crazy bots series 1 (the remake)
  • Re: crazy bots series 1 (the remake)
    we return for the match that will probably end up killing me (literally) as we have 2 killer spinners
    1 Hit Wonder vs Raven the 4th
    3 2 1 ACTIVATE
    Raven starts the battle by spinning up to full speed. 1 Hit Wonder does the same as the two robots start moving
    from the starting spots, and Raven charges full pelt at 1 Hit Wonder, and SMAAAAAAASH!!!!!!. 1 Hit Wonder landed
    on the drop zone, and Raven crashed into the wall and onto the floor flipper, but remember. The arena has been
    reinforced with armox to protect the fans. 1 Hit Wonder is moving really slowly away from the drop zone, but it
    looks like Raven is completely dead. Although the weapon is still spinning. There is no movement whatsoever from
    Raven. 1 Hit Wonder only just nudged the pit release. Now 1 Hit Wonder is dead as well. The Refbot comes in to
    count out Raven 1 2 3 4 5 6 7 8 9 10. 1 Hit Wonder is lucky that Raven broke down 1st. Now the house robots
    come in for some fun on Raven, whos weapon has finally stopped. Dead metal cuts into the ring of Raven. And
    the sparks litter the whole arena. 1 Hit Wonder is now moving, but at about 0.25 mph, as shunt comes in and
    pushes it into the pit CEASE
    since the losers melee has 2 of kodys bots. Ill do a thumb war with my stepdad to decide who goes out
      Sigh... Just like PTT3, eh, Kody?
      I'll post tactics for the loser's Melee when you show us which Kody bot was eliminated.
        i won the thumb war which means raven the 4th is out
          Excellent. That means that Dr. Acula won't get destroyed!!! :P
          Terra the 2nd vs Dr. Acula: And yet another Kody vs Mark matchup. These seem to be quite common. :P
          My tactics: Grab and pit. It's all I can do.
            We take another break for the end of series mega-brawl qualifiers
            Well, ive decided 6 robots that have automatically qualified for the mega-brawl
            They are:
            Minesweep3r
            OID
            Apocolypse 2
            Helix
            Terra the 2nd
            Iron Awe 6
            So the bots attempting to qualify
            Megaroll 2 vs Crooked Evo vs Thunderstorm (unable to enter main competition) vs ST Hammer
            Exotherm vs Behemoth vs Hazard (i know its a middleweight, but i ran out of bots) vs Brutalis 2.1
            tactics predictions and those mechanical parts that say DO NOT TOUCH!!!!
              I can't be arsed to look at the stats of Dr. Acula right now, so I'll just going to put in vague tactics of the 'lift over and pit' variety. :P
                For the mega-brawl, I would like to replace Minesweep3r with Minesweeper 4.
                And also, might I suggest you replace Hazard with The Master(the first robot to win the heavyweight division in Robot Wars)?
                Anyways:
                Megaroll 2 vs Crooked Evo vs Thunderstorm vs St. Hammer
                What the heck is Thunderstorm? Anyways, I'll use the dangerous drum to knock out Crooked Evo, and I'll also use the drum to carve up St. Hammer, unless Lian tells me/us about Thunderstorm.
                  Hazard will now be replaced by M2
                    Thunderstorm is lewis matthews robot that didnt enter the main series due to it being cut short
                    And Mark, Minesweeper 4 will replace Minesweep3r
                      We return with the mega-brawl qualifiers
                      Megaroll 2 vs St Hammer vs Crooked Evo vs Thunderstorm
                      3 2 1 ACTIVATE
                      Megaroll 2 starts us off by chasing after Crooked Evo with its drum as Thunderstorm shoves St Hammer around the
                      arena, as Crooked Evo gets under Megaroll 2 and launches it high into the air and back down, but right side up as
                      Thunderstorm gets under Crooked Evo and flips it over. Now St Hammer comes in and bashes the underbelly of
                      Crooked Evo who now self rights. Megaroll 2 now comes in and hits St Hammers body and takes off some armour
                      but it wasnt that much that came off St Hammer so they are ok. Crooked Evo gets under Thunderstorm and flips
                      them high into the air as Megaroll 2 hits the pit release. Thunderstorm lands on the pit and barely escapes as it
                      decends. Thunderstorm now comes back and flips Megaroll 2, but Megaroll 2 is unaffected whatsoever, as it hits
                      the side of Crooked Evo and it takes off a small bit off armour as Crooked Evo gets under St Hammer and flips it out.
                      Now Megaroll hits the side off Thunderstorm and now pushes it towards the pit, but i cant make it as Thunderstorm
                      is pushing back but Crooked Evo helps out Megaroll and dumps Thunderstorm down the pit CEASE
                      Megaroll 2 and Crooked Evo qualify for the mega-brawl
                        I just thought I'd make a revision to my tactics:
                        Grab Terra the 2nd, hit the pit release button, and pit her. My design has a front hinged wedge, and they seem to do pretty well against lifters and skirts. I'll try to grab her from the sides if I can, and at no point will I try to grab her from the front.
                          what
                          oh whatever, it's a joke entry anyway
                            tactics for the mega brawl : well seeing as i have 2 bots il make sure they stick together and pick the others off 1 by 1 then make them fight to the death :twisted: :twisted: :twisted:
                              Ok we return to our mega-brawl qualifiers
                              Exotherm vs Behemoth vs M2 vs Brutalis 2.1
                              3 2 1 ACTIVATE
                              Behemoth starts us off by charging Brutalis and lifting him up and over as Exotherm spins its disc up to speed as
                              M2 comes in and flips Behemoth onto its side against the arena wall, where it is trying to self right, but keeps on
                              hitting the side wall and landing back on its side again. M2 gets under Brutalis and launches it clear into the air and
                              it slams onto the pit release. The pit goes down as the siren flashes. Behemoth has just managed to self right and
                              is charging at M2 and flips it over but M2 self rights. Exotherm, who has kept out of dangers way the entire match,
                              comes in and hits Brutalis so hard that it lands outside the arena. Now Exotherm retreats to get its blade up to full
                              speed as Behemoth is flipped high into the air by M2 and back down with a crash. Behemoth has landed on its back
                              end and is trying to self right as Exotherm hits M2's side and rips off a side panel. Behemoth self rights and turns M2
                              over onto its back but M2 self rights, only to be flipped over again by Behemoth and is pinned on its side as Exotherm
                              hits the underside of M2 and rips off both wheels. M2 self rights but cant go anywhere as the Refbot counts him out
                              1 2 3 4 5 6 7 8 9 10 CEASE
                                Whos gonna get smashed in the play-offs
                                Dr Acula vs Terra the 2nd
                                3 2 1 ACTIVATE
                                Dr Acula starts us off by charging at Terra and tries to clamp it down but misses as Terra gets under the Dr and
                                lifts it up and it lands back down, bouncing off the ground. Now Terra hits the pit release and charges Dr Acula
                                and gets under it and slams it into the ppz where dead metal grabs Dr Acula and brings its disc into play and it
                                looks like it hurts BZZZZZZZZZZZZZZZZT!!!!! Sparks fly from Dr Acula and litter the arena as Terra gets underneath
                                and props Dr Acula against the wall. It looks like Dr Acula cant get off, oh dear here comes the Refbot to count them
                                out 1 2 3 4 5 6 7 8 9 10. Terra now lifts shunt up and over. Mr Psycho is not pleased and picks Terra up and dumps
                                it out of the arena as Dr Acula is shoved down the pit CEASE
                                The grand final draws
                                Apocolypse 2 vs Iron Awe 6
                                1 hit wonder vs Terra the 2nd
