Martyn's Robot Wars Series 5
  • Martyns Robot Wars Series 5
    Heat A
    Pussycat (17) V Flaming Hell V Vampire Killer
    Take out the No. 17 seed by ripping the wheels off, they are really vunerable to my cage, and the saw isnt much better, because the top of the robot can be knocked away and the saw smashed off ala Fluffy. Stats for Vampire Killer would be nice.
    Heat B
    Mega verter (19) V dominator 2 V Sheer Hell
    Dominator 2 is my main target, because the armour isnt as tough as it looks, and 13 Black, on which SH is based, got through it easy, so Im gonna aim to smash up Dominator. Stats for Mega Verter would be nice
    Heat E
    Dervish \// (25) V flipping hell V Hefty kick in the balls
    Shit. My arch rival and a V. nasty vert spinner. Whichever one I get under first, shove to the side wall and send it to Heaven before sending it to Hell
    Heat G
    Killertron vs Hell€™s teeth vs Salamander 3
    Rip up the wheely bin lid with the disc, failing that, use the wedge to beech him
    Heat L
    Chaos 2 (26) V Dr. Evil V Hell Machine
    Chaos 2 is vunerable to axes, and I designed HM to tackle the S3/4 champ to begin with, so that gas bottle is history. stats of Dr Evil would help
    Heat N
    Disc-o-inferno (6) V Cassius 2 V Jaws of hell
    Cassius 2s armour is crap, my jaws will go through that no trouble, so hes my main target, but I will try and avoid DOI if I can help it
    Heat O
    All scoop and no stab make Steve a dull boy (4) V Dantomkia V Helliant
    erm...Stats on AASANSMSADB please, my saws should make a mess of Dantomkia, butr not enough to immobilise it, so I will aim to go back to back with it and rip out the vunerable link
    Heat P
    Wedge Devolution (2) V All Hell V Nova Storm
    Wedge Devo is my main target, just gonna clobber anything that comes near me
      http://www.extremefightingmachines.co.uk/cgi-bin/discus/show.cgi?tpc=760&post=46786#POST46786http://www.extremefightingmachines.c...pc=760&post=46 786#POST46786
      all scoop and no stab
      NAME- MegaVerter
      SHAPE- Convex curving (outwards curving) wedge.
      COLOUR- Gold, with a silver flipper arm.
      WEIGHT- Somewhere close to, but under, 200KG.
      DIMENSIONS- 140cm X 80cm X 70cm
      SPEED- 7mph
      TURNING CIRCLE- About 10cm. Not overly drastic.
      GROUND CLEARANCE- Definite 0 at front, due to variable-pitch wedge flipper arm scoop, 0 on sides and rear with torsion-spring held skirts.
      ARMOUR- 1cm Ti/V alloy, with a 50 x 50 x 10mm steel box section frame.
      LEGS- Inside robot, 8 legs in a similar running setup to Anarchy.
      POWER- 2 B42-500 4€ MagMotors on 36V, producing a nice 45HP.
      WEAPONS- Big, very, very powerful flipping arm. Powered by three 120mm bore, 250mm stroke custom hydraulic rams powered by 750psi pneumatics (full pressure pneumatics), it produces around 10000KG of force!!! That€™s akin to 20 Wheely Big Cheese flippers. The flipper arm is made of 12mm Ti/V alloy with steel box section framework, and lifts to a 90 degree angle, meaning the top goes to 2.1m in the air. The launching capabilities of this flipper are enormous, enough to throw 100KG around 30-35m into the air. 6 2KG CO2 bottles feed the rams, and it can get 15 flips a fight.
      SRIMECH- The flipper arm has a 10cm x 10cm hole towards the top of the curve, from which a ram, similar to X-Terminator 2€™s SRIMECH, can extend to self-right it. The ram is powered by 150psi pneumatics, and has enough force to throw the robot back over, as I wouldn€™t dare try to use the flipper and put myself on Mars ;D
      NOTES- Enough force to throw a lightweight high enough that it would take out low-flying aircraft. ;D
      Scotts stats
      NAME- Stratos-Fear
      SHAPE- A sort of 4Wheel Drive Wheely Big Cheese.
      COLOUR- Stealthy Black and Grey
      WEIGHT- 100kg
      DIMENSIONS- (L) With Flipper: 155cm, Without: 62cm (W) With flipper: 124cm, Without: 26cm each wheelpod. (H) 26cm
      SPEED- 15mph, high acceleration
      TURNING CIRCLE- 0
      GROUND CLEARANCE- Dead zero at front, rising to about 1-2cm at rear.
      ARMOUR- 4-7mm RSP-707 T6, Dave found this, it has the same density as aluminium but is almost as strong as titanium.
      WHEELS- 4, 4wd
      DRIVE- 2 24v LEM130€™s, geared for good speed and acceleration, powered by 3 x 24v 3Ah NiCad battlepacks.
      WEAPON 1- 130cm pneumatic flipper. This thing is powered by THREE 420mm x 80mm full pressure rams, running off three nitrogen tanks, with one extra as a buffer. It has a travel of 115 degrees. This should comfortably launch another heavyweight far into the air, better than WBC due to the increased power and length of the flipper. 3000psi Nitrogen, or 1000psi CO2 powered.
      SRIMECH - Axlebot, therefore it€™s invertible and can€™t be flipped.
      SKIRTS- None
      NOTES- Could probably flip about a tonne, and launch a heavyweight far, far into the air. Possibly the first 4 wheeled axle bot? Due to the shock, can probably kill another heavyweight in one or two flips. Overflip is now redundant because the flipper flops over due to the hollow axle connecting the two drive boxes. The flipper rides the ground, and due to the speed and low, low angle can easily breach any skirts.
      SUMMARY- Prepare to be launched into the stratos-fear!
      STRENGTHS- THAT flipper, acceleration and speed.
      WEAKNESSES- Armour is sacrificed a bit for extra power.
      NAME- Glasgow Kiss
      SHAPE- Weirdly shaped, see picture.
      DIMENSIONS (LWH)- 86cm x 87cm x 22cm
      COLOUR- Groovy tie dye effect, dude! Like someone€™s been painting the sports centre€¦
      WEIGHT- 100kg
      SPEED- 15mph
      TURNING CIRCLE- 0
      GROUND CLEARANCE- 0 at front, 1cm elsewhere.
      ARMOUR- 5mm titanium. I can€™t weight check this, since Rhino doesn€™t like calculating the area of the body
      WHEELS- 4, sellotape type
      POWER- 2 x Mag S28-400€™s powered by 24v of 9Ah Nicads.
      WEAPON 1- Double headed axe, powered by two pneumatic cylinders at 1000psi CO2 on a rack an pinion system
      WEAPON 2-
      SRIMECH - Of course, with the axe.
      SKIRTS- None, due to curved sides.
      NOTES- Each axe-head is different.
      SUMMARY- A spiritual replacement of Axe Murderer.
      STRENGTHS- That axe.
      WEAKNESSES- Could be flipped by an agile flipper
      NAME- We€™ll buy you a new one tomorrow, Mrs Brown
      DIMENSIONS (LWH)- 100cm x 66cm x 14cm
      SHAPE- Invertible box type clusterbot
      COLOUR- Unpainted aluminium
      WEIGHT- ~100kg, 50kg for each
      SPEED- 15mph
      TURNING CIRCLE- 0
      GROUND CLEARANCE- 0 at front, 5mm elsewhere
      ARMOUR- 10mm 2014A Aluminium
      POWER- 2 x 24v LEM130s powered by NiCads
      WEAPON 1- Linear Actuated lifting arm
      WEAPON 2- Linear Actuated lifting arm
      SRIMECH - Maybe with the lifters, invertible
      SKIRTS- None
      NOTES- Each can lift and push 200kg
      SUMMARY- Wham, bam, thank you Ma€™am!
      STRENGTHS- Teamwork, pushing power.
      WEAKNESSES- Each is only half the weight of a heavyweight.
      NAME- Lunch Box
      SHAPE- Sortof sculpted wedge
      COLOUR- Black and Flamey, since its so hot
      WEIGHT- ~100 kg
      SPEED- 15mph
      TURNING CIRCLE- Absolute 0
      GROUND CLEARANCE- 0-5mm
      WHEELS- 4, inside
      POWER- 2 x Mag S28-400€™s, driven by a worm gear reduction, then a chain, at 36v
      WEAPON 1- Full Pressure front hinged flipper, powered by two big rams and two CO2 tanks. Going for the OOTAs baby, yeah
      WEAPON 2- Secondary rear scoop
      SRIMECH - But of course :wink:
      SKIRTS- None, for manoeuvrability
      NOTES- Inspired by Launch Pad, in both name and weapon depts.
      SUMMARY- A mobile launching pad, going for OOTAs, front hinged style
      STRENGTHS- Strong flipper, backed up by decent drive.
      WEAKNESSES- Short fights are probable.
      NAME- Hefty Kick in the Balls!
      SHAPE- Reminds of Cerberus in S3 or 4, I think. Tapered rear with front scoops.
      COLOUR- Grey, with Scottish flag scoops.
      WEIGHT- 100kg
      LENGTH- (L) 78 cm without disc, 151cm including skirts and wheel pods, (W) 105cm without, (H) 23cm without disc, 76cm with disc.
      SPEED- 15mph
      TURNING CIRCLE- 0
      GROUND CLEARANCE- 0 at front and skirts, 1cm everywhere else.
      ARMOUR- 5mm titanium, 12mm titanium front
      WHEELS- 2, interior wheels.
      DRIVE- 2 x 36v Mag S28-400s
      POWER- 4 x 36v Battlepacks
      WEAPON 1- 75cm vertical disc, powered by two LEM130s at 36v, which spins at 2000rpm. Instant spin-up time.
      WEAPON 2- Like you€™ll get past the first.
      SRIMECH - None, though my driving, the skirts and the will ensure it doesn€™t get flipped. Actually it could possibly do an IG-88 due to the speed of the disc and the short length of the body.
      SKIRTS- Side skirts, hinged.
      NOTES- Should easily destroy a lot of bots and the scoops can both aid get under a lot of flippers and fend off other robots€™ weapons
      SUMMARY- Destructive, indiscreet and designed to give the other bot a hefty kick in the balls!
      STRENGTHS- Weapon, stylishness, and scoops
      WEAKNESSES- Armour kinda sacrificed for extra weapon power.
      NAME- Insecticide
      SHAPE- A rounded main body with exterior sidepods
      DIMENSIONS- (LWH) 122cm x 132cm x 21cm
      COLOUR- Sleek dark grey
      WEIGHT- 99.42kg
      SPEED- 15mph
      TURNING CIRCLE- 0
      GROUND CLEARANCE- 0-1 cm
      ARMOUR- 4mm titanium for main shell, 5mm titanium for the sidepods
      WHEELS- 2, each in its own pod.
      POWER- 2 x Mag S28-400€™s at 36v, 4 X 36v 3Ah NiCad packs
      WEAPON 1- A 16kg, 66cm diameter horizontal disc, powered by a Briggs and Stratton E-Tek motor at 36v. This spins at approximately 1500rpm due to the 7:11 gear ratio and is 4cm off the ground.
      SRIMECH - Invertible, due to a Scottish flag invertibility bar at the rear.
      SKIRTS- None
      NOTES- My personal favourite of my renders
      SUMMARY- Destructive disc backed up with decent drive.
      STRENGTHS- That disc, agility
      WEAKNESSES- It isnt painted red, and you know, red is the fastest colour, so it isnt the fastest robot of that exact same speed.
      Tony stats
      Weight: 100kg
      Armor: Each spike is 4mm titanium. The side guards are 10mm titanium. the rear plow is 8mm allunimum. Each disc is made out of 10mm titanium. The framework is 9mm alluniumum. The actual armor is 12mm lexan.
      Speed: 18mph
      Dimensions: LWH in centimeters: 140/50/9
      Ground Clearence: Overall 5mm, but at the rear plow, 0mm
      Power: Disc by a etek, drive motors by Astroflights, 4 nicads for 96 volts.
      Weapon: 12kg spinning discs with a 180 diameter spinning at 2700 RPM.
      Invertible Yes
      Strengths: Strong and fast
      Weaknesses: Poor armor
      http://www.geocities.com/wrwf2004/VampireKiller_P2K.jpghttp://www.geocities.com/wrwf2004/VampireKiller_P2K.jpg
      Weight: 100kg
      Armor: The framework is 7mm hardox. The outer shell is made out of 8mm hardox. The forks are about 100mm long and are made out of 13mm allunimum. Each hinged skirt is 7mm titanium.
      Speed: 25mph[geared towards acelleration]
      Weapon: Lifting forks
      Srimech: Invertible, so whats the point?
      Dimensions in centimeters [LWH] 140/60/5
      Power: Driven by Astroflights, it uses 4 12 volt battlepacks, giving it 48 volts total.
      Ground Clearence: 0mm around the hinged skirts, 0mm at the front of the lifting forks.
      Strengths: Fast, low, well armored, a great all-around pusher.
      Weaknesses: below average torque, completly useless in a arena with no hazards
      http://img27.exs.cx/img27/2657/shovearound21pm.jpghttp://img27.exs.cx/img27/2657/shovearound21pm.jpg
      Name: Terror Gear 2
      Speed: 18mph [geared towards torque]
      Armor: 9mm steel frame, 8mm steel hinged wedges, rear thwack arm is 10mm steel, drum is 8mm steel. Armor is 12mm lexan.
      Dimensions: LWH in centimeters: 150/50/8
      Ground clearence: 0mm at hinged wedges, 5mm evrywhere else.
      Shrimech: No, but is invertible.
      Power: Drum by a etek, driven by 4 magmotors. 8 battlepacks for a total of 96 volts.
      Note: Wheels arent as wide as they look, despite what it looks like, the drum DOES go past the hinged wedges.
      Weapon: 9kg spinning drum thats about 80mm in diameter and is about 50mm long. Spins at 2500 RPM.
      Invertible: Yes
      Strengths: Can push around oppomens while they hit the drum, great speed and weapon.
      Weaknesses: Average armor, can lose control pretty easily.
      http://67.18.37.15/1242/23/upload/p1230428.jpghttp://67.18.37.15/1242/23/upload/p1230428.jpg
      Name: Hurricane Hugo 4
      Weight: 100kg
      Speed: 30mph
      Shape: Triangle
      Weapon RPM: 2500, weighing 20kg
      Weapon: Ring Spinner with 3 hammers connected together for extra sturdieness, combined with a Y-Drive thwack.
      Motors: 3 magmotors with rubberl wheels for drive.
      Armor: 8mm hardox for frame, 1mm pexiglass for armor, 10mm titanium for each hammer.
      Dimensions[LWH in centimeters]: 170/90/5
      Strengths: VERY deadly
      Weaknesses: Next to no control.
      http://img57.echo.cx/img57/8687/hurricanehugo49ks.jpghttp://img57.echo.cx/img57/8687/hurricanehugo49ks.jpg
      Speed: 17mph [geared towards torque]
      Armor: The frame is 8mm titanium. Each hinged wedge is 10mm titanium. The blade is 12mm titanium. The armor is 9mm lexan.
      Dimensions: LWH in centimeters: 135/35/7. Blade is about 100mm long.
      Ground clearence: 0mm all over the skirts. 5mm when the skirts are knocked off.
      Power: Blade powered by a etek, driven by 4 magmotors. 4 nicads for 96 volts.
      Notes: THe blade has a mix of torque and speed.
      Not invertible, cant self right, but try flipping it in the first place.
      Weapon RPM: 2200 geared for torque
      Strengths: VERY Low, can get under things and push them while the blade hits them for lots of damage, hard to damage.
      Weaknesses: Dead if flipped, armor isnt the greatest.
      http://67.18.37.15/1242/23/upload/p1228336.jpghttp://67.18.37.15/1242/23/upload/p1228336.jpg
      A cluster of four robots, each linked together with wire, trashed when one of the bots spins thier weapon up.
      The robots [All Lightweights] are:
      Excalibur
      Ragnarok
      Masamune
      Murasame
      Weight: 25kg
      Speed: 10mph
      Weapon: 1600 RPM spinning vertical disc at 5kg with about 120mm of a diameter.
      Power: 4 S28-150 Magmotors geared at 17:1, 4 4400N Polyquest LiPoly Packs that have 14.8 volts each. Weapon runs on a DeWalt 24v Hammerdrill Motor.
      Armor: About 8mm alluminum for the armor, 12 mm for the frame, and the disc is about 5mm titanium.
      Dimensions[LWH in centimetrs]: 80/60/7
      Invertible: yes
      Strengths: Fast and well armored
      Weaknesses: Weapon is only above average.
      Notes: Wheels are a tad further back than in pic.
      Weight: 25kg
      Speed: 4mph
      Weapon: Full body spinner. The bot spins at over 2400 RPM, and weighs 10kg.
      Power: 4 Astroflight 940P Geared Motors at 15:1 Batterys are 2 Powersonic PS-1250 F1 12V 5.0ah. Weapon is a GX4 102mm (4) Motor.
      Armor: The armor is 10mm titanium. The frame is 1mm pexiglass. The teeth are 8mm titanium as well.
      Dimensions[LWH in centimeters]: 70/50/8
      Invertible: no, but can self right
      Strenghs: Strong, and hard to rip up the shell.
      Weaknesses: If you can SOMEHOW get underneath it, its dead due to the next to no armored frame. Also slow as hell.
      Weight: 25kg
      Speed: 8mph
      Weapon: Ring spinner at 2200 RPM, weighing 8kg.
      Armor: 8mm alliminum for the armor, 1mm pexiglass for the frame. about 6mm ti for each tooth.
      Power: 4 Astroflight A40P75B Geared Motors at 15:1 for drive. about 8 Powersonic PS-640 F1 6V 4.6ahs for batteries. The spinner is powered by a EV Warrior Motor.
      Invertible: Yes
      Dimensions[LWH in centimeters]: 70/70/6
      Strengths: Hits fast due to grinding weapon with good torque, good speed.
      Weaknesses: Armor! WHAT armor?!
      Weight: 25kg
      Weapon: 6kg spinning horizontil disc that is 150mm in diameter and spins at 1800 RPM.
      Speed: 9mph
      Armor: 9mm lexan for the armor, 8mm allunimum for the frame. The disc is 8mm titaninium, and the skirts are basically just hinged 6mm 11€ x 8€ Hexcel Texalium/Carbon Fiber Hybrid Sheets.
      Power: 4 S28-150 Magmotors and a EV Warrior for the disc. 3 Powersonic 12 volts.
      Dimensions[LWH in centimeters]: 90/70/8
      Invertible: Yes
      Strengths: Pretty well rounded
      Weaknesses: Kinda low armor.
      FINALLY! I got the stats done..
      Piccy: http://img224.echo.cx/img224/4206/4swordsfortony3br.jpghttp://img224.echo.cx/img224/4206/4swordsfortony3br.jpg
      Weight: 100kg
      Speed: 22mph [geared to torque]
      Chassis shape: 2 wheeled wedge[voltronic], with the arm for each chassis able to clamp on a robot. Wroks excactly thesame inverted.
      Weapon: Torquey SOB-like disc at about 2000 RPM.
      Armor: 10mm lexan for the armor, 12mm titanium for the frame, and the disc is 9mm hardox with a diamond edge for extra cutting strength. 6kg flywheel at about 100mm in diameter. The arm taht makes it lift either forwards or backward, depending on if it is invertible or not, is about 9mm tungstein.
      Dimensions[LWH in centmieters]: 150/80/8
      Power: Magmotors for drive, 2 rubber wheels
      Strengths: Very pushy, disc has alot of torque so it can contiue grinding to cause alot of damage. Quite fast as well.
      Weaknesses: About average armor, disc isnt THAT strong.
      http://img38.echo.cx/img38/2818/dr4te.jpghttp://img38.echo.cx/img38/2818/dr4te.jpg
      Spawn again
      now that is sorted also not to dave.w i wrote your fight for heat a before i saw your tactics
        Hence the reason why for a decent gap between the draw and the first fights, to allow all the slow people to post tactics.
          nuts Oh well, Ill have to wait and see how that turned out
            Well its time for another series of Martyn€™s robot wars and today sees the first 6 robots of the series battling it out for the first place in the series semi finals.
            Pussycat (17) entered by Aj is back for a 5th crack at the title, once again it€™s the sorta box with triangle on top shape, and it has the twin discs as well, part of its blade is carbon coated so it can easily rip into titanium armour. However pussycat has high ground clearance and doesn€™t have great pushing power
            In series 1 it lost in round 2 to eventual runner up disc-o-inferno
            In series 2 it got to the semi finals defeating 4th seed ReSpun along the way, but lost its round 4 match to panic attack (13) and then lost in the losers melee to disc-o-inferno and the nutcracker
            In series 3 seeded 10 it reached the heat final but lost out super spin dash
            In series 4 it went out in round 1
            Flaming hell entered by Dave. W is a circle bot with a bit on top to hold its powerful SoW style cage spinner which has €˜bot openers€™ to smack into the opponents, it has small actuators to selfright on the cage, however its hard to control where the robot will go after smacking into an opponent.
            Vampire Killer entered by tony, it€™s an invertible box, with two powerful front spinning discs one on top of the other, it has 4 spikes on each side and a rear scoop. The robot is very destructive but its armour is poor.
            Pussycat (17) V Flaming hell V vampire killer
            House robots: Dead Metal and Cassius Chrome
            3.2.1.ACTIVATE
            All three robots start to spin up their own spinners. Pussycat charges in at the side of vampire killer, smacking the blade onto one of the titanium spikes ripping it off. Flaming hell charges at vampire killers front causing both robots to fly away. Vampire killer goes after pussycat smacking into the front and pushing the 17th seed into the corner with dead metal. Dead metal grabs the cat and lowers the saw into it. Dead metal lets go of pussycat who smacks into the arena disc activate button. Vampire killer smacks into the rear of pussycat leaving its mark with a rip in the rear of the cat. Flaming hell charges over smacking in to the two robots causing all three to go flying. Pussycat is the first to recover and smacks into the side of vampire killer the blade ripping into the lexan armour. Flaming hell smacks into the front discs of vampire killer, flaming hell bounces back as the top disc on vampire killer grinds to a halt. Pussycat backs off the side of the newcomer only to charge in again and smacking into another spike easily bending it down. Flaming hell activates the pit release thingy, but is rammed into the arena by the scoop of vampire killer. Pussycat smacks into the side of vampire killer ripping into the lexan armour. Flaming hell moves into the centre of the arena to spin up again as vampire killer pushes pussycat towards the pit, but the 17th seed wont be put down that easily and escapes. Flaming hell comes over and smacks into the side of vampire killer knocking it into Cassius chrome€™s cpz. The shimmy bot starts firing its spikes rather pointlessly on the newcomer. Meanwhile flaming hell is chasing pussycat and clips the rear wheel sending the cat sideways and onto its side, pussycat quickly gets back on its wheels quickly. Vampire Killer escapes the cpz, but pussycat is there to smack into the side of the spinner bot. Flaming hell not wanting to miss out on the action comes in and smacks into vampire killer sending it spinning away. Pussycat smacks on the top of vampire killer who tries to escape but cant. Pussycat backs off but vampire killer isn€™t moving any more. Refbot comes over and nudges the mrws newcomer but it still doesn€™t move, refbot raises his hand and starts to count out vampire killer 1.2.3.4.5.6.7.8.9.10. Dead metal comes over and grabs vampire killer and drops it down the pit.
            Vampire Killer, killed off quickly.
            Pussycat (17) and Flaming Hell go through to round 2.
            In the pits its is found that pussycat chopped through Vampire Killer€™s aerial causing it not to respond.
            Fight 2
            SD IV (1) V Anarchy V Die-Ceratops Re-Invertus
            SD IV (1) entered by Steven it€™s shaped rather much like tornado except the rear goes to a fine point, on the front is a pussycat style saw €˜sept its larger and horizontal. The scoops from last year are gone. Its tornado like pushing power and powerful weapon took it to the gold medal last year.
            In Series 1 it lost out in round 2 to under force
            In series 3 it reached the series semi finals taking out chaos 2 and pussycat
            In series 4 it won the tournament beating out Battle raptor 3, Frost byte (3), NSBFR, series 3 champion spinny thing recharged and the crashing bore to become champion of the 4th wars
            Anarchy is a walking box with front scoop and rear flipper, it also has an axe which smacks down onto the robots in the scoop.
            In series 1 it lost out in round 1 to under force
            In series 2 it lost in the heat final to force power
            Die-Ceratops Re-Invertus entered by chris is basically a wheely big cheese clone with inner wheels, this means it has a powerful flipper and runs inverted.
            House robots: Shunt and Matilda
            3.2.1.ACTIVATE
            All three robots head into the centre of the arena, anarchy looking a bit ponderous walks over to Die-ceratops but the newcomer slips under the front of anarchy and flips sending anarchy up into the air and onto its head, can anarchy self right, the veteran fires its axe it just tips anarchy back onto its legs, SD IV charges at the rear of anarchy but it goes up the flipper, anarchy fires the flipper and sends the reigning champion over but back onto its wheels. SD IV charges at the pit release thingy, the siren sounds. Die-ceratops slips under anarchy€™s front scoop, the veteran fires its axe but it doesn€™t reach the newcomer who flips sending the walking box over. Anarchy twitches but neither weapon seams able to right the robot. SD IV charges in and pits anarchy,
            Cease
            Anarchy didn€™t cause to much chaos and falls at the first hurdle
            SD IV (1) and Die-ceratops re-invertus.
            Before round 2 its time for a special event and it€™s the first round of our all stars tournament
            Funky Cow Eater 2 V Archangel of the abyss V Disc-o-inferno V Giga Byte
            Round 2 draw
            Die-ceratops re-invertus V Pussycat (17)
            SD IV (1) V Flaming Hell
              Crap. First bot out. Oh well, always next heat. And always next series for Vampire Killer, I better toughen up the armor.
                You do know Titanium doesnt rip like paper when hit by carbon right. Frank told me.
                Shame the fight was decided once more by the house robots, no driving skill required at all, and did you know that controlling a wheely big cheese style front nose is very hard, hence why Chaos beat it time and time again.
                *Inserts ilfamous sign-off phrase*
                  Dave, must you critize FRA EVERY chance you get? Really, I havent even been here that long, and your anti-FRA posts are gettingon my nerves. Im still disapointed youre leaving, but is it absolutly nessacary for you to be like this beacuse of it?
                    *minor standing ovation*
                    You catch more flies with honey than vinegar, Davey Boy... :wink:
                    HEAT A
                    ROUND 2
                    1) Die-Ceratops ReInvertus VS Pussycat (17)
                    I think a recreation of the cats fight with StratosFear in PTT4 could take place here...
                    2) Flaming Hell VS S.D. IV (1)
                    Were both round about the same speed, so Spin Dash should be able to catch Dave and ram him around a little before attempting a pitting. The good thing about cage spinners is their relatively poor traction, so this shouldnt be much of a problem and hopefully, the cage will do little to my Hardox armouring.
                    Prove me wrong, Mr Weston!
                      Im not critizing the FRA, if it wasnt for them, than vapourbots would have ended 18 months ago when the robot wars forum shut down.
                      Im just saying my opinion, and if you dislike my opinions then fair enough, but its a human right to have the right to make an opinion. If you remove the right to make an opinion, then you turn the area into a controlled zone.
                        Unfortunately its also our human right to get annoyed with said opinion and ask you to cease being so vocal about it.
                        Anyway, for the Ti/carbon answer, look at Pussycat vs Dominator 2 in series 4. Dominator took numerous blows from the blade, and while whatever was holding the base to the armour was broken, the armour most certainly wasnt torn to ribbons.
                          Dave I have two words for you, the first being shut, the second being up, you have made yourself perfectly clear on your stance as to this which is fair enough, but you peresist in disrupting everything else, Im pretty sure theres a human right along the lines of the right to go about your business without beign harassed.
                            But remember, Pussycats weapon isnt excactly Nightmare-ish.
                              ** You do know Titanium doesnt rip like paper when hit by carbon right. Frank told me. **
                              Franks an expert metalurgist now Frank, whats going to happen when my Swedish Fire Steel is hit by an Aluminium Carbide tooth with a petroleum based lubricant on the tooth?
                                Itll catch fire because when the steel and aluminium crash into each other, a spark will be created causing the petroleum based lubricant to catch fire.
