crazy bots series 1 (the remake)
  • Re: crazy bots series 1 (the remake)
    Lol...
    MORE IN-DEPTH TACTICS:
    From what I can tell, 1-hit Wonder and Surgeon General are the toughest bots in this battle. Bigger Brother is very susceptible to external damage. Couple that with a massive increase in KJs of energy, and I'll be able to kill Bigger Brother with 1 or 2 hits. If he tries to get his flipper under me, my teeth will tear his flipper arm off its hinges.
    Then go after Kody. He may have a good disc, but one hit from my spinning rim will probably tear it right off. Once the disc is gone, hit the side and try to immobilize its drive. Once it's immobilized, attack any house robots that try to attack it.
    Hit Obsidian from the side. Try to immobilize it. My top and bottom panels can survive his axe, but I don't want him to hit one of my legs, for fear that he could immobilize it. Try to take Obsidian out with the rim as quickly as possible.
    If Kody wants to team up with me, then use my tactics against Bigger Brother and Obsidian. If Jack wants to team up with me, use my tactics against Surgeon General and Obsidian.
    However, if neither of them want to team with me, then kill both of them, leaving Obsidian to be killed in round 2.
      lets begin heat f
      volde vs terrorhurtz vs skull vs envy
      3 2 1 activate
      envy starts us off by flipping thz over but self righting, now volde comes in and uses its axe and claws to trap skull in as
      it is lifted clear into the air as envy hits the pit release, thz comes in and hammers away at skull, who is trapped in the
      air, now envy comes in and flips terrorhurtz over, now volde drops skull into the pit as envy flips volde over but volde
      self rights with the axe and clamps thz but envy flips volde over who lets go of thz who self rights and smacks into envy
      BANG BANG SMASH volde has self righted and is now hitting envy, now the 2 pushes envy into the ppz where shunt is
      lurking but envy flips shunt over, now thz gets its axe jammed into envy as volde hits its axe into thz and drags it back
      over the pit, now thz is dangling over the edge as volde gets its axe out of thz and it falls into the pit CEASE
      1 hit wonder vs surgeon general vs bigger brother vs obsidian
      3 2 1 activate
      1hw gets its spinning ring up to full speed as surgeon general slices into bigger brother, as obsidian goes after 1hw and
      BOOM 1hw slams into the wall as obsidian lands on its back, now bigger brother flips surgeon general up but not over as
      1hw spins up again and hits obsidian BOOOM obsidian sent flying across the arena with all of the top and left hand side
      armour ripped of and lands on the pit as 1hw, which has just escaped landing out of the arena, spins back up to full
      speed as surgeon general cuts and rips off the back panel off bigger brother as 1hw hits bigger brother and both are
      sent rocketing out of the arena, hitting the reinforced armox that protects the fans and back into the arena the right
      side up, but it seems that bigger brother can only drive on one side as surgeon general rips off another bit of armour
      now bigger brother is dead as the refbot comes in to count them out 1 2 3 4 5 6 7 8 9 10, 1hw, who is now through to
      the next round has stopped spinning and hits the pit release as obsidian goes down and surgeon general pushes bigger
      brother down the pit CEASE
      2nd round draws
      1hw vs envy
      volde vs surgeon general
      tactics predictions and a toilet please as im about to burst *heads straight for the upstair toilet *
        Well, Envy's made of 3.25mm Hardox. And it has C40-300 Magmotors for drive. It's the closest thing to a vapourbot built in real life that there is.
        My plan is to spin up to full speed and hit it. 1 hit should tear up the Hardox(3.25mm is the thinnest Hardox you can get), knock out a motor, or both. If the first hit doesn't kill him, hit him again until he stops moving. The rubber on my robot's feet should prevent him from getting flung away, whereas my shockproofing protects me from my own energy. Who knows? Maybe a good hit will knock out its flipper!
        Simply put: KILL IT!!! :P
          Originally posted by corsair_lightning
          (3.25mm is the thinnst hardox you can get
          not true, i have some 1.5mm
            That's weird. Most people here on the FRA forum claim that 3.25mm hardox is the thinnest you can get.
            But anyways, tactics remain.
              [quote=team_orr]
              not true, i have some 1.5mm[/quote:2lg532so]
              Has it been milled down to 1.5mm? As far as I am aware, 3.25mm is the smallest size SSAB produce.
                Volde vs. Surgeon General
                Scatter his parts across the arena. :P
                  [quote=k_c_r][quote=team_orr:n8mm40o1]
                  not true, i have some 1.5mm[/quote:n8mm40o1]
                  Has it been milled down to 1.5mm? As far as I am aware, 3.25mm is the smallest size SSAB produce.[/quote:n8mm40o1]
                  Correct. SSAB has the smallest range from Hardox 400 to Hardox HiTuf set at 3.0-3.7 mm.
                  Docol (also from SSAB) is available in thinner plate from 0.4 to 3.0 mm.
                    What's the difference between Hardox and Docol, are they manufactured differently?
                      we return with one hit wonder vs envy
                      3 2 1 ACTIVATE
                      1hw gets up to full speed as envy goes for the pit release, now envy slowly comes in for an attack but moves away
                      very tactical this battle, but 1hw gets a hit in and they are both shot around the arena, envy almost landed out of the
                      arena as 1hw who was still spinning crashed into matildas rear, ripping off the flywheel, 1hw gets away from the ppz
                      and gets up to full speed once again as envy bashes into 1hw again and envy is sent across the arena into battleaxe
                      who grasps the into his claws and begins to strike down with the axe BANG BANG BANG SMASH envy gets away with
                      dents in the bodywork as 1hw spins up again and hits the side of envy, and a piece of envy is ripped off, but envy still
                      has full movement as it gets under 1hw and flips YEEEEHAAAA one of 1hws teeth on the ring hit the floor and the bot
                      shot up 10ft into the air and back down but still at full speed as it hits envy and rips a battery and it goes in again and
                      smashes the c02 canister, now 1hw bashes in again and rips the exposed wheel off now the refbot counts out envy
                      1 2 3 4 5 6 7 8 9 10 as 1hw backs off battleaxe drops envy down the pit CEASE
                      battle 2
                      surgeon general vs volde
                      3 2 1 ACTIVATE
                      the battle starts with volde rushing in on surgeon general and trying to clamp it but failing as surgeon general gets away
                      and cuts into the side, now volde turns and clamps surgeon general and lifts them high into the air and parades them
                      around the arena, now it lowers them, but still clamped to shunt who axes the armour of surgeon general, now volde
                      takes them over to the edge of the arena and tries to dump them out but it looks like volde has stopped moving along
                      with surgeon general, who is stuck in mid air, time is stopped as the 2 are seperated and placed in the middle of the
                      arena to fight again, the match restarts, with surgeon general moving in for the kill, but it looks like volde has stopped
                      moving completely as surgeon general comes in and rips off the clamping arms and the axe, now it hits volde again and
                      it is spun across the arena onto the pit as the refbot counts them out 1 2 3 4 5 6 7 8 9 10 as surgeon general hits the
                      pit release button and watches volde drop down CEASE
                      heat final is 1hw vs surgeon general
                        Like I said in another thread, there's just too much force behind 1HW's weapon; no matter how much shockproofing he has (and it's quite overkill :P), he's going to kill himself, or rip his own weapon off. In which case I shall sacrifice my disc. Go straight at him with the disc, and aim to hit his weapon so his self-destruction happens. It could happen all by itself, look at Son of Whyachi. :P
                        Come on, Mark. Gyrate was pushing the weight limit all by itself. Adding actual armour and shockproofing will most definitely put it well over 100kg. :P
                          kody 1hw is 150kg shuffler
                            *reminds self to check stats before typing message*
                            Still, he's going to kill himself. :P When you have an energy output as large as that at that quick of a speed, any such shockproofing is negated. :P
                              oh yeah whilst im talking to you kody i have built a soul calibur bot myself
                              kamikirimusi (kami-kiri-musi)
                              the stats are on my section of marks website :P
                                Umm...that's nice?
