Martyns Robot Wars Series 5
Cheeky boy system has 12 legs i think, itll probably fll voer or strumble with only 8 so there
Also I think with such minimal power in your mobility you wont be able to move at all. You expecting Two standard wheelchair motors, at 12 volts power the legs to move. to work. I use magmotors at 36 to get archangel moving, that poer had to go through all the cams in the legs and i doubt what your suggestign would be adequate.
Let me just do a quick weight breakdown, and this is the non techie here
engine - 40 kg
shell - 20kg
chassis - 74 kg
claws: there are six of which so, as for exampel the mortis axe blade weights 3kg, assuming its half the weight of that we get 9kg for puny blades
a starter motor, lets be generous and say there weight 3kg
same again for the wheelchair motors
That 152kg, which means your trying to fit batteries, the legs of the machines, the skirts and the fuel tank into 48kg. Considerign scuttle b2 (anarchy without the armour or weapons) weights 100 that just aint gonna happen, especially seeign as the design of the cheeky boy system requires large feet.
engine - 40 kg
shell - 20kg
chassis - 74 kg
