crazy bots series 1 (the remake)
  • Re: crazy bots series 1 (the remake)
    your not the only one with soul calibur bots
      far be it from me to point out flaws in other peoples fights, (and plz dont take offence from this anybody) but theres no way 1hw could beat envy, the weapon it too powerfull, it will rip itself to shreds. however you are slowly improving your fights, just try and make it longer and set it out differently
      jack
        Originally posted by joeychevron
        What's the difference between Hardox and Docol, are they manufactured differently?
        Just like Hardox, Docol is availale in different grades. Dependent on the mixture of ingredient and the way they are processed. Usually the high tensile Docol alloy has better welding capabilities but is less hard than Hardox, but just a few percent less.
        Basically Hardox is for the heavy duty stuff, Docol is for strong car panels and such.
          Actually, 1HW is a 200kg true walker. The system uses no rotational parts whatsoever.
          Tactics: KILL IT!!! I probably won't get knocked out(shock-mounted motors and shockproofing), but with his not-as-good armour, I'll easily be able to kill it.
          And it does have a lot of shockproofing, due to the 200kg true walker weight limit.
            right we take a break from competition for the featherweights
            beauty2/jack vs heretic/kody vs starfighter/mark vs drumroll/random realie
            in the robots live arena with battleaxe as house robot
            3 2 1 ACTIVATE
            heretic starts of by charging beauty 2 who flips them high into the air as starfighter comes in and flips beauty 2 over
            now drumroll hits heretic and it goes flying across the arena and into the claws of battleaxe who now bashes them with
            the axe SMASH SMASH BANG BANG their is a big dent in the top of heretic as starfighter heads for the pit release as
            beauty 2 flips drumroll who rolls back onto its wheels and hits the side of beauty 2, taking out a bit off armour as
            starfighter flips heretic over but its kind of pointless seeming as heretic is invertable, now heretic hits the pit release
            and the pit goes down, now starfighter flips heretic against the wall and its stacked there, its not going anywhere as
            beauty 2 flips drumroll onto the wall and now it flips them out as starfighter tries to do the same with heretic but only
            brings heretic back into it, now starfighter flips beauty 2 into battleaxe but beauty 2 gets away and lifts battleaxe up
            and starfighter joins in and lifts up the other side up as heretic hits beauty 2 from the back and rips the armour off as
            starfighter charges it to the edge off the arena and flips it up against the wall, now it turns its attention to heretic as it
            pushes it towards the pit but heretic dodges, now starfighter flips heretic against wall and tries to flip it out but fails
            again, but starfighter gets under again and flips it onto the arena wall but heretic only just drove back in, now it seems
            like beauty 2 is being counted out 1 2 3 4 5 6 7 8 9 10, now for good measure starfighter flips beauty 2 out of the arena
            as heretic hits the rear end of starfighter, but starfighter turns around and rams heretic down the pit but heretic is safe
            as its through to the finals CEASE
              And I make it to the featherweight finals once again...
                we are back with the heat final
                1 Hit Wonder vs Surgeon General
                3 2 1 ACTIVATE
                1 Hit wonder starts us off by spinning its ring up to full speed, meanwhile Surgeon General spins up its own disc and
                heads straight for 1 Hit Wonder!!! CRASH The two robots land on the opposite sides off the arena, talk about an impact.
                Now Surgeon General reverses into the pit release, the siren flashes as the pit goes down, now 1 Hit Wonder gets back
                up to its maximum speed. But remember it has a speed cap on it so it dont kill itself. Now 1 Hit Wonder turns, looking
                to damage the disc of Surgeon General. But Surgeon General is to quick, now it gets its own disc up to full speed and
                charges 1 Hit Wonder SMASH, both bots go flying across the arena. 1 Hit Wonder landed in the claws of BattleAxe but
                gets away. Surgeon General landed next to the pit. Now 1 Hit Wonder hits Surgeon General in the side. BASH. Off comes
                the right hand wheel of Surgeon General. Ive just looked at the camera view from the pits, and the roboteers shout
                Oh man what a hit. Others are saying Oh great, i might be up against that now. Now 1 Hit Wonder smashes into
                the other wheel of Surgeon General, tearing it off, and it lands out of the arena. Now the Refbot comes in to count
                Surgeon General out, oh dear, the favourite for the heat is out. 1 2 3 4 5 6 7 8 9 10 As 1 Hit Wonder shoves the lifeless
                Surgeon General into the pit. CEASE
                the semi final draws
                terra the 2nd/kody vs iron awe 6/jack
                dr acula/mark vs apocolypse 2/liam
                1 hit wonder/mark vs raven the 4th/kody
                the feather weight battle
                flow/jack vs micro gore/kody vs beauty IV/mark vs minimoth/random realie
                tactics predictions and a microwave with a pizza inside please
                  Happened in real life too - no fun
                    hmm Dr. Acula
                    good design, likeable robot, but it has a narrow area of attack and the weaponry requires a lot of precision. Usual Apocalypse II tactics, drive underneath, then use the barbs on top to tip Dr. Acula into the pit. Not risking the flipper in this match, Dr. Acula is too good an opponent.
                      Terra the 2nd vs Iron Awe 6: Kody for the win.
                      Dr. Acula vs Apocalypse II: Former tag team partners turned enemies. Very ironic... I'll try the classic Dr. Acula strategy again: Grab and pit. This'll be harder, due to his skirts, which my claws might slide off. However, his back panel is flat, so I'll try to grab him by his back panel and pit him. That's pretty much all I can do.
                      1-hit Wonder vs Raven the 4th: We meet again, Kody. I don't think this'll ever end...
                      Anyways, I have more shockproofing, more weight, more grip, however he can put out more KJ. He can't sneak up on me, seeing as I have a spinning rim that goes all the way around, but I can't sneak around him due to his spinning rim. It's going to come down to who gives out first. It probably won't be me who gives out first.
                      Simply, I see a repeat of Mass Disctruction Ultimate vs Crankshafted in the PTT3 Semi-Finals. With Raven the 4th being Crankshafted of course...
                      Flow vs Micro Gore vs Beauty IV vs Minimoth: What can I do? Stay out of Flow's way at the start. Try to pit it if I have a chance. Also try to pit Micro Gore. Since it's an axlebot, it'll be easy to shove around and pit.
                      Also, you can thank me for improving Lian's battle quality. I had a little talk with him over some PMs..
                        Raven the 4th is a joke bot, so I don't care whether I win or lose, really.
                        Hit 1HW repeatedly, win or lose. Then dance.
                          Welcome to the semi-finals of Crazy Bots
                          To kick us off, we have the featherweights at the Robots Live arena (which is in a studio next door :P)
                          From Hemal Hempstead, in Hartfordshire Minimoth
                          From Toronto, Canada, Micro Gore
                          From Richmond (is that correct jack :P ), Flow
                          From Texas USA, Beauty IV (but the bot is english duh )
                          The drivers
                          Minimoth/Kane Aston (as its partly his bot so he is driving )
                          Beauty IV/Mark Elam
                          Micro Gore/Kody Kunz
                          Flow/Jack Orr
                          The house robot will be of course BattleAxe
                          3 2 1 ACTIVATE
                          Minimoth gets us started by lifting Beauty over but Beauty self rights and pushes Micro Gore into Battleaxe who tries
                          to axe the bot, but misses it as it gets away and gets into a scrap with Flow who launches it clear into the air and back
                          down, landing on Minimoth's scoop in the process. Now Flow flips Beauty towards the wall as Minimoth flips Micro Gore
                          over but its kind of meaningless as micro gore goes after Flow and crumples into the top armourment. Flow tries to get
                          away but Micro Gore has a firm crush on it, so in other words, its not going anywhere. Beauty has just flipped itself off
                          the arena side wall hits the pit release, the pit now decends. Minimoth turns Beauty over once again. But Beauty is too
                          close to the pit, but Mark doesnt notice and self rights. Beauty IV has landed in the pit, so its out. Now Minimoth flips
                          Flow over, but its still being clamped onto by Micro Gore, who finally lets go. Flow self rights and launches Micro Gore
                          clear into the air and out. Now Minimoth drives at Flow but flow flips them onto their scoop and out of the arena CEASE
                          the feathers final will be
                          flow vs minimoth vs starfighter vs heretic :P
                            Now for the 1st battle
                            Iron Awe 6 vs Terra The 2nd
                            3 2 1 ACTIVATE
                            Iron Awe starts us off by charging Terra and trying to flip it, but fails as Terra's skirts prevent Iron Awe from getting
                            under. Terra now lifts Iron Awe up and over onto its back, but Iron Awe self rights over the top of Terra, who in
                            reply turns to lift Iron Awe over, but Iron Awe gets away from Terra and hits the pit release. Terra pushes Iron Awe
                            into the ppz where Shunt is lurking with the axe and fires it, but it misses Iron Awe and gets stuck in the floor. Now
                            Iron Awe gets under Terra from the side and flips it high into the air and back down with a crash. But Terra, who
                            was completly unshaken by the flip, self right fantastically. Now Terra lifts Iron Awe onto its back, but Iron Awe
                            self rights, but theres a problem with Terra. The lifting arm is jammed outwards, which means the front is exposed to
                            a flip, and Iron Awe takes advantage of the situtation and launches it high into the air, Terra lands with a crash on
                            its back, unable to self right. Iron Awe does a victory spin. The Refbot counts out Terra 1 2 3 4 5 6 7 8 9 10.
                            Iron Awe takes a ticket to the finals, but we have not seen the last of Terra, as it will be in the loser's melee.
                            Iron Awe is being chased by Dead Metal, but is avoiding it with very quick movements, now Iron Awe goes towards
                            the stuck Shunt and flips it over. Now the house robots back off from Iron Awe who now charges Terra and tries
                            to flip it out but fails, now it tries again. Now Terra is stacked against the wall. Iron Awe flips Terra out of the arena
                            3 is the charm for Iron Awe CEASE
                              Welcome back to the semi finals
                              Apocolypse 2 history
                              (as apocolypse) Pheonix Cup winner
                              (as apocolypse) Vapourbot Vengance finalist
                              Dr Acula history
                              Given to Mark Elam by Jamie McHarg
                              2nd place in Liams Mini Tournament
                              3 2 1 ACTIVATE
                              Apocolypse the 1st to move gets under Dr Acula and bashes them into the wall. Now it drags back for another go, and
                              slams Dr Acula into the wall once again. Dr Acula is trapped on the wedge of Apocolypse because of the barbs on the
                              wedge and flipper. We spoke to Liam earlier and he said hes gonna ram Dr Acula, due to the fact it might be risky to fire
                              the flipper. Apocolypse hits the pit release, with Dr Acula still stuck to it. Apocolypse tries to drop Dr Acula in, but cos it
                              might go in itself. Now Apocolypse now powerslams Dr Acula into the wall. Now it pushes Dr Acula to Sir Killalot who now
                              picks Dr Acula up and spins it around and around and around, now it lets go of Dr Acula. Now Dr Acula tries to get round
                              the back of Apocolypse to clamp it down but its just to fast. Apocolypse gets round the back of Dr Acula and shoves it
                              towards the pit but Dr Acula moves just in time, but drove into the ppz in the process where Dead Metal gets its saw in
                              the armour of Dr Acula BZZZZZZZT!!!!!. Look at that massive cut in the side of Dr Acula as it gets away from the ppz
                              but not away from Apocolypse who gets underneath and slams it against the wall. Now Apocolypse drives full pelt at the
                              pit with Dr Acula on the front and Dr Acula drops in and Apocolypse barely got away from the pit CEASE
                              Dr Acula goes to the losers melee, as Apocolypse 2, the son of a champion, is carrying the tradition on and is through to
                              the grand final. 1 Hit Wonder vs Raven the 4th up next :P
                                Reposting so you don't forget.
