Martyn's Robot Wars Series 5
  • #76
    Martyns Robot Wars Series 5
    I would build a real robot, but it will take a large amount of time out of my other jobs, its coming upto a busy time for music reviewers, and as each album takes a few hours to do the review for, it knocks down the time I have free. Also in that remaining free time, I have to do gardening, so hence hardly no free time.
    *Goes back to listening to new foos album*
    • #77
      I need stats from:
      Scott and Chris then i will be able to post the draw
      • #78
        if your waiting for scott to post his stats before putting up the draw, then you will be waiting until the cows come home
        • #79
          Indeed. There was a very good reason I said he couldnt reserve places in advance in my tourney
          • #80
            Scotts Gay?
            • #81
              That joke might have worked if it had any relevance, but seeing you just pulled it out of your arse...
              • #82
                Ccan i swap Squish for the new version called Squishiest? Stats below.
                Weight: 100kg
                Armour: 4mm Grade 5 Titanium
                Speed: 20mph
                Shape: Low wedge
                Weapon 1: A very powerful hydraulic crusher, with 14 tonnes of pressure at the tip.
                Strengths: Very powerful crusher and strong armour. Good pushing power and good speed.
                Weaknesses: Slow srimech.
                Ground Clearance: 0mm at front due to wrinkler device. 5mm at sides and 1cm at back.
                Srimech: It uses a set of Razer style wings.
                Notes: The robot is powered by 2 LEM130 Lynch motors running at 36v, giving 20mph top speed and pushing power equivalent to 18HP. The robot has 6 inner Vulcalore wheels, which give tremendous traction. The crusher itself is made from 4mm Hardox, with 300 weight reducing holes. It is powered by an M-Mac M40 Hydraulic Actuator running at 12v, which can give 14 tonnes of pressure. The actuator has already been used in Robotic Combat, so this robot is realistic. The tip of the crusher is coated in carbon, so it can rip through Titanium easily. For the weapon to function properly, the robot contains 12 x 9.6-volt NiMh Radio Controlled Car Batteries, each weighing 12oz.
                • #83
                  Danny, your actuator needs at least 115 Volts to be powered (From http://www.mmacactuators.com/techspecs.htmlhttp://www.mmacactuators.com/techspecs.html) and depending on whatever rules Martyn is using, the common Fra rules says either 36 or 60 volts max depending on whichever verison people read.
                  Just suggesting it
                  • #84
                    Well its time for the draw, i still need stats for five of your bots chris and need them before i can do heat a
                    Heat A
                    Pussycat (17) V Flaming Hell V Vampire Killer
                    SD IV (1) V Anarchy V Die-Ceratops Re-Invertus
                    Heat B
                    Archangel of the abyss (3) V tails V Supreme Glory Gamma
                    Mega verter (19) V dominator 2 V Sheer Hell
                    Heat C
                    Clawdius decimus murderous (5) V Firestorm 5 V Kali
                    Squishiest(21) V drilla killa 7 V hurricane hugo
                    Heat D
                    3 Stegs To Heaven (23) V cyclone force 2.5 V Mrs Brown, you€™ve got a lovely daughter
                    Giga Byte (7) V ripper V x terminator 3
                    Heat E
                    Storm 2 (9) V Tengu 6 V Death adder 3
                    Dervish // (25) V flipping hell V Hefty kick in the balls
                    Heat F
                    Fluffy (11) V Supernova V Orka MK 4
                    Battle raptor 3 (27) V Dallas D squared V Psyclonic
                    Heat G
                    Road Block (29) V mega masher 2 V hell€™s teeth
                    Killotine Evo (13) V Heir to black panther 4 V Ringwraith
                    Heat H
                    Wheely pure evil 2 (15) V leprosy infection V baldur gamma
                    Launch Pad (31) V automatic schmuck V tornado
                    Heat I
                    13 Black (16) V Juggerbee Pi V 4 swords
                    Diotor 2 (32) V phrizbee V Metalmorphosis
                    Heat J
                    Killertron (30) V Shovearound 2 V Salamander 3
                    Panic attack 3 (14) V spawn again V terror gear 2
                    Heat K
                    Typhoon 2 (2 V Wreck-tangle 2 V Tenderiser€™s revenge 2
                    Force Power turbo (12) V Manic Monsoon V Aka IDIOT
                    Heat L
                    MORD 2 (10) V Glasgow kiss V Sonic Boom
                    Chaos 2 (26) V Dr. Evil V Hell Machine
                    Heat M
                    Biohazard ( V Razer V Surround Sound
                    Whirligig (24) V Wedga Revo V The matador
                    Heat N
                    Wheely Big Cheese (22) V S3 V GeForce Evo 3.0
                    Disc-o-inferno (6) V Cassius 2 V Jaws of hell
                    Heat O
                    All scoop and no stab make Steve a dull boy (4) V Dantomkia V Helliant
                    SOR 4 (20) V Ze Newie V Insecticide
                    Heat P
                    Stratos-fear (1 V Darkestar V the nose 3.0
                    Wedge Devolution (2) V All Hell V Nova Storm
                    tactics and predcitions please
                    • #85
                      Go for pussycat, and rip it apart.
                      I dont wanna start anything here. Just get up to speed with both my thwacker and spinner and go berserk only when someones enough of a idiot to ram into me.
                      Send all four parts after Juggerbee, and try to destroy it.
                      Get under Killertron and ram it full speed into Salamander.
                      Heh, 2 bots of mine in the same heat. Have Spawny constantly flip Panic Attack, and then when its down, have Terror Gear 2 push it while having the drum nip away. When enough damage is caused, have the two gang up to push PA into the pit.
                      Go after Chaos 2, and If i can get under it, bring the saw down on it and leave it there until I can push him into a house bot. When he gets out, rinse, lather, repeat.
                      Ah shit... Well, uh, PIT WEDGE DEVOLUTION ASAP!
                      • #86
                        Heat A
                        errr....difficult to decide but i suspect a win for the reignign champion
                        Heat B
                        I like my chances here, spin and smash.
                        Heat C
                        Hore tricky, kali can outramn firestorm and its design is manouverable enoguh to be able to get udner the machiens, the trick is can i do anythign useful with them.
                        Heat D
                        Not a clue, althoguh knowing scot this machine will be fiendishly annoying.
                        Heat E
                        Dervish \// (25) V flipping hell V Hefty kick in the balls
                        Curses, tengu can beat storm as tengu is powerful enough to match typoon (well typhoons hypothetical max and therefore actually in practise much stronger)
                        Heat F
                        *shrugs*
                        Heat G
                        Well roadblock to get pummelled, hopefully the heir can holds its own against its fellow axe bot.
                        Heat H
                        Should be relativly easy, I dont think either can outpush me and certainly neither can damage me.
                        Heat I
                        Dont know much bout any of these vapours so i cant really say.
                        Heat J
                        Salamander should be able to decimate killertron with minimal difficulty.
                        Heat K
                        Forcepower or Tom to go through here.
                        Heat L
                        Another case of the dreaded shrugging.
                        Heat M
                        Could go most ways here.
                        Heat N
                        dunno
                        Heat O
                        dunno
                        Heat P
                        Try and take otu vulnerable parts of the machines. Please try to write without the track hatred that everyone round here seems to have.
                        • #87
                          The Usually wrong Predictions
                          Based on stats and not ability to RP...
                          ...soz, wrong area
                          Heat A - Vampire Killer
                          Heat B - I would say Alexs spinner but that will prob kill itself, so Mega-Verter
                          Heat C - Firestorm 5
                          Heat D - X-Terminator
                          Heat E - Storm 2, still the best rammer.
                          Heat F - Battle Raptor 3
                          Heat G - Killy Evo (WTF is Roadblock doing in there)
                          Heat H - Automatic Schumuck... Really Probabily the ulimate robot, One of the favourites.
                          Heat I - Either 4 Swords or Juggerbee Pi
                          Heat J - Shovearound 2 or Terror Gear 2
                          Heat K - 2nd melee will be hard to write, but it will either be Monsoon or Force Power.
                          Heat L - If its the 2nd Glasgow Kiss than it will win, but IIRC the 2nd generation is for Arca only, so it will be MORD 2
                          Heat M - Heat of Death - Biohazard or Whirligig, nothing can get underneath Biohazard, even Razer.
                          Heat N - GeForce Evo because of that Flipper
                          Heat O - Son of Ripper or Ze Newie, nothing else comes close to these two.
                          Heat P - Stratos-Fear, that flipper is still strong, and if its the revised Arca verison, than it will be another favourite. If not, Novastorm. Wedge Devo to crash out round 1.
                          • #88
                            Tactics!!!
                            Heat B
                            Archangel of the abyss (3) V tails V Supreme Glory Gamma: Here I will gang up with Tails and try to stop AOTA spinning up. If this occurs, I will try and get underneath AOTA, clamp down with the axe and pit it. Failing this, Ill attack Tails instead.
                            Heat C
                            Squishiest(21) V drilla killa 7 V hurricane hugo: This time, Ill go after drilla killa, and use it as a shield to protect myself from hurricane hugos attacks.
                            Heat D
                            GigaByte V1.5 (7) VS Ripper VS X-Terminator: Ill stick to attacking the sides of Gigabyte and Ripper, and AVOID RIPPERS FLIPPER AT ALL COSTS!
                            Heat E
                            Dervish \// (25) VS Hefty Kick in the Balls! VS Flipping Hell: Ill concentrate all my attacks on Flipping Hell.
                            Heat F
                            Battle Raptor 3 (27) VS Dallas D Squared VS Psychlonic: Ill go after Battle Raptor in this one, Psychlonic looks a bit too nasty to go after in round 1.
                            Heat H
                            Baldur Gamma VS Leprosy Infection VS Wheely Pure Evil 2 (15): Go after Leprosy Infection.
                            Heat K
                            a.k.a. I-D-I-O-T VS ForcePower Turbo (12) VS Manic Monsoon: The melee from Hell-ay! :sad: Ill just drive around slamming into things.
                            Heat L
                            Glasgow Kiss VS M.O.R.D. 2 (10) VS Sonic Boom: Ill go after Glasgow Kiss and try to loosen something inside.
                            • #89
                              QUOTE
                              Nothing can get underneath Biohazard, even Razer DaveO.
                              *Points DaveO in the direction of Voltarc*
                              Ill get the stats for AT LEAST DCRI and CF2.5 up ASAP.
                              • #90
                                But Voltarc isnt entered.
