation: Wheels/Legs/Shuffles
Speed: KM/H
Weapon: Weapon type and specs
Drive: Motors used and voltage, style of reduction
Power: Battery type and Voltage & Amps
Armour: Materials and thickness, method held on
Ground Clearance: MM
Turning Circle: M
Notes: Anything you want to explain that doesn€™t fit in the above categories
You fill in the form and give it back to the official who leads you to a room with other roboteers. You stand patiently waiting for all the entries to be accepted and wait for your match to be drawn out.
Weight:
Pressures:
Hydraulic = 3000psi
Spinners:
Weapons:
Clusterbots:
Team Name:
Robot Name:
Weight: KG
Speed: KM/H
Turning Circle: M
