EnigmaTek Series 1.01
Team Name: Team Doomforall
City/Town/Suburb Representing: Geddington
Tengu Advance
Length/Width/Height: 65cm diametre, 50cm high
Weight: 100KG
Motivation: wheels, 4 small internal ones
Speed: 7KM/H
Weapon: Full body spinner running off of a C40-300 Magmotor, two 5kg, 5cm long, stainless steel blades which are attached directly to the chassis and protrude inside the robot. Geared down at the same ratio as whatever the normal tengu is, which I cant recall offhand.
Drive: 2 x Bosch 24 volts, er...someone do reductions for me as Im not exactly sure what I want
Power: Another thing Ill need help on.
Armour: 7mm aluminium-vandium alloy, bolted on
Turning Circle: 0M
Notes: err.... will this do? There is a srimech bar inset into the top of the robot, powered by 2 heavy-duty linear actuators. Additionally the spinner rign is present and correct, the robot is constructed so that directly above the blades the robot tapers inwards up to the top. Over this the ring is a carefully moulded aluminium sheet which is about 1% larger than the dimensions of the robot, and mounted on 18 castors (eight columns of 2 at regular intervals) The top plate of the robot is then attached over this acting a stopper to prevent it falling off.
Tengu Advance
Weight: 100KG
Speed: 7KM/H
Turning Circle: 0M
